raymondj(at)frontiernet.n Guest
Posted: Tue Jul 12, 2011 2:41 pm Post subject: Removing Label Machine Generated Labels from Instrument Pan |
I'm surprised at how tenacious your labels are. The only thing I might
suggest is something like Un-Do or similar label/price tag remover,
although I have my doubts. Good luck. Please post if you find something
that works.
Raymond Julian
Kettle River, MN
"And you know that I could have me a million more friends,
and all I'd have to lose is my point of view." - John Prine
On 07/12/2011 05:07 PM, Jim Crowder wrote:
| Quote: | I am redoing my instrument panel and need to remove the printed tape
labels generated by a label machine. I have tried WD40, alcohol, lacquer
thinner, and a heat gunsetas hot as I have so far daredto apply. None of
this has worked so far.The labels havebeen in place about five years and
seem to defy non destructiveremoval. A fingernail doesn’t work either.
Help needed--any suggestions?
Jim Crowder
| | - The Matronics Jabiru-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?Jabiru-List |
Posted: Wed Jul 13, 2011 6:32 pm Post subject: Removing Label Machine Generated Labels from Instrument Pan |
I'm assuming it is trichloroethane. I'm not surprised that it did the
job. What did it do to the finish on your panel?
Raymond Julian
Kettle River, MN
On 07/13/2011 03:05 AM, James, Clive R wrote:
| Quote: | Brake Cleaner?
From: owner-jabiru-list-server(at)matronics.com on behalf of Jim Crowder
Sent: Tue 12/07/2011 23:07
To: Jabiru List
Subject: Removing Label Machine Generated Labels from Instrument Panel
I am redoing my instrument panel and need to remove the printed tape labels generated by a label machine. I have tried WD40, alcohol, lacquer thinner, and a heat gun set as hot as I have so far dared to apply. None of this has worked so far. The labels have been in place about five years and seem to defy non destructive removal. A fingernail doesn't work either. Help needed--any suggestions?
Jim Crowder
Clive J
Posted: Tue Jul 19, 2011 5:34 am Post subject: Removing Label Machine Generated Labels from Instrument Pan |
You do need to have a substantial paint job when using it....
I use it for loads of stuff, always have a tin handy for degreasing but as you say it does melt stuff...
Regards, Clive
From: owner-jabiru-list-server(at)matronics.com on behalf of rayj
Sent: Thu 14/07/2011 03:29
To: jabiru-list(at)matronics.com
Subject: Re: Removing Label Machine Generated Labels from Instrument Panel
Raymond Julian
Kettle River, MN
To: Jabiru List
Jim Crowder
