Introduction
rsrandazzo(at)precisionma
PostPosted: Mon Apr 10, 2006 10:55 pm    Post subject: Introduction Reply with quote
Fellow Commanders-
I have just joined this list after a recommendation from Twin Commander
Corp. I don't know what the local customs are- so I thought I'd at least
introduce myself!
I have had MSN 12021, a 1973 685 series Commander (N414C) for slightly more
than a year. The airplane is currently based in western Nevada at
Reno-Stead Airport (4SD) and will be in use for a range of business and
private missions.
Although we brought this magnificent airplane here last April, I've only
managed to acquire about 40hrs of time in up to today, as it has spent
almost the entire year in a significant maintenance refit.
At the time we purchased the bird, it was clear that it was going to need
some TLC to get it back up to the level of mechanical integrity that I
demand from an airplane- we found some things buried in the engine
compartments that hinted of some non standard maintenance practices (nylocks
holding the turbo casings in place and safety wire holding the heat shields
to their mounts... (!?!)) but overall the airplane is a fantastic specimen
completely free of corrosion and some of the wear and tear you'd expect on a
32 year old bird.
The right engine was exhibiting some signs of stress- but gave only a few
hints to it's illness in spite of a significant maintenance inspection.
During a test flight in August the engine suffered an uncontained failure
that put the final exclamation point on my concerns about it's health. (to
say the least!) I had the good fortune of gaining some live single engine
experience with the airplane on a clear, windless day while at 16,500' and
directly over the top of my home field.... It doesn't get much better than
that!
Upon removal and inspection- it appears that the engine builder elected to
use a silicone sealant inside the engine case. The sealant came free in
globs and clogged the oil system- causing a complete meltdown in mere
seconds. Fortunately the left engine came from a different and (we think)
more reputable engine shop!
I've flown a number of turbine/turboprop/large piston twins- and I will
swear to the fact that the Commander is the finest flying twin I've ever
driven with an engine shut down. Absolutely predictable, stable and well
mannered. If any of you have never had the opportunity to fly your airplane
single engine down to a landing (I hope you never do) you can rest assured
that if you keep your wits about you and plan your landing thoughtfully -
your airplane will look after you.
We've just received the new engine that is to be hung on N414C- along with
two overhauled props. We've just finished replacing every hose on the
airplane (some dated to date of manufacture...oops...that slipped through
the pre-buy...) and have gutted the entire avionics package to make room for
modern technology.
N414C is expected to fly again in late May/early June with a full new
cockpit setup that is built around a two screen Chelton Flight Systems
Synthetic Vision package. Since we were gutting, we're also installing two
Garmin SL30 Nav/Coms, a full set of electric backup 2 inch
Attitude/Altimeter/Nav gauges, and a PS audio control panel. This cockpit
layout will be a bit unique in that we are putting the navcoms/audio panel
into a center console along with the color radar unit in order to open up
panel space and arrange things more cleanly for pilot use.
We are also adding a Gemini engine monitoring package to the airplane in
order to try and extend engine life as much as possible- and possibly see
any further engine aberrations before the pieces fly out of the cowling...
We are working closely with the great folks at Chelton who are expanding the
STC list for their AP-3C autopilot to include the 685 series commanders
specifically so that we can install the unit on this airplane. We'll likely
have to fly the airplane to Idaho upon completion so that they can
demonstrate the installation to their FISDO in order to complete the STC
approval- but we felt that this was a small price to pay for the improvement
in safety and functionality that would come with the new system. (Aside
from which, when the good old M4 stopped working- it was going to cost as
much to repair is it would to install the new Chelton autopilot....)
No decision on overhauling the cabin or repainting the exterior- but I'm
sure these will come in due time. Looking forward to getting this grand old
bird flying again in fantastic new style.
For those interested- we estimate that approximately 300lbs of weight will
be shed from the airplane before this overhaul is finished....
My only wish for the airplane is that sometime soon- all of us 680/685
owners can get access to an engine that is more dependable than the
GTSIO-520-Ks.... I really haven't had much chance to work with these
engines- but from what I've read they can be a temperamental lot if not
cared for precisely in flight. I'm comfortable with the process- but it
would be nice to have an alternative....
