Idle mixture
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Engines-List
grantn
PostPosted: Tue Aug 03, 2010 9:26 pm    Post subject: Idle mixture Reply with quote
Can anyone out there tell me which way the idle mixture set screw should be turned for leaning the Precision Airmotive carburetor on my O-320 engine? counterclockwise or clockwise? I'm assuming there is a standard direction for these carbs. I can't give you a serial number at the moment, and the meager documentation that came with the beast isn't explicit on the subject - it just advises to lean until the RPM rise is 25 to 50 when leaning to cutoff. Thanks for any help on this.
Grant Neilson
RV9A C-GGNX
177 hours flying
- The Matronics Engines-List Email Forum -
http://www.matronics.com/Navigator?Engines-List
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Engines-List All times are GMT - 8 Hours
