Rotax 582 oil leak
Ken Potter
PostPosted: Mon Jun 21, 2010 2:41 am    Post subject: Rotax 582 oil leak Reply with quote
Hi Folks,
I have my Rotax 582 running fairly smoothly at this point. I have an oil leak though. There is a black, tarry like substance on the exhaust side of the engine which appears to be coming from the casing somewhere, maybe between the cylinders. Does anyone have an idea of what this is and where it could be coming from. The engine is new but was upgraded in 2003 by a rotax dealer. The previous owner said it had preservative oil on the internal parts. Could this be some kind of preservative leaking.
Cheers
Ken
Ken Potter
Model II, No. 483
Rotax 582, C-Box,
99% Complete
C-FJKP
Lanark, Ontario
thesupe(at)hotmail.com
PostPosted: Mon Jun 21, 2010 4:55 am    Post subject: Rotax 582 oil leak Reply with quote
Sounds like a leaking exhaust manifold to me.  I've seen the same thing on my 582 when I had one.  Engine was also running rich at the time.  Take care,  Jim Chuk  Avids, kitfox 4  (building)  Mn
Subject: Rotax 582 oil leak
Date: Mon, 21 Jun 2010 03:41:18 -0700
--> Kitfox-List message posted by: "Ken Potter" <kjpotter(at)sympatico.ca>
Hi Folks,
Cheers
Ken
Ken Potter
Model II, No. 483
Rotax 582, C-Box,
99% Complete
C-FJKP
Lanark, Ontario
http://forums.matronics.com/viewtopic.php?p=301891#301891
Hotmail has tools for the New Busy. Search, chat and e-mail from your inbox. Learn more.
Ken Potter
PostPosted: Tue Jun 22, 2010 7:51 am    Post subject: Re: Rotax 582 oil leak Reply with quote
Thanks Jim, right on both points. I was running a bit rich for break. I tightened the exhaust manifold bolts. They were surprisingly loose. I degreased the engine and ran it up for 1/2 hour at 5000 rpm. No leak.
Cheers
Ken
Ken Potter
Model II, No. 483
Rotax 582, C-Box,
99% Complete
C-FJKP
Lanark, Ontario
