jeffrey-j-paris(at)excite Guest
Posted: Thu Sep 17, 2009 8:04 am Post subject: Paint Brands Suggentions for composite Aircraft |
Dear Europa Gurus,
Any suggestions on what brand of paint product works best for our airframes? I have used these products in the past on othe Airplane projects:
My Zenith Zodiac-Akzo Nobel-epoxy primer and 2 part Polyurethane wished for better results
My friend's RV-6-PPG epoxy primer and 2 part Polyurethane- Nice product to work with and nice results
My friends Sonex-Stewart Systems Water based 2 Part Polyurethane-A BITCH to work with. Results good after a great deal of fussing/Re-do's.
Thanks for your time and consideration.
Jeff Paris Jab 3300 Kit #A012 Europa Monowheel Classic Dynon D180 1920 hours into the project Click to reduce wrinkles & lines. Anti-aging that works, try now. Anti-Wrinkle Products Click Here For More Information [quote][b]
Posted: Thu Sep 17, 2009 8:51 am Post subject: Paint Brands Suggentions for composite Aircraft |
Jeff, I would recommend gel coat and in particular Swabilec - sprayed and
then rubbed down to a perfect finish with wet & dry. It is what most racing
gliders are finished with and they of course look for the ultimate finish on
their laminar flow surfaces. Regards, David Joyce, G-XSDJ.
jeff(at)rmmm.net Guest
Posted: Thu Sep 17, 2009 10:12 am Post subject: Paint Brands Suggentions for composite Aircraft |
Jeff,
After using K38 (PPG) high build primer and blocking down several times
I then used Sherwin Williams Geniuses automotive finish. One coat then
one wet coat and that was it. Looks good. However, If I had to do it
all over again I would use these...
http://www.loehle.com/loehle_aero_coatings_on_rv_aircr.htm
Mike Loehle will be at Rough River and anyone is interested they can
sit in on a talk he's giving on his finishes to the Louisville EAA
chapter.
Jeff R.
A258 - N128LJ / Gold Rush Driving into Rough River Saturday morning
and spending the night.
Bud... I'll bring the miller light since I'm driving.
On Sep 17, 2009, at 11:02 AM, Jeffrey J Paris wrote:
Quote: |
Dear Europa Gurus,
projects:
fussing/Re-do's.
