Classic stall characteristics
mz(at)cariama.nl
PostPosted: Fri Sep 05, 2008 5:41 am    Post subject: Classic stall characteristics Reply with quote
As announced in my first posting here from two weeks ago, I am looking to buy a Tri-Gear, and as it happens I have my eye on a Classic Monowheel that was converted into a Tri-Gear back in 1998.
Reading this forum and from talking to a couple of Europa owners/builders, I've come to learn that some Classics have a really nasty wing-drop when stalling. It's my understanding that this is mainly because when building the Classic wings, it is near to impossible to produce port and starboard wings to be 100% symmetrical (if there are any other reasons, I would love to hear them too of course!).
Since I don't want a plane that has a nasty wing-drop, I was wondering: except for flying the plane and performing numerous stalls at a really safe altitude in different configs, are there other ways to find out if a specific Classic might have a nasty wing-drop when stalling?
And: will such wing-drops always manifest when doing stalls, or is it just every now and again?
Being a novice in this area, I f.i. could imagine that a heavy wing in cruise and level, the presence of an aileron-trim, the absence of stall-strips or a tendency to yaw in straight and level might be 'indirect indicators'. Or is this way of thinking a stupid one?
Any tip or trick to identify a plane with a nasty wing-drop is welcome!
Marcel
(PS: no need to talk about speed here, I am fully aware that flying well above stall-speeds in a coordinated matter is a sensible thing to do Wink)
Visit - www.EuropaOwners.org
frans(at)paardnatuurlijk.
PostPosted: Fri Sep 05, 2008 6:33 am    Post subject: Classic stall characteristics Reply with quote
course!).
The classic has less wash-out I believe. So the wings stall more abruptly.
Frans
wooburnaviation(at)google
PostPosted: Fri Sep 05, 2008 6:36 am    Post subject: Classic stall characteristics Reply with quote
I had a Classic Europa that was converted to a Trike. It handled well, and stalled straight ahead - provided the ball was in the middle. I got a bit lazy once, had the ball out to the left, and sure enough I had a wing drop (about 80deg in about half a second )- in other words the incipient stage of a spin.
Standard recovery worked well,( as a reminder:- stick forward to break the stall, smoothly up to full power, roll wings level.) lost about 300 ft. and the aircraft recovered immaculatly. Please also remember the "stall speed" is only wing level and unaccellerated stall speed. Wings actually stall due to the angle of attack ! OK review over - for which I appologise.
In short the stall/ spin is pretty benign, with no nasty habits, HOWEVER, as you point out these are hombuilt aircraft, and vary greatly from model to model. The only way to be sure is to test fly it ( with plenty of altitude, and a suitably experienced pilot).
BTW what is the registration of the aircraft ur looking at, and what's your local ?
Dave
2008/9/5 zwakie <mz(at)cariama.nl (mz(at)cariama.nl)>
[quote]--> Europa-List message posted by: "zwakie" <mz(at)cariama.nl (mz(at)cariama.nl)>
Marcel
sidsel.svein(at)oslo.onli
PostPosted: Fri Sep 05, 2008 7:53 am    Post subject: Classic stall characteristics Reply with quote
Also the XS (with wash-out, as already pointed out) can have sudden wing
drop at stall entry if you are flying alone - mine does. Probably the
slight left aileron down/right aileron up that is necessary to keep wings
level with off-centre crew weight will create different angles of attack at
the outer part of the two wings' span, causing the left wing to stall first
and drop. When flying with a passenger, however, the stall of my XS is very
benign (almost difficult to enter stall in clean configuration). Recovery
is quick and undramatic in either case, nose down and right rudder
immediately stops the wing drop and level the wings.
Svein
LN-SKJ
grahamsingleton(at)btinte
PostPosted: Fri Sep 05, 2008 9:02 am    Post subject: Classic stall characteristics Reply with quote
Marcel
the stall is usually more sudden with the flaps down. Not usually a
problem clean, in my experience. The thing that makes it vicious is if
the stall starts at the trailing edge so that the whole wing "unzips"
suddenly. The cure is to make the stall start at the leading edge and
this is what stall strips do. t
On three Classics that I have helped with we spent a lot of time
profiling the leading edge according to computer generated templates.
All three aircraft have relatively benign stall characteristics, they
also seem quite fast compared to others.
Graham
Marcel
PostPosted: Fri Sep 05, 2008 9:12 am    Post subject: Classic stall characteristics Reply with quote
Just to be clear, I most certainly was impling the use of ailierons to level the wing, BUT that is after the nose has been lowered, and full power smoothly applied, flying speed regained. That is the incipient spin recovery technique. It is deemed safer that picking up the wing with rudder, as that is considered likely to spin you in the opposite direction ! Please, if you have any doubts about low speed handling, book a session with a PFA coach or a Flying Instructor experienced in homebuilts.
Happy Landings
Dave
On 05/09/2008, Carl Pattinson <carl(at)flyers.freeserve.co.uk (carl(at)flyers.freeserve.co.uk)> wrote: [quote]--> Europa-List message posted by: "Carl Pattinson" <carl(at)flyers.freeserve.co.uk (carl(at)flyers.freeserve.co.uk)>
I wouldnt describe the Classic stall as nasty.
If the ball is level, flaps retracted it is unlikely ther will be a wing drop and simply lowering the nose is enough to recover. If the wing drops use rudder (not aileron) to correct the incipient spin.
Elsewhere somebody said level the wings - this implies using aileron which can make the spin worse.