At any rate- that's a long winded introduction- but I'm a great fan of
Commander aircraft- and I'm looking forward to expanding my fund of
knowledge with all of you folks- and hopefully meeting you all one day at a
gathering!
Robert Randazzo
cschuerm(at)cox.net
PostPosted: Tue Apr 11, 2006 2:32 am    Post subject: Introduction Reply with quote
introduce myself!
Welcome Robert. Congrats on the acquisition of "Charlie" - she's a fine
bird!
If you can manage to wade through the 'noise' that has been archived
from this list, you'll likely find that almost every topic related to
Commanders has been discussed over the ages. Lots of great info there,
but feel free to give up trying to find it and just ask questions Smile
There are a couple of true guru's that hang around here and the tribal
knowledge is pretty extensive.
Sorry to hear about your engine trauma. Those K motors are pressed to
the limit and do have a history of breaking in exciting ways that result
in parts becoming located in different locations than specified by the
manufacturer. There have been some attempts to re-engine the 685, but
it doesn't appear that there are any options available at this time.
Sure would be nice if shops would quit using RTV (and my personal pet
peeve - teflon tape) on airplanes.
Sure hope you'll share info and pictures of your new panel - that's an
exciting upgrade and I'm sure you'll love the results!
I'll email you a couple of pictures of your bird off-list that I think
you'll enjoy. (list does not accept email attachments).
cheers,
Chris Schuermann
DO NOT ARCHIVE
n395v
PostPosted: Tue Apr 11, 2006 4:24 am    Post subject: Re: Introduction Reply with quote
Robert,
I owned N414C for about 2 years prior to the sorry SOBs you purchased it from. Had it in pretty pristine condition when I sold it. I hate that my baby was mistreated. I too have several photos I will send you off list.
Wing Commander Gordon (a list participant) who I am sure will pipe in has many hours flying N414C when she was only in her 20s.
You have purchased a fine basic airframe and if you cruise the logs you will find many SBs were performed in preparation for a 135 operation. You will not find many 685s with these mods.
I also suggest you have a knowledgable Twin Commander Mech. Go through the logs and over the plane with a fine tooth comb for other non standard items or deferred maint.
When I sold 414C part of the deal was a trade on a Cessna 414 owned by none other than those who sold you N414C. I had it thouroughly inspected and was prepared for what I had to deal with. I have absolutely no kind words for the folks you bought the plane from..
Enjoy 414C it is a dream to travel in.
Milt
Milt
CloudCraft(at)aol.com
PostPosted: Tue Apr 11, 2006 8:01 am    Post subject: Introduction Reply with quote
In a message dated 10-Apr-06 23:56:14 Pacific Daylight Time,
rsrandazzo(at)precisionmanuals.com writes:
GTSIO-520-Ks....
Welcome, Robert!
It's nice to know where N414C went and that her future is in good hands.
I've been worried about her since she left Milt's stewardship.
I few N414C back in 1997-98. At that time it was owned by Dick MacCoon (MR
RPM) and was targeted to be the conformity airplane for the Orenda engine
project. MR. RPM leased the airplane to McKinley Communications, the prior "host"
of the Twin Commander Flight Group and I was brought on full time to fly her
and run the Flight Group.
The AC-685 is a wonderful airplane; Turbo Commander systems (geeezzzz that's
a lot of Av Gas!, Known Ice and bleed air pressurization) and eerily quiet on
the inside.
The AC-685 was a stroke of marketing genius (opinions vary) in Rockwell's
attempt to have a product between the Shrike and the Turbo Commander. The
GTSIO-520s that produce 385 hp on the Cessna 421 were pressed into service on an
airframe that was used to 717 shp per side.
In order to get some performance, the GTSIO-520-Ks are pushed to 425 hp in
the AC-685 installation and that's a lot of power to extract from 520 cubic
inches.
An alternative engine for this and the "bathtub" nacelle Commanders is a
recurring dream shared by lots of guys on this list. We get our hopes up with
talk of some kind of diesel powered rotary liquid cooled turbocompound perpetual
motion limitless TBO shoebox-sized powerplant from the cover of Popular
Science about every two years.
