Dick Sipp
Posted: Fri May 19, 2006 7:24 pm Post subject: What fuel pressure should I see for electric or engine fuel |
The Ops Manual I have lists:
inlet to fuel pump min -2 max 35
inlet to fuel injector min 14 max 45 min at idle 12
I think you should see something like 25 psi or so in normal operation.
AirFlow Perfomance recommends a boost pump setting a few psi higher than the
engine pump pressure to verify its operation on the fuel pressure gauge.
It sounds like you may have a gauge or pressure sensor for a carbureted
engine.
Dick Sipp
40065