With flaps down many classics will drop a wing but that is probably down to the alignment of the flaps, not the difference in the wings.
Eliminating the wing drop is relatively easy - fit stall strips to make both wings stall simultaneously.
If you are worried about the stall characteristics of the Classic get a ride in one and check it out for yourself. It really is a non event.
mz(at)cariama.nl
PostPosted: Fri Sep 05, 2008 10:04 am    Post subject: Classic stall characteristics Reply with quote
Graham and all,
Speeds, AOA, wash-outs and recovery technique for incipient spins are all clear, I consider those things essential knowledge to everyone acting as P1. Nonetheless thanks for reminding me and possibly others.
I do not worry at all about stalling or incipient spins at safe altitudes, but I would not be happy flying an aircraft that has an 'strong wish' to enter stalls/spins while flying at lower-than-cruise speeds, flaps selected and possibly a slightly high AOA in a not truly coordinated turn. My pattern-flying tends to have small deviations in these things, after all I am not a highly sensitive, nanoseconds-responsive 3-axis AP Very Happy. This probably to more or lesser degree applies to all of us (not implying sloppy flying by anyone here, so don't slap me! Wink ).
Without ever having flown such an aircraft, I guess that turning final is where you really have to be on high-alert with a plane like that, because that's when these elements are easiest aligned for entering a stall/spin that most likely is going to be non-recoverable.
With the above in mind, I want to make sure that the characteristics are within MY PERSONAL limits.
It goes without saying that doing stalls in different configs will be an important part of test-flying the plane. I was wondering if there are other ways you can tell if a plan has a tendency to violently drop a wing.
Hence my question that actually has not been answered: is there any way you can tell from physically inspecting a Classic Europa that it might have a tendency to violently drop a wing?
craigb(at)onthenet.com.au
PostPosted: Fri Sep 05, 2008 2:47 pm    Post subject: Classic stall characteristics Reply with quote
FWIW during my flight training a portion of it was done in two different
Piper Tomahawk's
they both flew nicely, but one, in the stall if you held off the stall long
enough,
had tendancy to almost go inverted, this was with wings level according to
the ball, it always
broke left, even when dual. So as others have suggested IMHO the only way to
know is to fly it and try it for yourself.
craig
mz(at)cariama.nl
PostPosted: Fri Sep 05, 2008 3:40 pm    Post subject: Classic stall characteristics Reply with quote
[quote:cf61ea0bc1="carl at flyers.freeser..."]There seems to be an assumption...[/quote:cf61ea0bc1]
Negative, just trying to find out validaty of the things I've been told. I really appreciate your input, together with
[quote:cf61ea0bc1="raggi6771"]...in two different Piper Tomahawk's...[/quote:cf61ea0bc1]
this places my concerns in perspective for me! I now understand that I can forget about measuring up or doing physical checks in an attempt to predict wing-drop tendency in stalls.
[quote:cf61ea0bc1="carl at flyers.freeser..."]I had the same concerns as you do till my instructor made do this[/quote:cf61ea0bc1]
Good to hear that I'm not the first one with these thoughts (not real concerns in my case though), and that you overcame them Very Happy
In conclusion: I will not be too worried about this, unless extensive stall-testing proofs differently.
g-iani(at)ntlworld.com
PostPosted: Sat Sep 06, 2008 3:09 am    Post subject: Classic stall characteristics Reply with quote
As Carl has said many, if not most, Europas have a 1 degree error in the
turn ball. This is because the bottom edge of the panel is at that angle to
the axis of the aircraft. Europa designed it that way but forgot to explain
in the build manual. Most people, me included, only noticed when the
aircraft had flown.
My aircraft (and G-IRON) are both XSs and have very benign stall
characteristics both straight and turning. This was established with a lot
of testing needed for the new High top (Mod 64b). If anything G-IRON would
drop the port wing slightly. Initially neither aircraft needed or had stall
strips fitted.
During the testing we found that the aircraft are so well behaved it was
very difficult to know exactly when they stalled, they just developed a high
sink rate. David Scouler, who did the testing, pointed out that stall
strips put the disturbed airflow over the tail plane making it far easier to
"feel" the stall. So we tried it and it works well to indicate that the
stall is fully developed.
So do not assume that the presence of stall strips indicate that the
aircraft has bad habits.
Ian Rickard G-IANI XS Trigear, 200 hours
Europa Club Mods Rep (Trigear)
e-mail mods(at)europaclub.org.uk
or direct g-iani(at)ntlworld.com
PostPosted: Sat Sep 06, 2008 6:14 am    Post subject: Classic stall characteristics Reply with quote
Just for clarity,
In spite of my posts in this thred, (all of which I stand by), the classic Europa is, in my opinion a safe, sweet handling aircraft. Provided the aircraft has been set up properly with the stall strips installed as per the manual, you would have to be comatose not to recognise an oncoming stall/spin scenario in it. I flew over 400hrs in one without having any issues at all re the handling of the aircraft.
You'll love it I'm sure !
Dave
On 06/09/2008, zwakie <mz(at)cariama.nl (mz(at)cariama.nl)> wrote: [quote]--> Europa-List message posted by: "zwakie" <mz(at)cariama.nl (mz(at)cariama.nl)>
PostPosted: Sat Sep 06, 2008 12:20 pm    Post subject: Classic stall characteristics Reply with quote
[quote:27bb034c16="g-iani"]
of testing needed for the new High top (Mod 64b).[/quote:27bb034c16]
What is the effect of this hi top mod on max speed and cruise speed?
Frans
