dmaib@me.com
Joined: 25 Apr 2006 Posts: 455 Location: New Smyrna Beach, Florida
Posted: Mon Feb 13, 2012 4:42 pm Post subject: Wheel Pants |
I have the James wheel pants on my 10. They were harder to fit than the
Van's pants. They are not as wide as the Van's pants but I don't yet have
any performance data.
Carl
dmaib(at)mac.com Guest
Posted: Mon Feb 13, 2012 6:46 pm Post subject: Wheel Pants |
No, the pants I remember seeing were not the James pants. Someone was
making them with an eye to offering them as a replacement for the
stock pants. They looked like they would have really nice fit and
finish with far less work than the originals. Mine are beginning to
show some wear and tear, and since I have never been very happy with
the way mine turned out, I was just wondering if there was another
option out there, or if I had been dreaming again!
David Maib
RV-10 #40559
Transition Trainer
On Feb 13, 2012, at 7:40 PM, Carl Froehlich wrote:
<carl.froehlich(at)verizon.net>
than the
yet have
Carl
fritzsch(at)eskimo.com Guest
Posted: Mon Feb 13, 2012 8:32 pm Post subject: Wheel Pants |
You may be thinking of a product from Airflow Technology which they
describe as "Low Profile Pressure Recovery Wheel Pants". I have a flier
from them in my files but don't remember where I got it. The flier
lists the main gear pants including gear leg fairings for $390 each and
the nosewheel pant at $275. Surprisingly I don't see a URL but they
list the phone number 831-771-0438. If interested, I would try to find
them on the web first by searching for them by company name tolearn a
little more about them.
Dave
Dave Fritzsche
40813
Puyallup, WA
Wings
David Maib
RV-10 #40559
Transition Trainer
> have
> Carl
robin(at)PaintTheWeb.com Guest
Posted: Mon Feb 13, 2012 9:26 pm Post subject: Wheel Pants |
Airflow Technology is Alan Bickle. He built a beautiful -10 with a James cowl (I think) and then modified the inlets about 1.5" for greater airflow in the upper deck. His fiberglass work (pants, cowl, plenum) on the 10 looks amazing from the photos I have seen.
Info below was copied from a Matronics posting the middle of last year.
Alan Bikle
AIRFLOW TECHNOLOGY
1586 Moffett Street Ste. E
Salinas, CA. 93905
Tel: 831-320-0193
Robin
dmaib@me.com
Posted: Tue Feb 14, 2012 6:47 am Post subject: Re: Wheel Pants |
Thanks guy's. Alan Bikle at Airflow Technology is the one I was looking for. I will get in touch with him.
_________________ David Maib
RV-10 #40559
New Smyrna Beach, FL |
msausen
Posted: Tue Feb 14, 2012 9:30 am Post subject: Wheel Pants |
He actually had new inlet rings machined at 6" I believe. I talked to him at Airventure and told me about some of his adventures with the James cowl. He had some extras machined so I bought a set from him.
Michael
Posted: Tue Feb 14, 2012 9:43 am Post subject: Wheel Pants |
I purchased a pair too but have decided to go a different route.
Robin
Posted: Tue Feb 14, 2012 3:18 pm Post subject: Wheel Pants |
I talked with Alan Bikle today. He never got enough interest in his
wheel pants to produce them.
David Maib
RV-10 #40559
Transition Trainer
year.
Alan Bikle
AIRFLOW TECHNOLOGY
Salinas, CA. 93905
Tel: 831-320-0193
Robin
n223rv(at)wolflakeairport Guest
Posted: Tue Feb 14, 2012 4:20 pm Post subject: Wheel Pants |
Just curious, what's wrong with the stock ones? I have an early kit and they are very well made and fit fairly good with little work.....
-Mike Kraus
RV-10 Flying
On Feb 14, 2012, at 6:16 PM, David Maib <dmaib(at)mac.com> wrote:
I talked with Alan Bikle today. He never got enough interest in his wheel pants to produce them.
David Maib
RV-10 #40559
Transition Trainer
> Alan Bikle
> AIRFLOW TECHNOLOGY
> Salinas, CA. 93905
> Tel: 831-320-0193
> Robin
> Do Not Archive
Posted: Tue Feb 14, 2012 5:08 pm Post subject: Wheel Pants |
The stock ones are fine, but I was never too happy with the job I did
on mine. Now that they are showing some wear and tear, I was just
curious if there were any other options out there that I might like
better. Apparently not, so I will repair mine and move on.
