dlm34077(at)q.com Guest
Posted: Mon Apr 16, 2012 4:59 pm Post subject: VDO 360-003 fuel pressure sensor transducer |
I am on my second; the first lasted about 500 hours; the second has lasted about 50 hours. They begin to fail by showing fuel pressures that are abnormally high intermittently. Anyone else has a similar problem?
thane
Posted: Tue Apr 17, 2012 3:31 am Post subject: VDO 360-003 fuel pressure sensor transducer |
Yep, I am on my 3rd. one. I have just over 215 TT. Sure wish they were more robust!!
Thane States
RV-10
_________________ Working on finish kit: I hate fiberglass!! |
rene(at)felker.com Guest
Posted: Tue Apr 17, 2012 3:55 am Post subject: VDO 360-003 fuel pressure sensor transducer |
I am a yes also, lost my first one at about 70 hours….the second is still going strong at 150 hours.
Rene' Felker
N423CF
801-721-6080
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Thane States
Sent: Tuesday, April 17, 2012 5:31 AM
Subject: Re: VDO 360-003 fuel pressure sensor transducer
Thane States
RV-10
Posted: Tue Apr 17, 2012 5:11 am Post subject: VDO 360-003 fuel pressure sensor transducer |
Sounds like GRT ought to sell the industrial one only with new EIS shipments. Cheap purchase just means that you get to change them frequently.
Sent: Tuesday, April 17, 2012 4:31 AM
Thane States
RV-10
johngoodman
Posted: Tue Apr 17, 2012 12:17 pm Post subject: VDO 360-003 fuel pressure sensor transducer |
I talked with Sandy and Gregg at GRT yesterday; there is a way to determine whether it is the sensor good or bad with the top cowl off. Mine, however, is intermittent, I am going to try and clean the terminals to determine whether my problems currently could be connections. The choices are two: (1) keep replacing the cheap sensor (I carry an extra with me) or (2) install the robust one which requires slight changes to the wiring. I will make a decision on it in a month or so; IIRC the three wires from it go to power, ground and the sensor. Since the current sensor already has a 4.8V power interconnection with the sensor line it must be removed which for me means removing some panel units to find and cut the offending wire.
Thane States
RV-10
