nose gear shimmy
tfisher(at)commandergroup
PostPosted: Tue Apr 04, 2006 5:32 pm    Post subject: nose gear shimmy Reply with quote
Anti-shimmy pads, adjust the screws that tighten the spring pressure.
Tom F.
Former 500B owner
NOW 680FLP (Mr.RPM).
n55bz(at)cox.net
PostPosted: Tue Apr 04, 2006 5:38 pm    Post subject: nose gear shimmy Reply with quote
Mine did that. I just had the mechanic tighten up the friction assembly on
the nose strut and it went away. It doesn't take much to make the shimmy go
away. Too tight and the nose wheel steering is sluggish.
Kindest regards,
Bill
YOURTCFG(at)aol.com
PostPosted: Tue Apr 04, 2006 8:12 pm    Post subject: nose gear shimmy Reply with quote
In a message dated 4/4/2006 5:25:23 P.M. Pacific Standard Time,
daniellfarmer(at)yahoo.com writes:
Any ideas on the fix?
Buy a can of disc brake cleaner. Spray liberally into the friction area.
Watch as the goo runs out. Works almost every time.. jb
avtec2(at)bellsouth.net
PostPosted: Wed Apr 05, 2006 4:28 am    Post subject: nose gear shimmy Reply with quote
New goodyeat nose tire;
Harry
dowens(at)aerialviewpoint
PostPosted: Thu Apr 06, 2006 10:23 am    Post subject: nose gear shimmy Reply with quote
The ENGINE BAFFELS probably need replacing... Possibility
john(at)vormbaum.com
PostPosted: Thu Apr 06, 2006 10:35 am    Post subject: nose gear shimmy Reply with quote
I've also heard that nose gear shimmy can be caused by sump corrosion Wink.
/J
nico(at)cybersuperstore.c
PostPosted: Thu Apr 06, 2006 12:50 pm    Post subject: nose gear shimmy Reply with quote
Or a worn pilot seat cover...
pakrak(at)charter.net
PostPosted: Thu Apr 06, 2006 4:51 pm    Post subject: nose gear shimmy Reply with quote
call Morris he will tell you exactly what is wrong.
wjrhamilton(at)optusnet.c
PostPosted: Thu Apr 06, 2006 9:50 pm    Post subject: nose gear shimmy Reply with quote
But, Folks,
Can she shimmy like her sister Kate ??
Cheers,
Bill Hamilton
