robertrv607(at)yahoo.com Guest
Posted: Wed Apr 29, 2009 5:32 pm Post subject: Fuel valve |
Hello:
Question on the "Adler"hope i have the wright name, fuel valve,
for those who have switch from the Standard Vans's one, to the new one,
how is that Valve sustained.,, that is the valve we received from
Van's has the, bracket, that is two legs, which are hold by the two bolts,
that go thru the main wing spar, and then there is the plante that
connect the two legs, at the top, and the center hole for the handle
of the valve...
Now when you connect the new valve, how is it connected,?
I do not think, one just connect the two fuel lines to the Valve, and that
is all..(Assuming the valve is the same diameter as the old one)
I know one can never (well it would be almost impossible to remove that
old bracket, one would have to remove the bolts???)
If some one has pictures of Installation, and details, would appreciate
it.
Bert
rv6a
| | - The Matronics RVSouthEast-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?RVSouthEast-List |
bill(at)repucci.com Guest
