chasb(at)satx.rr.com Guest
Posted: Tue Mar 06, 2012 12:38 am Post subject: Re-juvinate a NiCad Battery? |
Is there anyway to rejuvenate an old NiCad battery? I have an iCOM
hand held radio with a rechargeable battery pack. I assume the battery
is a NiCad. The radio requires a 9.6v charge, but I can't get the pack
charged above 9.25v. At that level I can listen to the radio, but
cannot transmit. The charger that came with the radio puts out 10.4v
when hooked to the battery, but the battery voltage won't increase
even after a day or so of recharging. Is there any way to save this
battery pack?
Charlie Brame
RV-6A N11CB
San Antonio
Posted: Tue Mar 06, 2012 6:36 am Post subject: Re-juvinate a NiCad Battery? |
At 02:37 AM 3/6/2012, you wrote:
| Quote: | --> AeroElectric-List message posted by: Charles Brame <chasb(at)satx.rr.com>
battery pack?
Charlie Brame
RV-6A N11CB
San Antonio |
Yes . . . maybe . . . and perhaps no. NiCads can suffer
certain degrading of chemistry that prevents any recovery.
Some 'failed' batteries have grown whisker-shorts in
the cells that MIGHT yield to a low voltage impulse
of many amps. For example, if you have access to a single
2 volt lead-acid cell or even another FAT ni-cad cell,
connecting it in parallel with the suspect whisker-short
might fuse it and recover the cell's utility.
The best advise I can offer is to re-cell your battery
pack. There are battery re-build companies that do this
quite well. Your battery pack is probably an array of
AA sized cells which you can purchase with solder tabs
from places like:
http://tinyurl.com/74c2x27
http://tinyurl.com/899bjcu
Bob . . . [quote][b]
ronburnett(at)charter.net Guest
Posted: Tue Mar 06, 2012 6:53 am Post subject: Re-juvinate a NiCad Battery? |
You might take the battery to Wholesale Batts. to see what they have for
a replacement. I did that for a radio battery for my Luscombe that has
no elect. system. I had to modify the length of the case that held the
batt. but for less than $20 I have a much better system that I can
recharge. The old one quit recharging.
Good luck,
Ron Burnett
On Tue, Mar 6, 2012 at 2:37 AM, Charles Brame wrote:
battery pack?
Charlie Brame
RV-6A N11CB
San Antonio
Mike Welch
Posted: Tue Mar 06, 2012 7:31 am Post subject: Re-juvinate a NiCad Battery? |
Charlie,
I also have an Icom handheld radio. Years ago, when my Icom A22 ni-cad OEM battery pack died, I bought their
(expensive) AA battery holder (now they're half price). It comes empty, and you simply use 10 of your rechargeable generic
AA batteries. In fact, you can use AA ni-cads, or AA NiMHs, or plain old Duracells. It's just an empty compartment,
and you fill it up with 10 rechargeable AA batteries.
For years I've just used the 1.2 volt NiMH's I got off of eBay. A couple of years ago, I bought the new rechargeable
1.5 volts models, although it worked just fine on the (10) 1.2 volt versions.
Here is the container for the A22. I would imagine you could get one of these for all their handheld models, although I haven't looked.
(you didn't mention what model you have)
http://www.ebay.com/itm/CM-167-10-AA-Cell-Battery-Case-ICOM-Air-Band-IC-A3-IC-A3E-IC-A22-IC-A22E-/160650004281
?pt=LH_DefaultDomain_0&hash=item25677c8739#ht_3307wt_1063
Mike Welch
> battery pack?
> Charlie Brame
> RV-6A N11CB
> San Antonio
skywagon
Posted: Tue Mar 06, 2012 10:59 am Post subject: Re-juvinate a NiCad Battery? |
Mike,
Great tip for the Icom A-22..Thanks.
David
PS: I do not know any way to rejuvenate an aged, encapsulated NiCad
'battery' pack. If one has surgical skills and can cut the pack apart, then
you can find and toss the offending cell(s). By that time, it would make
more sense to toss them all and start with all fresh. Still a big job for
encapsulated type batteries....
