Speedy11(at)aol.com Guest
Posted: Mon Apr 05, 2010 7:48 pm Post subject: Princeton 18-5B-5S Fuel Senders Won't Calibrate |
Matt,
That is exactly what I advised you about months ago. The Princeton probes do not calibrate properly.
I've filled and drained my tanks seven times. They still will not calibrate. I recommend builders use anything other than Princeton probes. And try to get them on the phone to talk about it. Good luck with that.
Mine are also prosealed in. Still, I'm tempted to rip them out and throw them in the trash and replace them with floats.
What I'm doing now is gradually calibrating the fuel flow transducer to get it as accurate as possible and then I'll simply keep track of how much has been burned or how much is remaining. Since I used a both selection on my fuel selector, it is easier for me to know about how much remains in the tanks. It will be a little more challenging for you since you'll be switching left and right.
I've recommended for the past year that nobody buy the Princeton probes - and I still recommend against them.
Stan Sutterfield
| Quote: | I installed Princeton 18-5B-5S Fuel Senders in the left and right fuel tanks with
Proseal (see attached). Last week I installed the wings permanently and today
I torqued all of the fuel lines from the wings to the fuselage. I got 21
gallons in 5.25 gallon increments ready to calibrate the 5-set point Princeton
probes today. They both powered up fine and started flashing the left light
indicating the Empty set point. I pushed the button once per the calibration
instructions to go to the 1/4 level. Instead of getting the #2 led flashing,
I get the all three LEDs flashing sequence indicating that probe "Can't be calibrated"!!!
From the installation manual: CAL Error (three flashing LEDs) - The probe failed
to calibrate. Possible causes: water in the tank (NO), inner brass rod is
shorted to the outside aluminum tube (PROBABLY), Alcohol in the fuel (NO), trying
to calibrate full first instead of empty (NO), or the probe electronics have
failed (MAYBE)." Yeah, you read all that right.
The best part of this story is that I Prosealed these babies in, installed the
wings, and now discover that both probes are defective or what even. How can
this fricken be? Its too late in the game for this. Replacing these stupid probes
is going to be a major pain not to mention the fact that likelihood of leaks
are now going to be high. I just can't believe it. This is so frustrating.
Why didn't the manual advise to check this long before now? Like before
they were installed, during installation, and right after installation before
the Proseal cured?
Oh, did I mention BOTH are bad? How can this be... How disheartening. Please
tell me I'm just mis-reading the calibration instructions...?
I'm going to go out on a limb here and say avoid these piles of garbage... |
| | - The Matronics RV8-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
