Infinity grip
dogsbark(at)comcast.net
PostPosted: Sat Aug 30, 2008 9:45 pm    Post subject: Infinity grip Reply with quote
Can anyone let me know how much to leave on the stick after trimming for an Infinity Grip? I'll be using the throttle quadrant and stock Van's panel/subpanel.
Sean Blair
#40225
Tim Olson
PostPosted: Sun Aug 31, 2008 5:23 am    Post subject: Infinity grip Reply with quote
You'll probably want to cut as much as possible while still
leaving enough for the infinity insert to attach.
panel/subpanel.
Sean Blair
#40225
nukeflyboy
PostPosted: Sun Aug 31, 2008 7:47 am    Post subject: Re: Infinity grip Reply with quote
Tim,
What did you use to connect the 17 wires - a 21 pin D-sub, or did you use something else?
Dave Moore
RV-6 built and sold
RV-10 built and flying
orchidman
PostPosted: Sun Aug 31, 2008 10:15 am    Post subject: Re: Infinity grip Reply with quote
nukeflyboy wrote:
Tim,
I am using an AMP 17-16 Mouser # 571-2060361 & 571-2060371
Gary Blankenbiller
RV10 - # 40674
(N2GB Flying)
robertrv607(at)yahoo.com
PostPosted: Sun Aug 31, 2008 11:10 am    Post subject: Infinity grip Reply with quote
Just my info. in my case.( I have an RV6A) I did use for the Intercom
and if I re call theElevator? Any how I use the parts that came with
the units,,the female and male, pin unit, one had 21 for the pins
the other I think was 12 or something like that.
I used as per instructions 22 Gauge teflon wires, and solder each
pin to it...not an easy task, but with patience and care, can be done.
In my case turned out to be OK.. same with the P to T. wires from stick
to the controls....
bert rv6a
--- On Sun, 8/31/08, nukeflyboy <flymoore(at)charter.net> wrote:
Subject: Re: Infinity grip
Date: Sunday, August 31, 2008, 11:47 AM
Tim,
Dave Moore
RV-6 flying
RV-10 QB building fuselage
http://forums.matronics.com/viewtopic.php?p 1805#201805
Tim Olson
PostPosted: Sun Aug 31, 2008 3:38 pm    Post subject: Infinity grip Reply with quote
Like most things in the panel....they're all wired direct, no
unnecessary connectors.
nukeflyboy wrote:
Tim,
Dave Moore
RV-6 flying
