Bondo
moe(at)rosspistons.com
PostPosted: Wed Mar 29, 2006 3:50 pm    Post subject: Bondo Reply with quote
Gents,
Does anyone have a suggestion as to which body filler is best to use on plain aluminum, where holes can not be drilled in the fuselage, to smooth out minor dents?
Thanks!
Moe
N680RR
680Fp
floydgm(at)hotmail.com
PostPosted: Wed Mar 29, 2006 4:49 pm    Post subject: Bondo Reply with quote
Pro seal fuel tank sealant smoothed with a finger dipped in MEK works well.
bowing74(at)earthlink.net
PostPosted: Wed Mar 29, 2006 4:56 pm    Post subject: Bondo Reply with quote
Pressurize it to about 30PSI!
bb
PostPosted: Wed Mar 29, 2006 5:43 pm    Post subject: Bondo Reply with quote
Bill Bow
It takes too much bondo and then makes the airplane way too heavy to make it
useable again. And you need STRUCTURAL bondo.
br549phil(at)mindspring.c
PostPosted: Thu Mar 30, 2006 6:12 am    Post subject: Bondo Reply with quote
Moe,
There is an epoxy filler called SUPERFIL by Poly-Fiber that is a
corrosion-inhibiting filler designed to adhere to bare alluminum.
I have used it for about ten years with excellent results. Dry time is
longer than bondo but it is easy to mix and shape with excellent adhesion.
Available at Aircraft Spruce in Corona 877-477-7823.
Phil
Phil Stubbs
[Original Message]
To: <commander-list(at)matronics.com>
Date: 3/29/2006 6:55:02 PM
Subject: Bondo
Gents,
out minor dents?
Thanks!
Moe
N680RR
680Fp
PostPosted: Thu Mar 30, 2006 6:50 am    Post subject: Bondo Reply with quote
Gents,
Thanks for the tips on filler.
Moe
wjrhamilton(at)optusnet.c
PostPosted: Fri Mar 31, 2006 11:48 pm    Post subject: Bondo Reply with quote
Folks,
At the risk of sounding like I am trying to teach somebody to suck
eggs, can I suggest that, for anything more than minor cosmetic
damage,and I really mean minor, and anything with a score as part of
the ding, you should consider it in terms of damage limits, ( not
much in the older Commander manuals) and AC 43-13A/B, and proceed
accordingly. Small doubler plates, suitable fitted on the underside
of "panel beaten" sections, are really easy to do. A ding means the
metal is stretched, all the usual methods of shrinking the plate
(skin) do not restore the original strength.
Needless to say, never use bog ( English for bondo) on any control
surface. The results of flutter from unbalanced controls is not pretty.
Anything you use should be safe on aluminium, the results of stress
corrosion ain't pretty, even "ordinary" surface corrosion,
especially inside lap joints can ruin your day, not to mention your
bank balance.
We have had altogether too much experience with hail damage recently,
and have some very nasty disputes in progress with insurance
companies, who will not accept that, on the type involve, the fwd.
spar/leading edge structure is, in fact, a "box spar", not just a few
ribs with a bit of sheet wrapped around it.
Bill Hamilton
At 13:53 31/03/2006, you wrote:
<tfisher(at)commandergroup.bc.ca>
You could always add a rib from behind to push out the "oil can".
Tom F.
allen_reed2(at)hotmail.co
PostPosted: Sat Apr 01, 2006 5:09 pm    Post subject: Bondo Reply with quote
If your plane has over 10% red primer on it,,you might be a "RED-NECK"
commander pilot!!! Big Al
[quote]From: W J R HAMILTON <wjrhamilton(at)optusnet.com.au>
Reply-To: commander-list(at)matronics.com
Subject: Bondo
Date: Sat, 01 Apr 2006 18:46:17 +1100
Folks,
bank balance.
Bill Hamilton
>Tom F.
PostPosted: Mon Apr 03, 2006 6:44 am    Post subject: Bondo Reply with quote
Commander Drivers,
Thanks very much for all of the information on dent filling. Here is the deal...Recently I picked up some ice very quickly, and when the hot props went on there was a little ice slinging episode which knocked our some body filler that had been previously installed. The dents were no worse than before, and were in the rounded part of the top of the fuselage (part of the pressure vessel and above the thick panel which is made to take the hit). Problem was, three pieces of body filler, about the size of a quarter each, missing do not look too good. Over the week end the Poly-Fiber Superfil Epoxy from Aircraft Spruce and Specialty was used. There is actually an STC for its use. It appears to work quite well.
Moe
