Replace Aileron Controls
JAPhillipsGA(at)aol.com
PostPosted: Sun Jan 11, 2009 10:14 pm    Post subject: Replace Aileron Controls Reply with quote
Fellows 601XL Builders and Flyers. Well, I finally finished up on removing the cables from my XL ailerons and replacing them with push pull tubes. Total cost was about $ 100. and took about a whole weekend to complete. Sure would have been easier to install them while building. I made a test flight Saturday morning and I was very pleased with the results. Control is quicker and more solid to the touch. At slow flight, in the pattern and steep turns it was more responsive. At greater speeds the ailerons were about as stiff and heavy as they ever were. I went up to 2,500 feet and took her up to 155 mph and gave her some shakes trying to see if a flutter could be caused and nothing. Lastly, the weigh difference is the push/pull rod system weighs 14.2 ounces more than the wire system. I didn't write up what I did or the materials nor have I taken any photos, but if a ground swell of interest and excitement occurs along with a bunch of pledges to buy me beer at Sun N Fun Bar B Q this spring I might be persuaded to put together an "How & What". Best regards, Bill of Georgia
A Good Credit Score 13x1201028747/aol?redir=http://www.freecreditreport.com/pm/default.aspx?sc=668072%26hmpgID=62%26bcd=DecemailfooterNO62"> See yours in just 2 easy steps!
jbrumpt(at)activ8.net.au
PostPosted: Mon Jan 12, 2009 4:01 am    Post subject: Replace Aileron Controls Reply with quote
I certainly would be interested if we can twist your arm
sky_ranger161
PostPosted: Mon Jan 12, 2009 4:03 am    Post subject: Replace Aileron Controls Reply with quote
Hey Bill,
Count me in for a beer! I'd love to see more details on your "cable to pushrod" mod.
Thanks!
Debo Cox
Nags Head. NC
www.mykitlog.com/debo
Gig Giacona
PostPosted: Mon Jan 12, 2009 6:41 am    Post subject: Re: Replace Aileron Controls Reply with quote
Consider the ground swelling. I'd really like to see how you did it and a materials and any other instructions.
I won't be a Sun N Fun but I have little doubt that we will cross paths in the future and if we do the info will be worth several beers.
W.R. "Gig" Giacona
601XL Under Construction
eldenej(at)yahoo.com
PostPosted: Mon Jan 12, 2009 8:34 am    Post subject: Replace Aileron Controls Reply with quote
There are a bunch of us, I suspect, that at a minimum would very much like to see what you have done; my wings, at this moment, are still open.
Elden Jacobson
xl/3300
--- On Mon, 1/12/09, JAPhillipsGA(at)aol.com <JAPhillipsGA(at)aol.com> wrote:
From: JAPhillipsGA(at)aol.com <JAPhillipsGA(at)aol.com>
Subject: Re: Replace Aileron Controls
Date: Monday, January 12, 2009, 2:13 PM
rfulmer1(at)triad.rr.com
PostPosted: Mon Jan 12, 2009 9:09 am    Post subject: Replace Aileron Controls Reply with quote
Hi:
You can count me in on that beer and ground swell too.....would love to see the method and material package.
Bob Fulmer
PatrickW
PostPosted: Mon Jan 12, 2009 12:41 pm    Post subject: Re: Replace Aileron Controls Reply with quote
I'm interested.
- Pat
paulrod36(at)msn.com
PostPosted: Mon Jan 12, 2009 2:55 pm    Post subject: Replace Aileron Controls Reply with quote
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> Sounds very good, Bill. For those of us who can't make S&F, the basics, (length of tube, material, method of attaching ball ends) would sure be helpful.
Paul Rodriguez
jonaburns
PostPosted: Tue Jan 13, 2009 9:19 am    Post subject: Re: Replace Aileron Controls Reply with quote
I am for sure interested. It should help the autopilot as well...
Jon Burns
Little Elm, TX
Thruster87
PostPosted: Sat Jan 17, 2009 12:15 pm    Post subject: Re: Replace Aileron Controls Reply with quote
Would like to see some pics as my wing skins have not yet been riveted and I'm keen to go the push pull rod path as well.[the Europa from England has been using push/pull rods with great success for years] Cheers