Uh huh.
Meanwhile, there is a place either in Heaven or the State Mental Hospital for
people like you who upgrade the avionics and care for the airframes of the
Aero Commanders. Keep up the good work!
PS: aside from holding the GTSIO-520 together, finding the Adell clamps that
connects the exhaust to the turbocharger outlet is going to be one of your
favorite Easter Egg Hunts. Also the -520-K is NOT the same engine as what's on
the Cessna 421, so don't expect an ace 421 shop to know anything about your
engine set-up (especially the fuel controlls). DO bring Morris Kernick up to
Stead to train your local A&P if you have one.
Life is not simple anywhere. Probably less so elsewhere.
n395v
PostPosted: Tue Apr 11, 2006 8:32 am    Post subject: Re: Introduction Reply with quote
Engrave the above quote on the aircraft data plate.
Personally inspect the exhaust system before every flight including feeling the areas of the exhaust system that you cannot see for holes and cracks, check all the hardware for tightness frequently.
Also at least every 100 hrs check cylinder head bolt torque.
If the prior owners re engined the airplane or replaced the motor mounts or if you plan on doing so check to see if they areb placed by part number to the drawing. If they are check for engine droop. There should be a little when setting on the ramp. If there isn't consider reversing them so you get a small amount of droop.
Under power the engines rotate up slightly and this stresses the turbo charger inlet system causing cracks and separation as it does to the turbo to exhaust connection causing cracks. These hot gasses inside the nacelle ain't good. I had to terminate 3 flights due to the induction system separating and cancelled 2 trips due to cracked exhaust stacks and burnt components in the nacelle. The folks who bought the plane from me blew a jug out the side most likely due to a loose bolt and had to put down due to an engine fire another time due to ?????
Several of the 1st 685s crashed due to engine fires.
IMHO the positioning of the lord mounts on the factory spec drawings are the reverse of what they should be.
Also ALWAYS personally check that the fuel caps are tightened after every re fuel. Line personell do it incorrectly 80% of the time and the damn caps are $400 each. Do not attempt to solve the problem by re installing the fuel cap chains. TThey invariably get into the anti siphon flap and hold it open resulting in fuel starvation.
Milt
Skyhawkc-172
PostPosted: Tue Apr 11, 2006 10:57 am    Post subject: Introduction Reply with quote
Robert,
Word of caution...when aquiring our commander we searched the aerocommander.com list and were diverted to a man named Morris Kernick for a pre-buy inspection. We don't like to name names, but find it somewhat appropriate being there have been at least one member on this board that is beyond the normal realm of just being upset about his dealings with Morris and ending up with smoked engines and the like. There are also at least one NTSB listing of a nasty firy Commander downing with relation to Morris. I shyed away from him once I found this info and the NTSB findings. Our little way of shedding a little truth to this otherwise non-perfect world...take it like a grain of salt.
We wish you well and are excited to here more on your beautiful bird.
Take care...
twincommanderflyer.com
This is what we found prior to our pre-buy with Morris on a Google search useing Morris Kernicks name.
Office of Inspector GeneralAbout|Contact|Home|Jobs|Privacy
Title:Mechanic Placed on Probation for Lying About Aircraft Inspection
Date:November, 19 2001
Type:Investigation
Summary:Melvin Morris Kernick, of Oakland, CA, was sentenced in U.S. District Court in Oakland, CA for falsely certifying that maintenance he had done on a private plane was reviewed by a certified inspector. Kernick pleaded guilty August 13 to charges of falsely representing that an annual inspection had been performed on a privately owned Aerocommander aircraft, located in Danbury, CT, by signing the name of an FAA certified inspector in the planes logbook. He was sentenced to 3 years supervised probation and ordered to pay $5,870 in restitution.
Related Information: OIG
-------------- Original message --------------
From: "Robert S. Randazzo" <rsrandazzo(at)precisionmanuals.com>
Fellow Commanders-
introduce myself!
private missions.
32 year old bird.
that!
modern technology.
gathering!
