ScottA
Joined: 05 Jan 2006 Posts: 100 Location: Park City, UT
Posted: Mon Mar 13, 2006 6:58 pm Post subject: Installing V530 prop |
About to install the V530. When I take the lifting shackle off the engine will it be obvious that the prop goes on the flange in a certain position? If not, any particular position you are installing them?
Thanks again,
Scott
| - The Matronics M14PEngines-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?M14PEngines-List |
rkent(at)wlacrussianeng.c Guest
Posted: Tue Mar 14, 2006 12:41 am Post subject: Installing V530 prop |
Scott,
It will be obvious, the prop will only fit in one position due to a locator pin on the back of the prop between two of the studs.
Rob Kent
Stores Manager
WLAC - Russian Engineering
www.wlacrussianeng.co.uk
Tel: +44 1628 829 165
Fax: +44 1628 828 961
dsavarese(at)elmore.rr.co Guest
Posted: Tue Mar 14, 2006 4:55 am Post subject: Installing V530 prop |
Yes, it can only be placed on the flange in one direction.
Dennis
ScottA
Posted: Tue Mar 14, 2006 5:43 am Post subject: Installing V530 prop |
Thanks for the info guys.
Scott
From: owner-m14pengines-list-server(at)matronics.com [mailto:owner-m14pengines-list-server(at)matronics.com] On Behalf Of A. Dennis Savarese
Sent: Tuesday, March 14, 2006 5:55 AM
To: m14pengines-list(at)matronics.com
Subject: Re: M14PEngines-List: Installing V530 prop
Dennis
jim1511(at)on.aibn.com Guest
Posted: Wed Mar 22, 2006 5:14 pm Post subject: Installing V530 prop |
Quote: |
Date: 2006/03/13 Mon PM 06:58:28 PST
To: <m14pengines-list(at)matronics.com>
Subject: Installing V530 prop
Thanks again,
Scott
There is a dowel pin on the prop hub so it can only be installed in one position. Jim
Posted: Wed Mar 22, 2006 5:28 pm Post subject: Installing V530 prop |
Yes, it will be obvious. There is a pin on the hub flange. It can only go
on one way.
Dennis
