rjdaugh(at)rapidnet.com Guest
Posted: Mon May 15, 2006 7:27 am Post subject: Hanger door cost and brain-based inflation |
You guys are right. I had to dig out my records, but the cost was more like
$1400.
The kit was $797. the skin - translucent fiberglass - was $329, a winch was
$97, and another $120 for wood.
My apologies to all and especially to the Ultimate door people. It is a
great door.
Randy
wingnut
Posted: Mon May 15, 2006 8:46 am Post subject: Re: Hanger door cost and brain-based inflation |
That's more like it . I'd like to bounce a few more questions off you if I may:
Would you say that the $800 for the kit is a good investment? Is there anything included in it that would be difficult to fabricate from scratch?
What is the purpose of the pronounced dip at the end of the overhead track? Could the door be build with a flat track like they use for garage doors?
Does the door use a counterweight or some kind of spring to help lift it?
Luis R
$1400.
great door.
Randy
DPREMGOOD(at)AOL.COM Guest
Posted: Mon May 15, 2006 9:17 am Post subject: Hanger door cost and brain-based inflation |
Randy,
Do you have an idea of how much the door weighs?
Doug Remoundos
Posted: Mon May 15, 2006 10:13 am Post subject: Hanger door cost and brain-based inflation |
Luis,
I am happy to try to answer your questions. See below. Indented.
Randy
lcfitt(at)sbcglobal.net Guest
asq1(at)adelphia.net Guest
Posted: Mon May 15, 2006 11:55 am Post subject: Hanger door cost and brain-based inflation |
FWIIW, I built an Ultimate Door about 15 yrs ago. I used their plans and
fabricated my own metal.
The top tracks are just standard garage door tracks with 10" cut off the
curved end and welded back in near the middle of the track as per UD plans.
A friend did the welding with a MIG. Didn't take long. I found an individual
who installs doors in our area and bought all the door hardware used
,track,pulleys brackets,etc.
We have a local Mennonite friend who sells metal siding and such for a
very reasonable price. I bought all translucent sheets to cover the door.
They are very light.The door faces East. In the AM it heats up in a hurry
and besides I don't have to have any lights on to work inside.
I built mine such that I the outside slopes down just slightly When it is
raised so the rain runs off when it is up so if I want more area to work in
I open the door for an extra 6" of roof.
They call for 1/8" cables to cross in each panel ,,as I remember. I live
on a farm and use hi-tensile fence. I used this wire and nicropressed it
onto the brackets and turnbuckles. It is at least as strong in this
configuration and the wire is 2-3 cents per foot.
I didn't use a winch. I found a (30" ? probably weighs 40-50# )flywheel
off some old hand crank farm machine and made a small drum for a winch. (You
need something for a bit of weight to smooth out the cranking)It takes 18
turns to raise a 12" door( remember in reality you are only raising it 6',
you are lifting from the center.) My wife can crank it up with one hand. I
think the door came out at about 400# and I used a 280#? counterweight.
Counterweight works fine ,but I like the sound of the concrete weights
better. I would do that next time.
I have a fairly complicated pulley system above. Another time I would use
a 2" pipe all the way across at the top of the door riding in lubricated oak
blocks.
Remember, This was 15 yrs ago,but I have less than $500 in the whole door
and I use it a lot. It is an excellent unit.
Larry Huntley
Posted: Mon May 15, 2006 6:37 pm Post subject: Hanger door cost and brain-based inflation |
Doug,
I think my counter balance weight is 160 lbs and the door has 210 lbs with
the counter balance weight in place. This makes the door 370 lbs.
I can't find any notes on this so I hope it is more accurate than my cost
data was.
Randy
Thanks Lowell. I fly from a strip on my ranch. We are about 4 - 5 miles
north of Mount Rushmore in the Black Hills of South Dakota. With Crazy
Horse, Devils Tower and the Badlands all close by, this is a great place to
fly.
I am trying to break my tether, but so far have stayed in a 150 mile radius.
Hoping to visit Longmont, Colorado, Sioux Center, Iowa, and Bozeman,
Montana this summer. I would sure like to make it to Cameron Park, but my
wife and I are still stretching our wings.....
Randy
jhartford(at)hartford-eng Guest
Posted: Tue May 16, 2006 4:00 am Post subject: Hanger door cost and brain-based inflation |
Randy Good to hear from someone in the Dakota's. I am building a Model
II In Dickinson ND. If you get up this way give me a call. 701-290-9051.
Jim Hartford
Posted: Tue May 16, 2006 7:49 pm Post subject: Hanger door cost and brain-based inflation |
Jim,
Jared Schott is flying a fox from his ranch in north Central South Dakota
near Timber Lake. I have been threatening to go visit him. May make it
someday.
Randy
Posted: Wed May 17, 2006 4:41 am Post subject: Hanger door cost and brain-based inflation |
Randy When I finally get my Fox in the air I will try to make a trip to
SD. Work seems to slow progress. I will get a month or two at a time
then have to head back to work and it might be months before I get back
to the plane.
Jim
