Wiki (was: Is it a hard to transition to a YAK?)
brian
PostPosted: Mon Apr 03, 2006 11:58 am    Post subject: Wiki (was: Is it a hard to transition to a YAK?) Reply with quote
Roger Kemp wrote:
Just had a look briefly at the Wiki! Not bad ol boy. Yeah, think you got
some Southerner in yor blud!
Ah s'pose.
Time for others to start putting stuff into the Wiki. I will be adding
the CJ6A checklists that Jeff created. I will probably modify them a bit
to improve "flow" in the cockpit. After that I will tackle the EPs.
So what are the rest of you going to contribute?
Brian
Brian Lloyd
brian-yak at lloyd dot com
- Antoine de Saint-Exupery
viperdoc(at)mindspring.co
PostPosted: Mon Apr 03, 2006 12:32 pm    Post subject: Wiki (was: Is it a hard to transition to a YAK?) Reply with quote
A dumb question since I'm just learning about Wiki, can an attachment be
sent to the Wiki? Like a YAK-50 pilot's handbook or a YAK -52 handbook?
Doc
[Original Message]
To: <yak-list(at)matronics.com>
Date: 4/3/2006 3:04:27 PM
Subject: Wiki (was: Is it a hard to transition to a YAK?)
Ah s'pose.
Brian
brian
PostPosted: Mon Apr 03, 2006 7:07 pm    Post subject: Wiki (was: Is it a hard to transition to a YAK?) Reply with quote
Well you can upload most any kind of file. I suppose you could put up a
PDF. But it would be much better if it was turned in to searchable,
indexable pages.
If you want to upload files to put on your pages look at the left side
of the WIKI page under "toolbox". You will see a link for "upload file".
If you are going to upload a file, do what you can to make sure the file
has a unique name that someone else won't use. "Image15.jpg" is not
particularly unique. In the case of Pappy's history article I prefixed
each of the image files with "gcj6aha-" (goolsby CJ6A history article),
as in "gcj6aha-image14.jpg". It is unlikely that anyone else is going to
put that in their file name.
Brian Lloyd 361 Catterline Way
brian-yak at lloyd dot com Folsom, CA 95630
Brian Lloyd
