sarg314(at)comcast.net Guest
Posted: Wed Jan 11, 2006 5:10 pm Post subject: control cables and engine movement |
While figuring out how to route my control cables for throttle and
mixture, it occurs to me that the engine can rotate quite a bit when it
starts and stops. There is only going to be 3 or 4 inches of cable
between the firewall, where it is firmly gripped, and the notch in the
cable sheath where it is also firmly gripped. Engine movement could put
a lot of tension on the cable.
Is this something I should worry about?
Should I be allowing for some "slack" in the cable between the firewall
and the attach point? It doesn't seem that's very easy to do.
Tom Sargent, RV-6A, engine
| - The Matronics RV-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