___________________________________________________________________
Posted: Tue Mar 06, 2012 11:20 am Post subject: Re-juvinate a NiCad Battery? |
I've done the 'repopulate' trick in an OEM pack (different brand radio)
by replacing the nicads with NiMH to get roughly the same voltage & more
AH's. Still had to stuff the pack with packing material to take up the
empty space in the pack. Still working fine after many months; I use the
same AC charger that came with the radio.
On 03/06/2012 12:57 PM, David Lloyd wrote:
<skywagon(at)charter.net>
Mike,
David
apart, then you can find and toss the offending cell(s). By that
time, it would make more sense to toss them all and start with all
fresh. Still a big job for encapsulated type batteries....
rparigoris
Posted: Tue Mar 06, 2012 11:56 am Post subject: Re-juvinate a NiCad Battery? |
Just a quick note on AA and AAA rechargeable cells. The latest and greatest LSD NiMh cells are well, great! LSD is Low Self Discharge, so cells that have LSD membranes can go a long period of time without discharging. Home Depot sells Energizer cells in AA and AAA that are LSD cells. I also find in the cold they work well. I haven't tried to solder them yet, but I suspect it will not be a problem. Normally soldering I scuff with a little 100 or so sandpaper, clean with Isopropyl alcohol, put a mini drop of mild activated flux, using a 150 watt iron quickly touch, get solder to flow (this happens very quickly) and cool with a damp paper towel "right now!). To interconnect cells I use solder braid not allowing it to wick and make the braid solid. Works great. You can use a lower wattage iron, but don't mess around, flow and cool. I don't think I ever lost a battery due to damaging because of soldering.
Once you solder them into a pack, just use a conmstant 1/10C style charger or a peak charger if you have one. An LM1117 or LM317 with one resistor as bob suggested a while back works fine. Charge C/10 for 14 to 16 hours.
The worst batteries I ever had to solder were long ago LiIon can cells. For those I tinned with Utectic acid core solder. It was some sort of stainless that I just couldn't get to tin with all the solders and fluxes I could find. The Utectic is pretty amazing stuff. Once tinned I solder sucked off as much as I could, then tinned and sucked a few times with 63-37, then soldered the braid on. I did that pack in the early2000s, and there is no sign of corrosion or eroding on that pack as of today.
Ron P. [quote][b]
email(at)jaredyates.com Guest
Posted: Tue Mar 06, 2012 1:37 pm Post subject: Re-juvinate a NiCad Battery? |
I'm also very impressed with the LSD cells. I soldered a pack just like usual and they behaved just as the nicd cells always have. It's nice to be able to pick up the rc airplane transmitter and not have to worry about whether it has been on the charger lately. I would recommend these cells especially for applications that involve such infrequent use.
On Mar 6, 2012, at 14:54, rparigor(at)suffolk.lib.ny.us (rparigor(at)suffolk.lib.ny.us) wrote:
Ron P.
Float Flyr
Posted: Tue Mar 06, 2012 4:50 pm Post subject: Re-juvinate a NiCad Battery? |
Having rebuilt several Ni-Cad packs I agree with you entirely. When one
cell bites the bullet you can be sure the rest are not far behind. What I
would suggest is to build another pack from newer NIMIH cells which have
longer life and less memory effect. Get the ones with the soldering tabs
already in place.
All these cells do auto discharge and you will find the total power they
can hold (capacity) deteriorates with age. You can reduce this
deterioration by only charging your cells to 70% and allowing then to
discharge only to 40%. From what I've read, a cell fully charged will lose
20% of its capacity in a year. A cell kept between 40 and 70% charge will
lose only 2% of its capacity. I think Lithium Ion cells also lose capacity
in similar quantities... Makes one think about all those little cells in
electric cars eh?
Noel
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
raymondj(at)frontiernet.n Guest
Posted: Tue Mar 06, 2012 5:11 pm Post subject: Re-juvinate a NiCad Battery? |
Question: How do you determine the percent charge on a battery pack. Is
it by voltage or current or what. That's one of my pet peeves with
rechargeables in everything. The batteries die from old age rather than
from reaching the max number of cycles.
