carlossa52(at)gmail.com Guest
Posted: Mon Jun 11, 2012 8:13 am Post subject: bushings |
Hello,Some time ago - but I think this year - somebody posted some information about bushings. I spent a long while searching, but couldn't find neither the post nor the product.Does anybody remember it? ...and while I have your attention: the upper and lower rudder hinges have different size holes (1/4" and 3/16" respectively), but the bushing is 1/4" for both...?? ThanksCarlos
DaveG601XL
Joined: 27 Oct 2006 Posts: 351 Location: Cincinnati, Oh
Posted: Tue Jun 12, 2012 8:13 am Post subject: Re: bushings |
Carlos,
I used the recommended 1/4" x .028 4130N tube as my bushing material so I can't help you if you were looking for an alternate material. I am writing to comment on your 1/4" vs. 3/16" hole sizes question. Look at both the rudder and fuselage rear member drawings at the same time. Where the bushing goes through the hinge middle piece, it is drilled to 1/4". Where the bushing stops up against either side, which clamps the bushing, it is drilled to 3/16" so only the AN3 bolt passes through. The entire hinge is split up between the two drawings so looking at both should make it plain to see.
_________________ David Gallagher
Cincinnati, OH area |