Robert Randazzo
Robert,
Word of caution...when aquiring our commander we searched the aerocommander.comlist and were diverted to a man named Morris Kernick for a pre-buy inspection. We don't like to name names, but find it somewhat appropriate being there have been at least one member on this board that is beyond the normal realm of just being upset about his dealings with Morris and ending up with smoked engines and the like. There are also at least one NTSB listing of a nasty firy Commander downing with relation to Morris. I shyed away from him once I found this info and the NTSB findings. Our littleway of shedding a little truth to this otherwise non-perfect world...take it like a grain of salt.
<EM>We wish you well and are excited to here more on your beautiful bird.</EM>
Take care...
<TABLE cellSpacing=0 cellPadding=0 width="100%" summary="" background=/images/button_table_bg.gif border=0>
<IMG alt="DOT Logo" src="http://www.oig.dot.gov/images/dot.gif">
<IMG alt="" src="http://www.oig.dot.gov/images/button_table_bg.gif">
About
Contact
Home
<NOBR>
Jobs</NOBR>
Privacy
Title:
Date:
November, 19 2001
Type:
Investigation
Summary:
<TABLE cellSpacing=0 cellPadding=0 width="100%" summary="" background=/images/button_table_bg2.gif border=0>
From: "Robert S. Randazzo" rsrandazzo(at)precisionmanuals.com
-- Commander-List message posted by: "Robert S. Randazzo"
<RSRANDAZZO(at)PRECISIONMANUALS.COM>
Fellow Commanders-
introduce myself!
private missions.
as it has spent
32 year old bird.
that!
modern technology.
al lot if not
gathering!
Robert Randazzo
Skyhawkc-172
PostPosted: Tue Apr 11, 2006 11:05 am    Post subject: Introduction Reply with quote
One last note...Harry Merrit listed on the AreoCommander site as avtec2(at)bellsouth.net is Morris Kernicks best friend. Just thought you should have a little info prior to going in blind like us and others before us.
Good Luck and Happy skies...
Fellow Commanders-
introduce myself!
private missions.
32 year old bird.
that!
modern technology.
gathering!
Robert Randazzo
<EM>Good Luck and Happy skies...</EM>
Fellow Commanders-
introduce myself!
private missions.
as it has spent
32 year old bird.
that!
modern technology.
al lot if not
gathering!
Robert Randazzo
vinophile(at)yahoo.com
PostPosted: Tue Apr 11, 2006 11:17 am    Post subject: Introduction Reply with quote
Oh Boy, here we go again. Tighten your belts and put
your helmet on...
Robert,
Take care...
name.
Office of Inspector
Aircraft Inspection
Type:Investigation
Randazzo"
> Fellow Commanders-
> introduce myself!
western Nevada at
> private missions.
maintenance refit.
> 32 year old bird.
> that!
> modern technology.
backup 2 inch
pilot use.
so that they can
=== message truncated ===
john(at)vormbaum.com
PostPosted: Tue Apr 11, 2006 11:34 am    Post subject: Introduction Reply with quote
I am very familiar with the crash that happened many years ago; Morris was
essentially threatened in order to force him to sign off & release the
airplane to the owner, even after Morris declared it unsafe to fly. Morris
specifically grounded the airplane, but the owner wouldn't listen. What
would you expect to happen?
Nobody works on my airplane except Morris, and I've had NO issues in 7 years
of flying my 500B that was ONLY maintained by Morris. There are only a
couple of people left alive that know as much about these airplanes as
Morris. I've seen many people burned on Commander purchases. People who get
a pre-buy from Morris and LISTEN to him don't get burned.
There are two sides to every story. Morris can be grumpy, opinionated,
occasionally rude and non-social, but is a wealth of knowledge. The only
people who've dealt with him that have been burned, in my experience
(granted, only 7 years' worth) are people who don't listen to his advice, or
listen and then try to cut corners on maintenance.
Like dealing with doctors, you should always get a 2nd opinion. That's one
of the reasons the list is here. But I think you'd be surprised how many of
the highly praised Commander shops just call Morris when they come upon a
difficult Commander problem.
