9xx banjo fitting
kevann(at)gotsky.com
PostPosted: Fri Nov 12, 2010 9:09 am    Post subject: 9xx banjo fitting Reply with quote
Hi Folks,
I have a 914 in a Europa. The route of the oil line from the bottom of the engine banjo fitting (push on barb style) to the oil tank goes above the exhaust. I made a heat shield from some stainless sheet and this works pretty well, but puts a little pressure on the oil line (teflon with SS braid)
If the banjo fitting angled down a little I could run the line below, which would be preferable. Less heat and pressure on the oil line from contact with the exhaust pipe.
Anyone know of a source for a banjo fitting with an angle that would fit this application? I don't think I want to go to the AN type banjo fitting because I can't use AN on the old style oil tank I have. Or is there an adaptor for that?
Thanks, Kevin
h&jeuropa
PostPosted: Sat Nov 13, 2010 5:22 am    Post subject: Re: 9xx banjo fitting Reply with quote
Kevin,
Have a look at Rotax SI-914-005 R2. There you will find on page 7 a drawing of Rotax part # 956050 which is an AN8 fitting with an 8 deg angle.
Hope this helps.
Jim & Heather
N241BW
PostPosted: Sat Nov 13, 2010 6:55 am    Post subject: 9xx banjo fitting Reply with quote
Hi Jim & Heather,
I have seen the Rotax AN8 banjo fitting. But without buying a new style oil
tank with AN fittings, I would not have AN on both ends of the hose.
My question was about finding a barb style banjo with an angle.
Kevin
Kevin,
angle.
Hope this helps.
Jim & Heather
N241BW
l_luv2_fly(at)yahoo.com
PostPosted: Sat Nov 13, 2010 7:30 am    Post subject: 9xx banjo fitting Reply with quote
Kevin,
I TIG welded a couple of 8 AN - 1/2" Tube steel braze fitting adapters to the two barb fittings on top of the oil tank and effectively converted it to tank with AN fittings.
The only 'messing around' part was that I had to bore the adapter so that the oil tank barb fitting would slide inside so it could be welded.
The fittings came from Pegasus Auto racing and the part number was 3259-08 (at) $4.00
If I can find them I'll send you some photographs.
Paul
To: rotaxengines-list(at)matronics.com
Sent: Sat, November 13, 2010 8:53:08 AM
Subject: Re: Re: 9xx banjo fitting
--> RotaxEngines-List message posted by: "Kevin Klinefelter" <kevann(at)gotsky.com (kevann(at)gotsky.com)>
Hi Jim & Heather,
Kevin
