cffd(at)pgrb.com Guest
Posted: Wed Dec 02, 2009 9:03 am Post subject: Bing Carby |
The "Bing Carburetors Aircraft Tuning and Parts Manual" (2007) states that the diaphragm in carb should be replaced every two years regardless of hours. Has anybody done this?
Chuck D.
| | - The Matronics JabiruEngine-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?JabiruEngine-List |
checkpoint2(at)COMCAST.NE Guest
Posted: Wed Dec 02, 2009 9:22 am Post subject: Bing Carby |
No, didn’t on BMW Motorcycles either. 2200 Jab. in Alpi Pioneer has 340 hrs. no problems. Did you do the SCCA circuit in the
Fiftys ? Bob Haas N380BH.
From: owner-jabiruengine-list-server(at)matronics.com [mailto:owner-jabiruengine-list-server(at)matronics.com] On Behalf Of Chuck Deiterich
Sent: Wednesday, December 02, 2009 12:02 PM
To: Jabiru-List
Subject: Bing Carby
Chuck D.
| Quote: | | www.aeroelectric.com | 0123456789012345678
Lynn Matteson
Posted: Wed Dec 02, 2009 9:45 am Post subject: Bing Carby |
Not me.
I had my Bing for 3-1/2 years, and in discussing this matter with the
folks at Bing, they said there is no test for a bad diaphragm, just
hold it up to the light and if you can see no pinholes or cracks,
continue to use it.
And when you stop to think about it, what does two years really mean?
Two years of aging is one thing, two years at 200 hours per year for
one flier is not like two years of 50 hours per year for another.
That's why I asked the Bing folks if there was any test that could be
done, rather than just arbitrarily change it.
Lynn Matteson
Jabiru 2200, #2062, 818.9 hrs
Countdown to 1000 hrs~185 to go
Sensenich 62"x46" Wood prop
Rotec TBI-40 injection
Status: flying (and learning)
On Dec 2, 2009, at 12:02 PM, Chuck Deiterich wrote:
| Quote: | The "Bing Carburetors Aircraft Tuning and Parts Manual" (2007)
Chuck D.
============================================================ _-
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
naftalih(at)hotmail.com Guest
Posted: Thu Dec 03, 2009 7:44 am Post subject: Bing Carby |
Hi C
What static WOT do you get with the 62x46" prop?
Thanks C
Naftali.
| Quote: | From: lynnmatt(at)jps.net
Subject: Re: Bing Carby
Date: Wed C 2 Dec 2009 12:45:00 -0500
To: jabiruengine-list(at)matronics.com
--> JabiruEngine-List message posted by: Lynn Matteson <lynnmatt(at)jps.net>
Not me.
I had my Bing for 3-1/2 years C and in discussing this matter with the
folks at Bing C they said there is no test for a bad diaphragm C just
hold it up to the light and if you can see no pinholes or cracks C
continue to use it.
And when you stop to think about it C what does two years really mean?
Two years of aging is one thing C two years at 200 hours per year for
done C rather than just arbitrarily change it.
Lynn Matteson
Kitfox IV Speedster C taildragger
Jabiru 2200 C #2062 C 818.9 hrs
> Chuck D.
> ========== _-
&g-==============================================
Windows LiveT Hotmail is faster and more secure than ever. Learn more.
Lynn Matteson
Posted: Thu Dec 03, 2009 3:04 pm Post subject: Bing Carby |
I usually see about 2840-2860.
Lynn Matteson
On Dec 3, 2009, at 10:43 AM, Naftali Horowitz wrote:
| Quote: | Hi,
Naftali.
> Date: Wed, 2 Dec 2009 12:45:00 -0500
> Not me.
the
> continue to use it.
mean?
could be
> Lynn Matteson
> Kitfox IV Speedster, taildragger
> Electroair direct-fire ignition system
> > Chuck D.