/J
PostPosted: Tue Apr 11, 2006 1:23 pm    Post subject: Introduction Reply with quote
Milt-
Great stuff! Your post makes me feel even better about owning N414C. I
occasionally wonder if I've not slipped the main bus circuit breaker by
committing such a substantial investment to the rehabilitation of this old
girl- but I'm sure with some care, sound preventative maintenance and good
advice from all of you, I'll prove that my "hunch" here was a good one.
Funny you mention the yahoos I rescued her from. My maintenance guys
(Aviation Classics here at 4SD) have mentioned a couple of dozen times that
N414C "was clearly very well cared for until a couple of years ago- and
she's been receiving lowest bidder maintenance since then."
Some of the things we found were downright illegal- but inexpensive to
correct. Really makes you wonder why they didn't do it right the first
time- but I suppose that's what separates some owners from others.
I weighed for some time picking up a 685/680FLP or a 690- and eventually
settled on the 685 because I'd be able to acquire a decent quality airframe
and invest money to bring the avionics up to new standards- and still have a
nice chunk of change left over for care and feeding. (Feeding is
important!) With a 690, I'd have had to spend all my time sitting in the
cockpit making airplane noises and pretending to fly- since I wouldn't have
any bankroll left over for fuel and oil....HAHAHAHAH...
I've been gone through the logbooks in detail- I'm glad I have your old
airplane, Milt. When she's done we might have to jog down your way and show
her off....
Sat up all night last night reading old posts from this list and saw you
mention the 757/767/400 in a post someplace...That tells me you are a UAL
guy, no? (400 was the give away.) I spent 13 years at UAL before leaving
management to take a flying job at another carrier... Hope you didn't get
beaten down too badly with the whole retirement debacle. Those bastards
should be lynched for what they've done.
Robert Randazzo
allen_reed2(at)hotmail.co
PostPosted: Tue Apr 11, 2006 5:18 pm    Post subject: Introduction Reply with quote
you dont mean the same ones that got Chris do ya??
Reply-To: commander-list(at)matronics.com
Subject: Re: Introduction
Date: Tue, 11 Apr 2006 05:24:02 -0700
Robert,
or deferred maint.
(http://img230.imageshack.us/my.php?image=airborne44cx.jpg)
Milt
Milt
N395V
F1 Rocket
http://forums.matronics.com/viewtopic.php?p=27541#27541
n395v
PostPosted: Tue Apr 11, 2006 5:23 pm    Post subject: Re: Introduction Reply with quote
Nope.
Milt
STOLHorse(at)aol.com
PostPosted: Tue Apr 11, 2006 9:35 pm    Post subject: Introduction Reply with quote
Hello Robert - And hello again to the rest of you Commander fans.
I have not contributed to this list in probably two years or more but I have
been reading virtually every post. This list is definitely my support group
as I am certain my brain will end up in a glass jar right alongside most of
yours in the Center for the Study of Creative Aircraft Expenditure
Justifications. But, that's OK with me because we all know that these airplanes are as
superior as they are unique. I've owned a 690B, 681B twice, a 560F briefly,
and now the 685. I'm sure we all have our favorite model but what I've
learned from my small sampling is that they are all fantastic airplanes.
It was a real pleasure to read your introduction Robert (and the resultant
685 specific advise) because I have been getting acquainted with MSN 12057
over the past year and a half. I'm not sure but I think Milt was the only 685
owner on the list and I knew he sold his (yours) a couple years ago.
Anyway, I am pleasantly surprised with the airplane. I bought it for the
same reasons you did and, after flying the 690's so much, I figured I'd really
not like it much. But, as long as I keep it in perspective and don't ask it
for 690 type capabilities, it has worked very well. I run the airplane
fairly heavy (its hard not to because they are so heavy empty) and I go to high
altitude airports with it -- but not in mountainous areas. I do use full power
on take off, because it needs it, but I do it very slowly.
I am currently doing my second annual on it (I do most of my own
maintenance) and this is definitely the time of year when I am continuously arguing with
myself about how much I need a Commander. I was pretty worried about
finding parts for it but, so far, I have been able to find all that I need. That
is not to say that there haven't been some challenging "Easter egg hunts" but,
actually it has been much better than I expected. I can echo the concerns
about the exhaust system inspections. Right after I got the plane I found a
crack in one exhaust stack that started right at the weld of the flange and
had worked its way about 5/8 around the tube. I open both sides of that
cowling and get my flash light and rag and study and grab and touch and wipe
everything thoroughly before every flight. The stories of broken exhaust and fires
is plenty of motivation to spend 45 minutes or so preflighting the airplane.
