paulrod36(at)msn.com Guest
Posted: Wed Jan 14, 2009 1:11 pm Post subject: In-flight opening of front hinged canopy |
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> When I was scratch-building my canopy, after several iterations I wound up using two barrel bolts, which I made spring-loaded, to slide over and snap into two notches in some 3/16 steel t-bar stock. I haven't flow it yet, but after you release the turning handle, you can hear the barrel bolts snap in place. I think it will hold.
Paul Rodriguez
bryanmmartin
Posted: Wed Jan 14, 2009 1:13 pm Post subject: In-flight opening of front hinged canopy |
I have the old style canopy latches. I have never had one side of m
canopy unlatch as I was trying to latch the other. There is a bit of
slack in the cable that needs to be taken up before the canopy will
unlatch. The two sides latch up independently of each other.
If I was going to use the new style latch, I would definitely alter
the design to allow each side to latch independently of the other. All
it would take is slots on one end of the tie bars linking the latch
hooks to the torque tube and springs pulling each hook towards the
latched position.
On Jan 14, 2009, at 11:50 AM, Sabrina wrote:
| Quote: | When I was building my canopy frame, I was amazed how tinkering with
one side would often release the other side.
I would lock one side, leave the other up. In attempting to lock
the remaining side the original side would sometimes release due to
movement of the release cable. That scared me.
Has anyone else split the release mechanism on the canopy so both
the left and right side need to be released independently?
This way, one has 4 "disengagements" before release, accidental or
whatnot.
I prefer this to the single "disengagement" of the 650. Attempting
to re-latch one side necessarily unlatches the other since it is a
solid arm. Correct?
Bryan Martin
N61BM, CH 601 XL,
RAM Subaru, Stratus redrive.
_________________ --
Bryan Martin
do not archive. |