Looking forward to hearing about this.
Raymond Julian
Kettle River, MN
"And you know that I could have me a million more friends,
and all I'd have to lose is my point of view." - John Prine
On 03/06/2012 06:48 PM, Noel Loveys wrote:
already in place.
electric cars eh?
Noel
Posted: Tue Mar 06, 2012 8:18 pm Post subject: Re-juvinate a NiCad Battery? |
At 07:09 PM 3/6/2012, you wrote:
Is it by voltage or current or what. That's one of my pet peeves
with rechargeables in everything. The batteries die from old age
rather than from reaching the max number of cycles.
Okay, but you're probably not going to like it.
Some years ago I wrote an article about the economics
of using house branded AA cells in my airborne hardware.
http://aeroelectric.com/articles/AA_Bat_Test.pdf
The thrust of the article went to in-flight reliability
of my battery powered hand held GPS and Comm radios
coupled with risk mitigation. One night over west
TX I found it necessary to change the four AA cells
out in my GPS receiver. During the fumbles with the
loose cells in the bottom of the flight bag, I dropped
one of the last good set of four cells on the deck.
We'll you can guess how THAT went. Had to turn
on the (ugh) VOR receivers and finish the trip.
This event started a train of thought to deduce
(1) the practicality of carrying a charger on
trips - another piece of hardware - and using
rechargeable batteries to be topped off before
flight . . . or simply putting new cells into the
device and pitching them when I got home.
I'd already wrestled with the ni-cads for my
flashguns and found that under less than ideal
conditions, I MIGHT be good for a several dozen
cycles . . . but when the flash gun craps in
the middle of a shoot and only one cell out of
the 4 was bad . . . the economics of hassle
was rearing an ugly head.
I did try to establish sets of cells that
had been cap-checked in the last 10 cycles
or so and tried to keep cells of similar
capacity together. This also spotted cells
that were crapping out. I'd pitch them when
they dropped to 75% of capacity. That preventative
maintenance process improved on-the-job reliability
but it also took TIME that was not adding value.
When cheap cells became available on eBay, I
started dating the new cells when I put them
in service and pitched them at 6 months.
The cost of time to test them exceeded the
value of the cells!
Premium, highly advertised batteries in
one radio (or flashgun) was worth a gallon
of gas. So I began to wonder just how bad the
el-cheeso brands of AA alkaline battery could be.
In the article, you read how even the least
expensive cells (about 22 cents apiece)
offered VERY good value for contained energy.
That's when I began the practice of installing
a fresh set of cells to go outbound, another
fresh set to come home. Fresh batteries
were dropped into the flight bag with a piece
of masking tape on them. I took the tape off
when the battery was installed. When I got
home un-tapped batteries were pressed into
other service and I never found myself fiddling
with batteries and battery box covers in flight.
Wrestling with Ni-Cd or Ni-Mh arrays still
comes with the attendant uncertainties. Just
how good are these cells and how closely
matched are they for capacity? So to this day,
I still don't use rechargeable cells in flight
hardware or mission critical devices. The AA
cells are so cheap that keeping fresh ones in
the electrowhizzy takes very little time,
attention and/or expense.
Now, the short answer to your question: You
need a device tailored to the task of fully
discharging a cell and reporting its contained
energy. I.e. a cap-checker. If you use a lot
of loose cells, this isn't too hard but if
the cells in question are in a soldered up
array inside a radio . . . you're flying
"blind" with respect to the real reliability
of the device.
Cell arrays that are regularly excerised seem
to do real well. My Makita and DeWalt drill
batteries seem to be good for a year or more
but there's a fast charger nearby with another
battery of unknown quality setting in it.
