horizontal stab
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> MurphyMoose-List
HBaker
PostPosted: Sun Mar 28, 2010 11:15 am    Post subject: horizontal stab Reply with quote
Hi Guys
Getting ready for paint, and trying to figure out if I can install the horizontal stab and elevator after riveting the fiber glass fairing , it doesn't look like it . Any suggestions on this? It will be hard to paint separately . If I install the horizontal stab then I cannot get it out of the garage.
Henry
- The Matronics MurphyMoose-List Email Forum -
http://www.matronics.com/Navigator?MurphyMoose-List
Currently building a Murphy Moose - any help would be appreciated.
westcoastkitplanes(at)gma
PostPosted: Sun Mar 28, 2010 4:10 pm    Post subject: horizontal stab Reply with quote
Henry,
Cut the fiberglass fairing so the horizontal stab and vertical stab pieces are separate for installation.  You could rivet the vertical stab fairing in place, but I would use screws to install the horizontal stab fairing pieces in place; you'll have to remove these pieces at a later date for inspection anyways.  Doing it this way will allow you to install elevator and stab.
Cheers,
Jeff
On Sun, Mar 28, 2010 at 12:15 PM, HBaker <henry.baker(at)nf.sympatico.ca (henry.baker(at)nf.sympatico.ca)> wrote:
[quote] --> MurphyMoose-List message posted by: "HBaker" <henry.baker(at)nf.sympatico.ca (henry.baker(at)nf.sympatico.ca)>
Hi Guys
Henry
http://forums.matronics.com/viewtopic.php?p=292097#292097
List" target="_blank">http://www.matronics.com/Navigator?MurphyMoose-List
le, List Admin.
HBaker
PostPosted: Sun Mar 28, 2010 5:41 pm    Post subject: Re: horizontal stab Reply with quote
Not real clear on what you are saying, do I put screws in the whole fairing , Or cut the fairing some where???
PostPosted: Sun Mar 28, 2010 10:29 pm    Post subject: horizontal stab Reply with quote
Henry,
You have to cut the fairings. I'll see if I can get a picture to you tomorrow or within a day or two.
cheers,
Jeff
On Sun, Mar 28, 2010 at 6:41 PM, HBaker <henry.baker(at)nf.sympatico.ca (henry.baker(at)nf.sympatico.ca)> wrote:
[quote]--> MurphyMoose-List message posted by: "HBaker" <henry.baker(at)nf.sympatico.ca (henry.baker(at)nf.sympatico.ca)>
http://forums.matronics.com/viewtopic.php?p=292154#292154
le, List Admin.
HBaker
PostPosted: Mon Mar 29, 2010 1:39 am    Post subject: Re: horizontal stab Reply with quote
I think we are talking about different fairings , I was talking about the one you get in two pieces and have to join with fiberglass it attaches to the fuselage and the vertical fin, I did not receive any for the ends of the horizontal stab .
Henry
PostPosted: Mon Mar 29, 2010 8:51 am    Post subject: horizontal stab Reply with quote
Henry,
I was referring to the main fairing (V & H Stab), yes you get it in two halves and have to put it together. But for the ease of doing inspections/maintenance put a cut line in the fairing; separating the V stab from the H stab.
I am not referring to the fiberglass tips on the stab, those should be a no brainer.
My offer to provide you with a picture of the main stab fairing installation is still open........ If we're on the same page.
Cheers,
Jeff
On Mon, Mar 29, 2010 at 2:39 AM, HBaker <henry.baker(at)nf.sympatico.ca (henry.baker(at)nf.sympatico.ca)> wrote:
Henry
http://forums.matronics.com/viewtopic.php?p=292177#292177
as List Un/Subscription,
www.matronics.com/Navigator?MurphyMoose-List" target="_blank">http://www.matronics.com/Navigator?MurphyMoose-List
ronics.com/" target="_blank">http://forums.matronics.com
Matt Dralle, List Admin.
HBaker
PostPosted: Mon Mar 29, 2010 12:19 pm    Post subject: Re: horizontal stab Reply with quote
I'll take you up on the picture , if you can get one, it certainly would be appreciated , and is there fairings for the ends of the horizontal stab and elevator as well ???
HBaker
PostPosted: Tue Apr 06, 2010 4:42 am    Post subject: Re: horizontal stab Reply with quote
Jeff I have the one on the leading edge of the horizontal stab.
bill(at)kidzploration.com
PostPosted: Tue Apr 06, 2010 8:45 am    Post subject: horizontal stab Reply with quote
I found these guys to be very active and very helpfulrebel-builders(at)dcsol.com (rebel-builders(at)dcsol.com)
You can sign up on the Merphy sight
its at the bottom of one of the pages, don't remember which one
but its easy to find
cheers Bill
On Tue, Apr 6, 2010 at 8:42 AM, HBaker <henry.baker(at)nf.sympatico.ca (henry.baker(at)nf.sympatico.ca)> wrote:
http://forums.matronics.com/viewtopic.php?p=293167#293167
le, List Admin.
HBaker
PostPosted: Wed Apr 07, 2010 9:26 am    Post subject: Re: horizontal stab Reply with quote
Thanks Bill
I'll try to get hold of them.
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> MurphyMoose-List All times are GMT - 8 Hours
