I Need a 6B5-5 Built
LHusky
PostPosted: Tue Nov 17, 2009 5:36 pm    Post subject: I Need a 6B5-5 Built Reply with quote
I need a new 6B5-5 built for my XL. I am going to go ahead and install my composite gear setup. The 6B5-5 gear channel used for the composite gear is the same as the regular 6B5-5, but it is a little deeper to accept the brackets. All the brackets are factory made from a CZAW plane. I will have to find the CZAW plans for the exact dimensions.  I just do not have the setup to make the part. Let me know if you can make this part and what you will charge me. Either way, I will have a full landing gear set, including front strut and all 3 wheels and tires for sale. Just do not know if it will be the composite set or Zenith set yet. Email me off line.
Larry Husky
Madras, Oregon
