kearney
Posted: Sun May 24, 2009 7:52 am Post subject: Zolotone - Anyone using it? |
Hi
First off, let me wish everyone south of the 49th a happy Memorial Day! To those who have are in the service, many thanks for you service.
Next, I am contemplating using Gray Zolotone to “finish” my canopy interior rather than installing a headliner. Has anyone used this product and if so, is there a simple way to apply it (while the canopy is off the fuse)? Are you happy with the results? Any PIX?
Cheers
Les
ricksked(at)embarqmail.co Guest
Posted: Sun May 24, 2009 9:14 am Post subject: Zolotone - Anyone using it? |
Les..I'm spraying mine this week in harvest gold...I have both a HVLP rig and I picked up a sprayer from spruce just in case...you will need a 2.2 tip to spray the second hammer or texture coat. I'm doing it on an installed cover and the door interiors...I'll get back to you later in the week would have done it today but the work emerg phone rangRick SkedN246RS
Sent via BlackBerry by AT&T
Date: Sun, 24 May 2009 09:51:21 -0600
Subject: RV10-List: Zolotone - Anyone using it?
Hi
First off, let me wish everyone south of the = 49th a happy Memorial Day! To those who have are in the service, many thanks = for you service.
Next, I am contemplating using Gray Zolotone to = “finish” my canopy interior rather than installing a headliner. Has anyone used = this product and if so, is there a simple way to apply it (while the canopy is off = the fuse)? Are you happy with the results? Any = PIX?
Cheers
Les
| Quote: | | _-=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D _-=3D - The RV10-List Email Forum - _-=3D Use the Matronics List Features Navigator to browse _-=3D the many List utilities such as List Un/Subscription, _-=3D Archive Search & Download, 7-Day Browse, Chat, FAQ, _-=3D Photoshare, and much much more: _-=3D _-=3D --> http://www.matronics.com/Navigator?RV10-List _-=3D _-=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D _-=3D - MATRONICS WEB FORUMS - _-=3D Same great content also available via the Web Forums! _-=3D _-=3D --> http://forums.matronics.com _-=3D _-=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D _-=3D - List Contribution Web Site - _-=3D Thank you for your generous support! _-=3D -Matt Dralle, List Admin. _-=3D --> http://www.matronics.com/contribution _-=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D |
Posted: Sun May 24, 2009 1:39 pm Post subject: Zolotone - Anyone using it? |
I used it and I like the results. Need the correct gun and follow directions. Even so I did not follow the directions perfectly and i still liked the result. I epoxied all the aluminum backing strips to the inside of the canopy so that I could paint that also while the top was outside. I was able to paint the door hydralic bracket later before the windscreen and doors went in.
JOhn G. FLying C the glider C not the 10.
Subject: Zolotone - Anyone using it?
Date: Sun C 24 May 2009 09:51:21 -0600
.ExternalClass p.EC_MsoNormal C .ExternalClass li.EC_MsoNormal C .ExternalClass div.EC_MsoNormal {margin-bottom:.0001pt;font-size:12.0pt;font-family:'Times New Roman';} .ExternalClass a:link C .ExternalClass span.EC_MsoHyperlink {color:blue;text-decoration:underline;} .ExternalClass a:visited C .ExternalClass span.EC_MsoHyperlinkFollowed {color:purple;text-decoration:underline;} .ExternalClass p.EC_MsoAutoSig C .ExternalClass li.EC_MsoAutoSig C .ExternalClass div.EC_MsoAutoSig {margin-bottom:.0001pt;font-size:12.0pt;font-family:'Times New Roman';} .ExternalClass span.EC_EmailStyle17 {font-family:Arial;color:windowtext;} (at)page Section1 {size:612.0pt 792.0pt;} .ExternalClass div.EC_Section1 {page:Section1;}
Hi
First off C let me wish everyone south of the 49th a happy Memorial Day! To those who have are in the service C many thanks for you service.
Next C I am contemplating using Gray Zolotone to “finish” my canopy interior rather than installing a headliner. Has anyone used this product and if so C is there a simple way to apply it (while the canopy is off the fuse)? Are you happy with the results? Any PIX?
Cheers
Les
.com
143.72 KB |
2382 Time(s) |
121.37 KB |
2382 Time(s) |
126.94 KB |
2382 Time(s) |
kearney
Posted: Sun May 24, 2009 2:53 pm Post subject: Zolotone - Anyone using it? |
It looks like you used the same gray I am considering.
I have also benn looking at your console photos from a while ago with a view to doing something similar except I would like to duct overhead air in as well.
Thanks for the info and pix.
Cheers
Les
#40643 - Living in a f/g world
On 24-May-09, at 3:35 PM, John Gonzalez <indigoonlatigo(at)msn.com (indigoonlatigo(at)msn.com)> wrote:
[quote] I used it and I like the results. Need the correct gun and follow directions. Even so I did not follow the directions perfectly and i still liked the result. I epoxied all the aluminum backing strips to the inside of the canopy so that I could paint that also while the top was outside. I was able to paint the door hydralic bracket later before the windscreen and doors went in.
JOhn G. FLying, the glider, not the 10.
From: [url=mailto:kearney(at)shaw.ca]kearney(at)shaw.ca (kearney(at)shaw.ca)[/url]
To: [url=mailto:rv10-list(at)matronics.com]rv10-list(at)matronics.com (rv10-list(at)matronics.com)[/url]
Hi
Cheers
Les
<Finished overhead 1.JPG>
<Finished overhead 2.JPG>
<Finished overhead 3.JPG>
