Dave(at)AirCraftersLLC.co Guest
Posted: Sat Apr 04, 2009 4:34 pm Post subject: Behind the Panel... |
Bob Archer makes a com antenna especially for RV wingtips. In the 10 you
can stand it up almost vertically. I've been very happy with the
performance. That said, it's on my no. 2 com. No. 1 is a bent whip on the
belly.
Some people have had problems with the Archer com antennas interfering with
a TT autopilot, to the point of actually inducing significant control
inputs. Yikes. I've never seen that in my plane but I understand the
problem is pretty well understood now and TT should be able to point out the
cure. It has to do with installing a filter on the d-sub at the control
head.
Dave Saylor
AirCrafters LLC
140 Aviation Way
Watsonville, CA
831-722-9141
831-750-0284 CL
www.AirCraftersLLC.com
Posted: Sat Apr 04, 2009 7:06 pm Post subject: Behind the Panel... |
Yeah, that's why it's my COM2. My only external antenna is a Comant on
the belly which will be hooked up to the SL30. Com2 will be on the
430. We'll see how that works.
Much of what I'm doing is guided by the experience with the Maule. I
use the KX155 Nav/com for primary communciations. The com on the 300XL
is only used occassionally for ground when I'm setting up for a busy,
unfamiliar airport. For in the cockpit, pre-takeoff flight planning, I
sometimes only turn on the 300XL to load the course and open the plan
while keeping the Nav/comm off to save the battery. I'm thinking I'll
do the same with the SL30 and the 430W.
Bill
Jesse Saint wrote:
You will be very disappointed with the COM performance as COM antennas
are supposed to be vertically polarized.
YMMV
Jesse Saint
Saint Aviation
jesse(at)saintaviation.com
352-427-0285
On Apr 4, 2009, at 11:08 AM, Bill Mauledriver Watson
> Hey Bob,
> I'm hoping I can split the one Archer because I have my second Com
> antenna in the other tip.
> Indeed, the VOR is a backup and I expect that the ILS will quickly
> effectively become one with the WAAS setup.
> Thanks
> bcondrey wrote:
>> <bob.condrey(at)baesystems.com>
>> Bill,
>> You can split the existing Archer nav antenna for both radios but
>> it's probably about the same amount of money to just install another
>> Archer nav (in the other wingtip). You'll get the added bonus of
>> not losing signal strength due to splitting of the signal between
>> the radios. Of course, most are using VOR as a backup to GPS and
>> the ILS is very strong anyway...
>> Bob
>> N442PM (flying)
>> http://forums.matronics.com/viewtopic.php?p 37654#237654
planesmith(at)hotmail.com Guest
Posted: Sat Apr 04, 2009 8:35 pm Post subject: Behind the Panel... |
Don't know if anyone mentioned the ARINC 429 box from AFS. It will also need to go behind the panel.
Vern Smith (#324 finishing)
[quote] From: jeff(at)westcottpress.com
Subject: Re: RV10-List: Behind the Panel...
Date: Fri C 3 Apr 2009 17:00:03 -0700
--> RV10-List message posted by: Jeff Carpenter <jeff(at)westcottpress.com>
Good point Bob... the general panel plan is this:
AFS Advanced Deck EE
AFS 3400 EE
GNS 430W
SL-30
GTX-330
PMA-9000EX
TruTrack DIgiFlight IIVSGV
The Alternator will be the 60 amp Plane Power
Jeff
On Apr 3 C 2009 C at 4:31 PM C Condrey C Bob (US SSA) wrote:
> --> RV10-List message posted by: "Condrey C Bob (US SSA)"
> Jeff C
> It would help to know what was going in your plane/panel...
> - If B&C alternator you'll need to put the regulator(s) there.
> - If GRT EIS you'll need to mount the manifold pressure sensor there
> - The forest of tabs should be in the aft side of the firewall rather
> than the subpanel
> - If you've got an AFS AOA the process will go on the subpanel
> - potentially an AHRS or GADHRS depending on the EFIS
> - Potentially a Wx receiver
> Bob
> N442PM (flying)
jeff(at)westcottpress.com Guest
Posted: Sun Apr 05, 2009 9:12 am Post subject: Behind the Panel... |
anyone have the foot print of the AFX WX Receiver?
On Apr 3, 2009, at 7:00 PM, Jesse Saint wrote:
Nav antenna diplexer(s).
Instrument cooling fan?
Ammeter shunt?
AFS wx receiver?
Ethernet hub?
Jesse Saint
Saint Aviation
352-427-0285
On Apr 3, 2009, at 8:00 PM, Jeff Carpenter <jeff(at)westcottpress.com>
> AFS 3400 EE
> GNS 430W
> SL-30
> GTX-330
> PMA-9000EX
> Jeff
>> Jeff,
>> rather
>> than the subpanel
>> Bob
>> N442PM (flying)
