andynfultz(at)bellsouth.n Guest
Posted: Mon Oct 31, 2011 5:51 pm Post subject: Thermostat ? |
[quote] Anybody know where I can get a replacement thermostat for my STRATUS EA-81 engine. I don't think mine is functioning properly. It seems to be sticking open for a while and as of late I think it's sticking closed. Can't seem to make up its mind what it wants to do. Sometimes it will function somewhat properly. Today on a short flight I could tell it was working as it should then toward the end of the flight it stuck closed again. Thanks.
Andy
| - The Matronics Stratus-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?Stratus-List |
billvt1(at)gmail.com Guest
Posted: Tue Nov 01, 2011 4:46 am Post subject: Thermostat ? |
Posted: Tue Nov 01, 2011 7:58 pm Post subject: Thermostat ? |
billvt1,
I got no body to your reply. Try it again Please.
Andy
tshankland(at)sbcglobal.n Guest
Posted: Thu Nov 03, 2011 6:24 am Post subject: Thermostat ? |
Andy,
Here is something you might want to consider. I too have notices times when my temperature reads above 200, it usually is at about 190. I had concern that something was amiss in my cooling system. I measured the temperature both with an inferred sensor and a thermocouple on the engine when I returned from a flight. I was never able to get a reading as high as shown on the gage. I then noticed if the engine was off the reading declined about 10 degrees. What I have determined is that there is a voltage sensitivity in the VDO meters, higher voltage higher reading. Thus after flying a while and the batteries get fully charged the voltage tents to rise, along with the temperature. I'm going to put together a small circuit to clamp the voltage going to the water and oil temperature at 12 to 12.5 volts and then see what happens. I probably will get it done and in the air this week or next and then see what happens.
TIm Shankland
Andy Fultz wrote: [quote] (at)font-face { font-family: Calibri; } (at)page WordSection1 {size: 8.5in 11.0in; margin: 1.0in 1.0in 1.0in 1.0in; } P.MsoNormal { FONT-SIZE: 11pt; MARGIN: 0in 0in 0pt; COLOR: windowtext; FONT-FAMILY: "Calibri","sans-serif" } LI.MsoNormal { FONT-SIZE: 11pt; MARGIN: 0in 0in 0pt; COLOR: windowtext; FONT-FAMILY: "Calibri","sans-serif" } DIV.MsoNormal { FONT-SIZE: 11pt; MARGIN: 0in 0in 0pt; COLOR: windowtext; FONT-FAMILY: "Calibri","sans-serif" } A:link { COLOR: blue; TEXT-DECORATION: underline; mso-style-priority: 99 } SPAN.MsoHyperlink { COLOR: blue; TEXT-DECORATION: underline; mso-style-priority: 99 } A:visited { COLOR: purple; TEXT-DECORATION: underline; mso-style-priority: 99 } SPAN.MsoHyperlinkFollowed { COLOR: purple; TEXT-DECORATION: underline; mso-style-priority: 99 } P { FONT-SIZE: 12pt; MARGIN-LEFT: 0in; COLOR: #000066; MARGIN-RIGHT: 0in; FONT-FAMILY: "Times New Roman","serif"; mso-style-priority: 99; mso-margin-top-alt: auto; mso-margin-bottom-alt: auto } SPAN.EmailStyle17 { COLOR: windowtext; FONT-FAMILY: "Calibri","sans-serif"; mso-style-type: personal-compose } .MsoChpDefault { FONT-FAMILY: "Calibri","sans-serif"; mso-style-type: export-only } DIV.WordSection1 { page: WordSection1 } <![endif]--> <![endif]-->
Quote: | Anybody know where I can get a replacement thermostat for my STRATUS EA-81 engine. I don't think mine is functioning properly. It seems to be sticking open for a while and as of late I think it's sticking closed. Can't seem to make up its mind what it wants to do. Sometimes it will function somewhat properly. Today on a short flight I could tell it was working as it should then toward the end of the flight it stuck closed again. Thanks.
Andy
| [b]
Posted: Thu Nov 03, 2011 5:58 pm Post subject: Thermostat ? |
Hey Tim, I'm using digital guages and haven't noticed the behaviour you have. I think my thermostat is just not opening and closing as it should.
Andy
[quote] --
Posted: Fri Nov 04, 2011 5:15 am Post subject: Thermostat ? |
Andy,
If you are using digital gages you are probably not affected by voltage variations, digital circuit will have their own internal voltage regulation.
Andy Fultz wrote: [quote] Hey Tim, I'm using digital guages and haven't noticed the behaviour you have. I think my thermostat is just not opening and closing as it should.
Andy
[quote] --