I have never spent anywhere near the amount of time on preflight
inspections with any other airplane but I feel better doing it on this one.
I have only flown it about 130 hours but, so far it has been a sound
airplane and I'm glad I gave it a try. I would love to upgrade the panel like you
are doing. (I am currently doing a very similar panel with the Chelton
displays in a customers Helio Courier.) I also gave a considerable amount of
thought to an engine conversion but, like Keith said, I think I'll wait for the
next Popular Mechanics to come out.
Well, maybe I rarely contribute to this list because I don't know when to
stop. Sorry to ramble on.
Welcome to the list and I look forward to hearing more about your 685.
Let's talk about power settings sometime.
Best regards,
David Maytag
PostPosted: Wed Apr 12, 2006 12:09 am    Post subject: Introduction Reply with quote
David-
Ah, Great! Another 685 owner!
I have not had any problems with parts- EXCEPT that I'm currently having a
hard time finding a turbo housing. Everyone seems to think they are
available- but nobody seems to know where. Apparently this happens with
turbo housings from time to time- so I'm not sweating it just yet.
My operating with the airplane has been mostly pretty heavy as well. Three
legs were with 322gal of fuel- and I was glad to have some time in larger
transport category airplanes that suffer in climb performance when full of
gas. I honestly never considered "Step climbs" in a GA airplane before- but
they worked perfectly.
Once I'm finished with this refit, most of my flying will be up/down the
west coast. Reno is mountainous terrain- which is why I was so inteersted
in the Cheltons. I like the idea of being able to see in the dark with the
synthetic vision- and in the event I have to find a landing strip with one
prop not turning- the Flight Path Vector is an incredibly useful tool. Most
of my flying will be single pilot- so I am a big fan of automation.
Store my email address, David- I'd like to make good acquaintance with
fellow 685 owners. I can't wait to get our bird flying again. Every time I
squeeze myself into the back of some airline's equipment- I look more and
more forward to having this upgrade completed.
Must be a way we can strap a pair of Garrets to our airplanes without anyone
noticing, David... Just might have to use some good old Yankee Ingenuity.
Hahahahah..... ("No, Mr. FAA Man. I don't know why the dataplate says
GTSO-520-K on it. I mean- look! Those are clearly Garrets!")
Robert Randazzo
br549phil(at)mindspring.c
PostPosted: Thu Apr 13, 2006 10:42 am    Post subject: Introduction Reply with quote
I contracted with Morris four years ago to do the pre-buy on my 560F
knowing of his past problems. I am an A&P with an IA but knew it was well
worth my while to have someone who knows what to look for do the
inspection. After eight hours and a list of 124 discrepancies(on an
aircraft about to be signed off for an annual) there was no question it was
money well spent.
Over the years his store of spares and freely given advice have saved me
much time, money and aggravation.
We all make mistakes. His value to the Commander community is hard to
dispute.
Phil Stubbs
[Original Message]
To: <commander-list(at)matronics.com>
Date: 4/11/2006 3:40:10 PM
was
Morris
years
get
or
one
of
[quote] the highly praised Commander shops just call Morris when they come upon a
/J
moe(at)rosspistons.com
PostPosted: Thu Apr 13, 2006 11:08 am    Post subject: Introduction Reply with quote
Gents,
Morris has always dealt with me very fairly. My mechanic has called Morris
numerous times for (free) advice when working on my 680F(p). I would
recommend Morris to anyone.
Moe
N680RR
kamala(at)msn.com
PostPosted: Thu Apr 13, 2006 4:30 pm    Post subject: Introduction Reply with quote
mk, so morris how many buttons are left on the chest of your shirt? you now
have a real clear picture of what your friends think of you, kept secret
until now. congradulations. mason
[quote]From: "Moe" <moe(at)rosspistons.com>
Date: Thu, 13 Apr 2006 12:02:35 -0700
Gents,
Moe
N680RR