David Maib
RV-10 #40559
Transition Trainer
On Feb 14, 2012, at 7:19 PM, Michael Kraus wrote:
<n223rv(at)wolflakeairport.net>
work.....
-Mike Kraus
RV-10 Flying
> David Maib
> RV-10 #40559
> Transition Trainer
>> have seen.
>> year.
>> Alan Bikle
>> AIRFLOW TECHNOLOGY
>> Salinas, CA. 93905
>> Tel: 831-320-0193
>> Robin
>> Do Not Archive
ScooterF15
Posted: Sat Feb 25, 2012 8:26 am Post subject: Wheel pants |
Thanks to some much needed ribbing from Bob Condrey, after 5+ years of flying, I finally installed the wheel pants. I’ve been putting it off so long, I started to develop a fear of the job… someone told me it was worse than doing the doors (which I consider the most painful job of the whole project)… the wheel pants weren’t that bad, but still not much fun in a sub-freezing hangar.
I flew the plane yesterday and what a difference! I had 125 KIAS off the runway before I realized I needed to raise the nose a bit higher than I’m used to. I managed to climb easily at 115 KIAS (this would almost zero out my climb rate with no wheel pants). I leveled at 9500 MSL and trimmed out to 166 KTAS, lean of peak at 10 GPH. I then turned West and (literally) popped up to 10500 MSL, where the plane trimmed to 165. That is a 15 to 16 knot gain in true cruising speed.
The plane also felt smoother and quieter.
I’ll see if this has helped fix my engine cooling problems as the weather warms up, but from a qualitative point of view the wheel pants seems to make a big difference in CHT and oil temps in climb.
-Jim
N312JE
bcondrey
Posted: Sat Feb 25, 2012 9:49 am Post subject: Re: Wheel Pants |
Not sure "ribbing" would be the right word, maybe just strong encouragement...
Glad you got it done - it really is hard to believe how much of a difference it makes!
Bob
sfarner
Posted: Sat Feb 25, 2012 10:07 am Post subject: Wheel pants |
As a "newbie," I've been told that the doors are really tough, as is the instrument installation.
I was hoping someone would tell me it gets easier after the elevators, but I'm guessing that won't happen!
Steve
From: owner-rv10-list-server(at)matronics.com [owner-rv10-list-server(at)matronics.com] On Behalf Of James McGrew [jsmcgrew(at)alum.mit.edu]
Sent: Saturday, February 25, 2012 10:22 AM
Subject: Wheel pants
-Jim
N312JE
tp://forums.matronics.com
Rv10flyer(at)verizon.net Guest
Posted: Sat Feb 25, 2012 11:32 am Post subject: Wheel pants |
The pants add the extra speed you mentioned and drag reduction. I can tell you from recent SoCal temps that yes the CHT WILL go down as the engine gets more air but also less resistance.
On Feb 25, 2012, at 8:22 AM, "James McGrew" <jsmcgrew(at)alum.mit.edu (jsmcgrew(at)alum.mit.edu)> wrote:
[quote] <![endif]--> <![endif]-->
-Jim
N312JE
cs.com
matronics.com/contribution
rene(at)felker.com Guest
Posted: Sat Feb 25, 2012 12:56 pm Post subject: Wheel pants |
Yes, i thought it got easier.....faster also.
Sent from my Verizon Wireless 4G LTE DROID
-----Original message-----
[quote]From: Steve Farner <steve.farner(at)bellevue.edu>
To: "rv10-list(at)matronics.com" <rv10-list(at)matronics.com>
Sent: Sat, Feb 25, 2012 11:02:20 MST
Subject: RE: RV10-List: Wheel pants
(at)font-face { font-family: Calibri; } (at)page WordSection1 {margin: 1.0in 1.0in 1.0in 1.0in; } P.MsoNormal { FONT-SIZE: 11pt; MARGIN: 0in 0in 0pt; FONT-FAMILY: "Calibri","sans-serif" } LI.MsoNormal { FONT-SIZE: 11pt; MARGIN: 0in 0in 0pt; FONT-FAMILY: "Calibri","sans-serif" } DIV.MsoNormal { FONT-SIZE: 11pt; MARGIN: 0in 0in 0pt; FONT-FAMILY: "Calibri","sans-serif" } A:link { COLOR: blue; TEXT-DECORATION: underline } SPAN.MsoHyperlink { COLOR: blue; TEXT-DECORATION: underline } A:visited { COLOR: purple; TEXT-DECORATION: underline } SPAN.MsoHyperlinkFollowed { COLOR: purple; TEXT-DECORATION: underline } SPAN.EmailStyle17 { COLOR: windowtext; FONT-FAMILY: "Calibri","sans-serif" } .MsoChpDefault { FONT-FAMILY: "Calibri","sans-serif" } DIV.WordSection1 { } As a "newbie," I've been told that the doors are really tough, as is the instrument installation.
