tri gear tires
graham(at)gflight.f9.co.u
PostPosted: Wed Jan 11, 2006 2:31 am    Post subject: tri gear tires Reply with quote
I would like to replace the main tires of my Trigear with smaller ones. Was wondering
whether the same size tires as the nosewheel uses can be installed on the
mains, too ?
(I need the additional clearance for an enlarged prop - and would not mind the
less drag).
Anybody has a suggestion where to obtain fairings for those smaller tires then
be well,
<Thomas, N81EU>
Thomas
have a look at Klaus Savier's web site, he does the low drag wheel pants for EZs. His EZ is the fastest. Also look at Gary Hertzler's achievements
He's very good on props and everything else to do with drag reduction.
http://www.lightspeedengineering.com/
<hertzler(at)yahoo.com>
Graham
