kirkhull(at)sbcglobal.net Guest
Posted: Sun Mar 26, 2006 2:31 pm Post subject: first flight classic VI |
I am getting ready to to the first flight in a classic VI with a 100 HP
subaru and was wandering if anyone could give me some prelimanary # for
lift off
Clime speed
Approach
landing
stall clean
Stall with full Flaps
I am just looking for a baseline to start with from another classic VI with
similar HP
Thanks Kirk
classic VI N205AK
vadert(at)telusplanet.net Guest
Posted: Mon Mar 27, 2006 5:38 pm Post subject: first flight classic VI |
Kirk
I'm not the best person to answer this post; there are other on the list
who have plenty of time in KF IV's with Subarus but nothing was coming
through so here's my two cents worth.
I don't have the numbers you're asking for, however, I have taken my
Kitfox IV with Subaru engine for it's first flight last summer. I had an
engine out on the second flight and damaged the aircraft.
My bird has an empty weight of 742 lbs and the cg is near the front of
the envelope when empty.
For my first flight I let the plane tell me when it was ready to fly.
At a certain speed it will want to leave the runway. I kept all of my
speeds well above the speeds published in the Skystar handbook. Your
airspeed indicator system may not be working properly (misaligned pitot,
pitot line blockage, instrument calibration) so I think the most prudent
thing is to remain above the published speeds until you feel comfortable to
push towards the figures.
I think the first flight (flights) should be used to check temperatures,
gauges etc. to make sure every thing is working properly. If there are no
bugs then you can start to work determining the speeds you and your plane
are comfortable with.
Tim Vader
C-FBYV
Posted: Mon Mar 27, 2006 7:50 pm Post subject: first flight classic VI |
thanks . we have done alot of taxi to check the temps and was planning to
add a little to all of the V speeds until I could check them out at alt.
smokey_bear_40220(at)yaho Guest
Posted: Mon Mar 27, 2006 8:40 pm Post subject: first flight classic VI |
Hi Kirk,
I got my tailwheel endorsement in a IV/Soob and fly a
V/Soob now. I dont remember all the speeds for the
IV perfectly, but you already have some good advice
there: Add a little to the book speeds initially and
use lots of runway too. I've added 5 to all except
the landing and stalls for you as I remember them.
You can take that out when your testing shows better,
or use what you feel prudent.
I'll fill in below for you as best as I know. Expect
some float for landing with the speed buffer. Do your
stalls when comfortable to know the speeds better with
your indicator.
My FAA inspector told me to angle, then climb adjacent
to the runway so that I can turn back to the runway
next to me rather than under and behind me, if I need
to. If your airport terrain allows that, you should
consider it too.
Be careful to use a near center CG initially so that
you have the best elevator authority available.
Kurt S. S-5/NSI turbo
--- kirk hull <kirkhull(at)sbcglobal.net> wrote:
| Quote: | I am getting ready to to the first flight in a
lift off 55 (approx-use feel)
Climb speed 65
Approach 65
landing 45
stall clean 42
Stall with full Flaps 37
another classic VI with similar HP
Thanks Kirk
classic VI N205AK
Posted: Tue Mar 28, 2006 5:44 am Post subject: first flight classic VI |
Thanks Kurt thak is exactly what I was looking for. N205AK should fly soon
Inspection is tentatively set for april 10
Posted: Tue Mar 28, 2006 3:22 pm Post subject: first flight classic VI |
Actually I am not going to fly it untill I can get some instruction in it
for tailwheel. I have time in everything from a 150 to a lear but no
tailwheel. I found someone with alot of experience in a cub who will fly
off the 40