Rechargeable batteries are fine on the ground
but I'm reluctant to fly with them as part
of my failure tolerance team of electrowhizzies.
http://aeroelectric.com/Pictures/Misc/Vacination_for_Dark_Panel_Syndrom.pdf
Float Flyr
Posted: Wed Mar 07, 2012 12:06 pm Post subject: Re-juvinate a NiCad Battery? |
The only way I've been able to determine if a battery is reaching its end of
life is to use it. As a professional photographer I've had lots of
experience with NiCads going dead at the wrong time (Murphy's law) so I used
to always carry a couple of sets of alkalines for backup. A couple of
things I found when batteries got to the point the just wouldn't hold a
charge I would completely discharge them... keep a short across the
terminals for 24 hr. Then hit them with a current of close to an amp with a
voltage around 3V for about ten seconds... then recharge them normally. It
seemed to rejuvenate somewhat and remove memory effect. The only batteries
I tried this on were pretty well discharged at the time of applying the
short.
In recent years I've gone to Lithium cells. I can't recharge them, the
chance of leakage and fire is too great, but they seem to last forever and a
second backup set is all I'll ever need. Shelf life of the lithium
batteries is in the order of several years and just about everything I've
tried them in seems to like them whether it's a high current application or
a very low current application. I have found that lithium batteries that
have used too much power to be used in a photo flash or digital camera will
still last a year or more in remote controls.
Noel
Kitfox III-A
Posted: Wed Mar 07, 2012 1:21 pm Post subject: Re-juvinate a NiCad Battery? |
Greetings Noel,
In an earlier post you mentioned that the life of rechargeable batteries
could be extended by operating them in a 40% to 70% range. My question
is how is the percent of charge state quantified?
Raymond Julian
Kettle River, MN
short.
Noel
Posted: Thu Mar 08, 2012 7:06 am Post subject: Re-juvinate a NiCad Battery? |
batteries could be extended by operating them in a 40% to 70%
range. My question is how is the percent of charge state quantified?
It it isn't . . . not without measurements. Many battery
powered devices, especially laptops have smart batteries
fitted with circuitry that measures the energy
required to top off a battery and compares it with the
energy demands of the computer. As the battery ages,
the predicted endurance for the battery goes down even
though the percentage of available capacity gets topped
off to 100% each cycle.
The better rule of thumb for both NiCd and HiMh
technologies is to use them. They seem to enjoy being
cycled. Unlike the LiIon battery that is damaged by deep
discharge below 10% or so, you don't hurt the metal
batteries by taking them all the way to zero. You don't
want to store them in a discharged state . . . which
suggests some form of maintainer tray to keep service-
ready cells topped off for regular use.
It's almost a certainty that I would have enjoyed much
longer service lives from metal cells I've owned if
I had invested time and equipment to their maintenance.
At some point the economics fall apart when you spend
many times more $value$ in maximizing the service
life than the battery costs to simply replace it.
Posted: Thu Mar 08, 2012 7:39 am Post subject: Re-juvinate a NiCad Battery? |
Is it voltage that is measured. Does the manufacturer supply a voltage
vs. % charge graph or table? Or is it derived experimentally?
I understand that there are cost/benefit issues here, but my objective
is to understand the process from a physics perspective for my own
education.
Thanks again for taking the time to help.
Raymond Julian
Kettle River, MN
On 03/08/2012 09:04 AM, Robert L. Nuckolls, III wrote:
<nuckolls.bob(at)aeroelectric.com>
------ SNIP--------
Float Flyr
Posted: Thu Mar 08, 2012 8:27 am Post subject: Re-juvinate a NiCad Battery? |
This post converted to html
Bob I’ll put my comments in red after each of your paragraphs only because I feel you have so much there AI don’t want to miss anything.
Kitfox III-A
Posted: Thu Mar 08, 2012 8:28 am Post subject: Re-juvinate a NiCad Battery? |
Bob and others have mentioned trying the 3V/1Amp charge. What device or battery do you use to provide the 3V - 1Amp charge?
Charlie Brame
RV-6A N11CB
San Antonio
[quote]Time: 12:06:32 PM PST US
From: "Noel Loveys" <noelloveys(at)yahoo.ca (noelloveys(at)yahoo.ca)>
Subject: RE: Re-juvinate a NiCad Battery?
