Stratus-List Digest: 5 Msgs - 10/14/10
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Stratus-List
Billvt
PostPosted: Fri Oct 15, 2010 4:00 am    Post subject: Stratus-List Digest: 5 Msgs - 10/14/10 Reply with quote
Tim,
If you go to my web page
http://homepages.together.net/~billvt/
under construction, engine mount crack, you will see photos of the failure of my engine mount.
I had mine repaired and reinforced as Larry said and I now have over 600 hours on the repaired mount with no further issues.
Bill - N812BM - HDS - Stratus
- The Matronics Stratus-List Email Forum -
http://www.matronics.com/Navigator?Stratus-List
tshankland(at)sbcglobal.n
PostPosted: Fri Oct 15, 2010 5:24 am    Post subject: Stratus-List Digest: 5 Msgs - 10/14/10 Reply with quote
Bill,
Your crack is very similar to mine, I believe we have someone in my EAA chapter that is a good welder, I would weld it myself but I not sure I trust myself well enough.
Bill Morelli wrote: [quote] [quote]--> Stratus-List message posted by: Bill Morelli <billvt(at)together.net> (billvt(at)together.net) Tim, If you go to my web page http://homepages.together.net/~billvt/ under construction, engine mount crack, you will see photos of the failure of my engine mount. I had mine repaired and reinforced as Larry said and I now have over 600 hours on the repaired mount with no further issues. Regards, Bill - N812BM - HDS - Stratus --
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Stratus-List All times are GMT - 8 Hours