Steve
Subject: RV10-List: Wheel pants
-Jim
N312JE
Bob Turner
Posted: Sat Feb 25, 2012 3:41 pm Post subject: Re: Wheel Pants |
"As a "newbie," I've been told that the doors are really tough, as is the instrument installation. "
It's all in the eye of the beholder. Most -10 builders are "metal guys" so the other stuff seems harder. I've spent my life in and around electronics so I thought the avionics was absolutely straightforward. The key, as with most things, is to spend 3 times as much time thinking about it as doing it!
_________________ Bob Turner
RV-10 QB |
Posted: Sat Feb 25, 2012 9:25 pm Post subject: Wheel pants |
It gets easier after the first condition inspection.
Robin
Sent from my iPad2.
On Feb 25, 2012, at 4:09 PM, "rene(at)felker.com (rene(at)felker.com)" <rene(at)felker.com (rene(at)felker.com)> wrote:
[quote] Yes, i thought it got easier.....faster also.
[quote] From: Steve Farner <steve.farner(at)bellevue.edu (steve.farner(at)bellevue.edu)>
To: "rv10-list(at)matronics.com (rv10-list(at)matronics.com)" <rv10-list(at)matronics.com (rv10-list(at)matronics.com)>
Steve
From: owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com) [owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com)] On Behalf Of James McGrew [jsmcgrew(at)alum.mit.edu (jsmcgrew(at)alum.mit.edu)]
To: (rv10-list(at)matronics.com)rv10-list(at)matronics.com (rv10-list(at)matronics.com)
-Jim
N312JE
Strasnuts
Joined: 10 Feb 2009 Posts: 502 Location: Salt Lake City, UT
Posted: Sat Feb 25, 2012 10:27 pm Post subject: Wheel pants |
I concur.
On Feb 25, 2012, at 21:23, Robin Marks <robin(at)PaintTheWeb.com (robin(at)PaintTheWeb.com)> wrote:
[quote] It gets easier after the first condition inspection.
Robin
Sent from my iPad2.
| Quote: | Yes, i thought it got easier.....faster also.
| Quote: | From: Steve Farner <steve.farner(at)bellevue.edu (steve.farner(at)bellevue.edu)>
Subject: RE: Wheel pants
Steve
-Jim
N312JE
| )��ߢ{l�7�r�h�M4�Miǜ���z����.�'�N�W] ��D�����K��j��',.+-æºï¿½ï¿½5�â�«h����,z�^���.+-�إ�؞�˜�� ��T��n�+��b�p+r�y'���C� å¡§{ ����,x(Z�P>-��Z��vk��k��j+y�ky�m���� &j��',r��5�â�«h�u�m���� ���'���o�j��j�+E]t.+-��M� $�NECI�������'���j[(j�����z����y�h��j�~m��ߢ���f����r�(�m��ߢ���f����r�(�����B�{k������y�����jy2���*.��z�.�˩���1�m�������)چ����i��0�f����r�(��(���n�b�xm���� &j��',r��r��&�*'�����'��k{��w/�i
| ky���"�휢Z+�M4�G�q�(����w�r����Ӆ�U�B��&j)E���RÇ����'����Ey�n�� j�j�+�����j|���n�)b�'���!j���'�+����ب� ܆+�I�r��yhi��k k� ���h��y�ݚ�!��!���j�~m���� ���'���o�j�j�+E]t.+-��i��0�f����r�(��Z�(���W]��h�D�H %�S�PÄ’jg���r��z{Z�����i�^�&���lZ+�k�����i���鬙�k�x���&��i���鬙�k�x���&�����n�b�u�m(�y8Z�L���+ʋ���ޮ����i��Lj�C��ex���f�v������0��k�x���&��'����ب�m���� ���'���oÜ¢{k������k��~��������m�
_________________ 40936
RV-10 SB N801VR Flying
780 Hours
SuperSTOL 60 hours |