I tried this on were pretty well discharged at the time of applying the-------snip---------[b]
ainut(at)knology.net Guest
Posted: Thu Mar 08, 2012 8:53 am Post subject: Re-juvinate a NiCad Battery? |
Probably not.
David M.
battery pack?
Charlie Brame
RV-6A N11CB
San Antonio
Tell the truth. Be honest. Be responsible to and for yourself.
We want our freedoms back. Strike the illegal legislations called: 1) obamacare, 2) "Patriot (HA!) Act", and 3) 'presidential orders' that affect anyone besides gubmnt worker bees.
Hate crime laws? Really? Thought police? Orwell would be proud.
Every gram of cocaine you buy from elsewhere contributes to an innocent being murdered in Central and South America. Grow your own or Stop taking it.
Posted: Thu Mar 08, 2012 12:36 pm Post subject: Re-juvinate a NiCad Battery? |
At 09:36 AM 3/8/2012, you wrote:
| Quote: | --> AeroElectric-List message posted by: rayj <raymondj(at)frontiernet.net>
Is it voltage that is measured. Does the manufacturer supply a voltage vs. % charge graph or table? Or is it derived experimentally?
I understand that there are cost/benefit issues here, but my objective is to understand the process from a physics perspective for my own education. | Understand . . .
I don't think that open circuit terminal voltage has a strong correlation to stored energy on the metal cells. Least wise, I've not seen any charts claiming to offer insight.
Posted: Thu Mar 08, 2012 1:09 pm Post subject: Re-juvinate a NiCad Battery? |
I like the second idea. The reason is the drop in voltage on rechargables is so different from conventional batteries. One second they look full charged the next second they are dead flat.
Which goes to my posting a few minutes ago considering an inquiry about voltage versus state of charge on the metal cells. The discharge curves are so flat (and I believe temperature dependent) that the only reliable measure of capacity is to run them down and count the electrons ------------
value of the cells!
Now you’re right i don’t like this... I wish I’d thought of dating the cells because in real terms after six months the really become iffy. Thanks for the idea.
Certainly your results may vary. But given that I can buy a metal cell for about the same retail price as a premium pink-bunny battery, I figure if I recharge the things 10 times, I've received more than my money's worth out of them. From that point on, it's gravy and I've got no regrets for pitching a set of cells at first sign of becoming an impediment to completion of task. ------------ We don’t get any cells (AA) that cheap this far north, wish we did.
Buy them off eBay. Got any Sam's Clubs around? The Members Mark AA cells are about $13 for a pack of 48 cells. Here's a good mail order source for low cost premium cells
http://www.batteriesandbutter.com/DUBU.html
---------------- The discharge profile of alkaline cells is so different from that of NiCad cells that even a cheap cell is better value than a NiCad especially if you don’t get the advertised 1000 recharges.. BTW did you ever find a person who actually go anywhere near that number of recharges?
Don't think so. You might get that kind of result in the lab . . . or maybe that's based on putting partially discharged cells in the charger every night. We know that an SVLA battery is good for about 100 deep discharge cycles under ideal conditions and "thousands" of engine starts when never called upon to supply a lot of energy. I suspect that 1000 cycles thing is more advertising hype than real world performance.
Worst thing in the world is to leave the batteries with a full charge on it. If you want to leave a battery for an extended period do so with that battery flat. That is why when you get a new device the batteries are NEVER charged! Daily use, especially complete use of batteries is a secret to long life.
I don't think my experience confirms this. Nickle cells have such high discharge rates that I would be surprised to find anything so equipped to run right out of the box.
Now for the best batteries I have ever seen. They are the batteries that Kodak used to put in their disposable flash cameras. Most of those batteries only saw a dozen flashes from micro flash units. So when they came into the processing lab they were just about full.
Do you know that the disposable camera uses a nickle battery? I'd think they would have to use alkaline or lithium to get any sort of shelf life . . . and yes, running one roll of film through the camera shouldn't even come close to discharging the cell(s).
