AW: FW: Rotax 912s water pump outlet
Kevin.Dilks(at)brp.com
PostPosted: Sun Sep 21, 2008 8:54 pm    Post subject: AW: FW: Rotax 912s water pump outlet Reply with quote
Remove the water pump housing and heat with a hot air gun , then turn the water socket to a new position , preferably move , clean and apply loctite 648 then set it the correct place.
This goes also for the cylinder head tubes.
Kevin Dilks
Von: owner-zenith601-list-server(at)matronics.com [mailto:owner-zenith601-list-server(at)matronics.com] Im Auftrag von Brenner, Shai
Gesendet: Samstag, 20. September 2008 07:19
An: zenith601-list(at)matronics.com
Betreff: FW: Rotax 912s water pump outlet
Sent: Saturday, September 20, 2008 7:47 AM
To: 'zenith601-list(at)matronics.com'
Subject: Rotax 912s water pump outlet
I have installed the engine to the engine mount and the cylinder cooling hose is interfering with the
Mount is it possible to modify the rigid water out let in
Rotax 912s water pump outlet or at the cylinder?
Any other solution?
Shai Brenner
CH601 HDS Rotax 912S [quote] http://www.matronics.com/Navigator?Zenith601-Listhttp://forums.matronics.comhttp://www.matronics.com/contribution [b]
