air.guerner(at)wanadoo.fr Guest
Posted: Fri Mar 24, 2006 12:14 pm Post subject: kick back fix |
Hello all,
In order to sort out the kick back problem I experienced with my 912S, I checked the trigger coils gap, as suggested by Andy in Factory Tech Talk. Surprisingly none of them were found to be within the tolerances specified by ROTAX. The specified gaps are between 0,3 and 0,4 millimeters. I measured gaps between 0.15 and 0.25 millimeters. I also found that the trigger coil B =C2=BE was pushed down by the alternator/ignition wiring harness, and therefore it was impossible to adust the gap properly. The fix was to use a ty-wrap attached to the engine mount ring so that the wiring harness is moved up out of the way. I adjusted the gaps at around 0,4 mm and now the engine is starting a lot more smoothly, with no kick back. It is obvious that the engine was delivered to me with this wrong gap adjustment. Adusting these gaps is a time consuming work, as you have to remove a lot of stuff to get access to the back of the engine. Therefore I strongly recommend that new builders check their trigger coils before they hang the engine on the aircraft.
Remi Guerner
F-PGKL, XS S/N395 monowheel, 912S, 383 hours, installing an Airmaster prop
kheindl(at)msn.com Guest
Posted: Sat Mar 25, 2006 7:16 am Post subject: kick back fix |
Quote: | From: "Rmi Guerner" <air.guerner(at)wanadoo.fr>
Reply-To: europa-list(at)matronics.com
Subject: kick back fix
Date: Fri, 24 Mar 2006 21:04:44 +0100 (CET)
Hello all,
I strongly recommend that new builde!
aircraft.
Remi Guerner
prop
Posted: Sat Mar 25, 2006 7:17 am Post subject: kick back fix |
Hello Rmi,
This sound very promising. My problem is that I can't find any reference to
this trigger coil in any of the manuals or newsletters. What exactly is it
for and whereis it ?
Are you also saying that maybe there is no need to upgrade to the new
starter motor ?
I am just about to order one from Lockwood ($299.-), but maybe I should
wait.
Karl
Hello all,
aircraft.
Remi Guerner
prop
Horizonspace(at)aol.com Guest
Posted: Sat Mar 25, 2006 7:52 am Post subject: kick back fix |
In a message dated 3/25/2006 9:18:09 A.M. Central Standard Time,
kheindl(at)msn.com writes:
Hello Rmi,
starter motor ?
wait.
Karl
Karl,
The trigger coils are located behind the plastic generator cover at the rear
of the engine. My understanding is that the new starter motor upgrade is
only needed for the higher compression 912S engines.
Tam
Posted: Sun Mar 26, 2006 10:54 am Post subject: kick back fix |
Karl,
Have a look at Rotax Service Instruction SI-25-1997 Rev 8 dated December 12, 2005. It gives useful information on the trigger coils.
Remi
Hello Rmi,
starter motor ?
wait.
Karl
Hello all,
aircraft.
Remi Guerner
prop
