Troy Maynor
Posted: Wed Aug 27, 2008 9:08 am Post subject: EGT Probes |
The Rotax manual specifies 2.75" from the flange to the mount point of the EGT probes. Is it a coincidence this centers right on the thick band part of the pipes where they are welded together or are these thicker parts for drilling and tapping? I have the kind that mount with clamps.
Troy Maynor
rampil
Posted: Wed Aug 27, 2008 10:23 am Post subject: Re: EGT Probes |
Troy,
My old and new exhausts both have uniform diameter and thickness
from the block flange to the ball joint. The only care was in siting
the weld-on bung so that the probe, sticking out 4 inches or so
do not obstruct access to the flange nuts or fitting the cowl back on.
In my new exhaust system, I have EGTs on all 4 cylinders.
wooburnaviation(at)google Guest
Posted: Thu Aug 28, 2008 12:33 am Post subject: EGT Probes |
Ira, Troy
I would like to fit a 4 probe EGT to my Europa (912 u/l). What system/display are you using please? Any comments on it's effectiveness appreciated.
Dave
G-CCGW
On 27/08/2008, rampil <ira.rampil(at)gmail.com (ira.rampil(at)gmail.com)> wrote: [quote]--> Europa-List message posted by: "rampil" <ira.rampil(at)gmail.com (ira.rampil(at)gmail.com)>
Troy,
Ira N224XS
[url=http://forums.matronics.com/viewtopic.php?p 0959#200959]http://forums.matronics.com/viewtopic.php?p 0959#200959[/url]
nwcmc(at)tiscali.co.uk Guest
Posted: Thu Aug 28, 2008 1:24 am Post subject: EGT Probes |
I have a 4 probe EGT system but didn’t want to pay for a complicated
engine monitoring display. I used a 4 position rotary switch in
conjunction with a uMonitor system. As the Rotax has no mixture control
the need to make adjustments based on EGT are not required. My main
reason for having 4 probes is to be able to instantly identify which
cylinder is giving a problem should the engine run rough for any reason
(eg rpm drop out of limits on a magneto check). This is easily achieved
with a switch and a single display.
Nigel Charles
