alan(at)kestrel-insurance Guest
Posted: Mon Mar 20, 2006 3:34 am Post subject: Spark plug Spanner (wrench) |
Hi All
I am in the middle of doing my annual and decided to torque the spark
plugs as recommended in the manual. Problem is I cant get hold of an
18mm plug socket to go on my torque wrench (3/8 drive) that will fit
into the small space available in the Rotax cylinder head. Before I
start destroying a socket, has anyone found a source from where I can
order one?
Many Thanks
Alan
BEBERRY(at)aol.com Guest
Posted: Mon Mar 20, 2006 3:46 am Post subject: Spark plug Spanner (wrench) |
Hi All
order one?
Many Thanks
Alan
I am inviting caustic response here I know, but it really is not necessary
to torque a plug. I have been flying various aircraft and changing plugs for
many years and the rule -as with cars - is to do them up very little more
than finger tight and let the copper washer do its job. Never had a blow yet
Patrick
Posted: Mon Mar 20, 2006 5:34 am Post subject: Spark plug Spanner (wrench) |
Hi! Alan
Suggest you get a suitable BOX spanner with the size you want at the
plug end and a smaller size the other end. Then get an old nut to fit
the small end and file out the thread to take your 3/8" drive wrench.
This has been known to work for Ivan Shaw in Stockholm ...ask him !
Bob H
Robt.C.Harrison
Ivor Phillips
Posted: Mon Mar 20, 2006 5:46 am Post subject: Spark plug Spanner (wrench) |
Hi Alan
These people carry them, Its German so a tad dearer than home grown,
http://www.tooled-up.com/Product.asp?PID=126785&MAN=Stahlwille-Spark-Plug-Socket-Rubber-18mm-11-16in
Europa-List message posted by: "Alan Burrows" <alan(at)kestrel-insurance.com>
Ivor Phillips
europa flugzeug fabrik
Joined: 13 Feb 2006 Posts: 65 Location: North Coast, USA
Posted: Mon Mar 20, 2006 5:55 am Post subject: Re: Spark plug Spanner (wrench) |
alan(at)kestrel-insurance wrote: | Problem is I cant get hold of an 18mm plug socket to go on my torque wrench (3/8 drive) that will fit into the small space available in the Rotax cylinder head. |
Just shop for a cheap spark plug socket, or any deep-wall for that matter, and which don't have a hefty wall thickness. Then, if necessary, lay the thing on the open jaws of a bench vise...take your most aggressive flat file to work around the circumference...and whistle while you work. Didn't take much filing for me.
Fred F.
Posted: Mon Mar 20, 2006 6:39 am Post subject: Spark plug Spanner (wrench) |
BEBERRY(at)aol.com a crit :
Quote: |
Hi All
order one?
Many Thanks
Alan
Patrick
Hi all,
There is nothing wrong in wanting to correctly torque spark plugs !
Now, if you search the Denso site, you'll find that *angular* torquing
is the best of the best.
I just (one hour ago) bought a 3.50 euro 18 mm plug socket in an auto
store. It has a 1/2" drive, but the 1/2 to 3/8 adaptor costs 2.50 euros
in the same store...
Gilles Thesee
Grenoble, France
http://contrails.free.fr
Posted: Mon Mar 20, 2006 9:30 am Post subject: Spark plug Spanner (wrench) |
Hello Gilles
"you'll find that *angular* torquing is the best of the best"
What is *angular* torquing?
Thx.
Ron Parigoris
Posted: Mon Mar 20, 2006 9:47 am Post subject: Spark plug Spanner (wrench) |
rparigor(at)suffolk.lib.ny.us a crit :
Quote: |
Hello Gilles
Hi Ron,
"Normal" torquing might lead to overtighten if the threads happen to be
coated with grease or oil, for instance. Denso recommends to hand
tighten, then to tighten one definite fraction of a turn. This way, the
corrrect tension is ensured regardless wether the threads are dry or not.
Gilles Thesee
Grenoble, France
philipgeorge347(at)hotmai Guest
Posted: Mon Mar 20, 2006 11:40 am Post subject: Spark plug Spanner (wrench) |
Hi Alan i think you will find the spark plugs in a 912 are 16mm 5/8 and not
18mm
or they allways used to be .
Phil George G-EORJ 912s xs
Quote: | From: "Alan Burrows" <alan(at)kestrel-insurance.com>
Reply-To: europa-list(at)matronics.com
Subject: Spark plug Spanner (wrench)
Date: Mon, 20 Mar 2006 11:30:36 -0000
Hi All
order one?
Many Thanks
Alan
Posted: Mon Mar 20, 2006 1:10 pm Post subject: Spark plug Spanner (wrench) |
philip george a crit :
18mm
Yes, but the 914 uses 18 mm plugs.
Gilles Thesee
Grenoble, France
Horizonspace(at)aol.com Guest
Posted: Mon Mar 20, 2006 6:56 pm Post subject: Spark plug Spanner (wrench) |
In a message dated 3/20/2006 3:12:10 P.M. Central Standard Time,
Gilles.Thesee(at)ac-grenoble.fr writes:
<Gilles.Thesee(at)ac-grenoble.fr>
Quote: |
<philipgeorge347(at)hotmail.com>
not
Gilles Thesee
Grenoble, France
We use a Sears Craftsman 18mm deep socket (3/8 drive) on our 914.
Tam Pho
