		PatrickW
  Joined: 27 Oct 2006 Posts: 380 Location: Fort Worth, Texas
				 Posted: Fri Dec 05, 2008 5:47 pm    Post subject: Main Gear Attachment Nut Torque...? |
				Does anyone know the correct torque value for the AN365-820 fiber lock nuts on the 1/2" Grade 8 bolts on the Main Gear Attachment bracket 6B11-4...?
 AC43.13-1B gives values on page 7-9, however I believe these values are for "metal against metal".  In the case of the Main Gear Attachment, we have "Metal against Rubber".
 What have other builders done...?
 - Pat
 PS - The drawings specify that these nuts can be used, and the farm boy in me thinks that the fiber nut is better than the castle nut because a bolt WITHOUT a hole in it is going to be stronger than a bolt WITH a hole in it.  But the torque question is still valid in any case.
  |  | - The Matronics Zenith601-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		GLJSOJ1
  Joined: 18 Aug 2007 Posts: 82 Location: Chesapeake, Virginia
				 Posted: Sat Dec 06, 2008 6:35 pm    Post subject: Re: Main Gear Attachment Nut Torque...? |
				I did mine at 35 ft# and used the castle nuts.  It did distort the extrusion some, but they are tight.  There have been other post on this subject so might want to check the archives also.
  _________________ 601XL N676L  FLYING PHASE I
CHESAPEAKE VA |
		PatrickW
				 Posted: Sat Dec 06, 2008 6:57 pm    Post subject: Re: Main Gear Attachment Nut Torque...? |
				There was some discussion on this topic here:
 http://forums.matronics.com/viewtopic.php?t=52550&highlight=6b114
 Since fiber lock nuts (as well as castle nuts) are specified on the plans, that's what I'll go with, along with "witness paint" to aid in future preflight inspections.
 I torqued them up to 35 ft-lbs for now.  It felt like more would be too much.  My original target torque was around 48 ft-lbs based on the average AC43 value converted to ft-lbs, assuming I read the chart correctly and assuming that it's applicable to Grade 8 bolts, which it may not be.
 Today my XL is standing on it's own gear for the first time.
 - Pat
				 Posted: Sat Dec 06, 2008 9:05 pm    Post subject: Main Gear Attachment Nut Torque...? |
				Here is a quote from a post by Jeff (Afterfxllc(at)aol.com) from Dec 3rd,
 2007 (message #51120) in a thread titled "XL Landing gear nuts Torque":
 "Talked to zenith today and asked if we torque the landing gear nut to the
 specs or just snug and they said it can be torque to specs but good and
 tight is fine also. I told them I would tighten mine down until the angle
 just started to  bend and give them the torque and they said they would post
 it in the updates. It's funny how so many have been built and the question
 has never come"
 -- Craig
		maarten versteeg
				 Posted: Mon Dec 08, 2008 12:08 pm    Post subject: Main Gear Attachment Nut Torque...? |
				Hello Patric,
 Sorry, I don't know the answer on your question. But concerning your
 argument that a fiber nut is better because a bolt without a hole is
 stronger then a bolt with a hole. I would agree that a bolt without a hole
 is stronger than a bolt with a hole, but I also think that the hole only
 affects the part of the bolt that doesn't matter. The hole in the bolt is
 below the grip range of the bolt, so the load on the hole is only the
 cotter pin.
     Maarten
 601 XL, plans building, all aerodynamic surfaces done
  	  | Quote: | 	 		   Time: 05:47:58 PM PST US
  Subject: Main Gear Attachment Nut Torque...?
  Rubber".
  - Pat
  _________________ Maarten Versteeg
601XL  scratch building wings |