> > ========== _-
N369LM |
Posted: Thu Dec 10, 2009 11:23 pm Post subject: Bing Carby |
Did you get any RPM increase due to the Electroair ignition?
Is it with the Bing or injection?
Thanks C
Naftali
[quote] From: lynnmatt(at)jps.net
Date: Thu C 3 Dec 2009 18:01:17 -0500
Lynn Matteson
On Dec 3 C 2009 C at 10:43 AM C Naftali Horowitz wrote:
> Hi C
> Thanks C
> Naftali.
> > Not me.
> the
> > continue to use it.
> mean?
> could be
> > Lynn Matteson
> > > Chuck D.
> > > ========== _-
Hotmail: Trusted email with Microsoft’s powerful SPAM protection.
Lynn Matteson
Posted: Fri Dec 11, 2009 3:29 am Post subject: Bing Carby |
No increase that I can really attribute to the Electroair ignition,
but I installed the ignition during an engine rebuild, so many things
were different after I reinstalled the engine. The main reason for
the ignition change was to get away from the (in my case) sloppy
rotors, and otherwise antiquated distributor-based ignition system.
(What modern engine uses distributors these days?) I also wanted to
have a system that was capable of advancing the ignition under
certain conditions, and retarding the ignition as well.
I am currently using the Rotec TBI-40 fuel metering system (Throttle
Body Injection), because I also wanted to be able to control the fuel
mixture while in flight. Here again, I felt that something a bit more
modern than the float-type carburetor was required (or in my case,
desired).
Some of the changes or decisions that I make are based on boredom...I
just need to be doing something different than just flying the plane
as it is. : )
Lynn Matteson
Jabiru 2200, #2062, 820.8 hrs
Countdown to 1000 hrs~179 to go
On Dec 11, 2009, at 2:22 AM, Naftali Horowitz wrote:
| Quote: | Did you get any RPM increase due to the Electroair ignition?
Naftali
> Date: Thu, 3 Dec 2009 18:01:17 -0500
> Lynn Matteson
> > Hi,
> > Thanks,
> > Naftali.
> > > Not me.
with
> > the
diaphragm, just
cracks,
> > > continue to use it.
> > mean?
year for
another.
> > could be
> > > Lynn Matteson
> > > > Chuck D.
> > > > ========== _-
Hotmail: Trusted email with Microsoft’s powerful SPAM protection._-
N369LM |
Posted: Fri Dec 11, 2009 2:43 pm Post subject: Bing Carby |
Thanks Lynn for your thorough reply
Appreciate it C
Naftali.
Date: Fri C 11 Dec 2009 06:26:23 -0500
No increase that I can really attribute to the Electroair ignition C
but I installed the ignition during an engine rebuild C so many things
rotors C and otherwise antiquated distributor-based ignition system.
certain conditions C and retarding the ignition as well.
Body Injection) C because I also wanted to be able to control the fuel
mixture while in flight. Here again C I felt that something a bit more
modern than the float-type carburetor was required (or in my case C
desired).
as it is. : )
Lynn Matteson
Jabiru 2200 C #2062 C 820.8 hrs
> Thanks C
> Naftali
> > Lynn Matteson
> > > Hi C
> > > Thanks C
> > > Naftali.
> > > > Not me.
> with
> > > the
> diaphragm C just
> cracks C
> > > > continue to use it.
> > > mean?
> year for
> another.
> > > could be
> > > > Lynn Matteson
> > > > > Chuck D.
> > > > > ========== _-
> > > > > ========== _-
> > > ========== _-
> > > ========== _-
> ========== _-
Your E-mail and More On-the-Go. Get Windows Live Hotmail Free. Sign up now.
Lynn Matteson
Posted: Fri Dec 11, 2009 4:54 pm Post subject: Bing Carby |
You're very welcome.
Lynn Matteson
On Dec 11, 2009, at 5:41 PM, Naftali Horowitz wrote:
| Quote: | Thanks Lynn for your thorough reply
Appreciate it,
Naftali.
N369LM |
