daveleikam(at)wi.rr.com Guest
Posted: Wed Jul 02, 2008 5:12 am Post subject: How tight to make the plumbing fittings? |
How much torque should I apply to 37 degree flare fittings and other NPT fittings for brake and fuel line connections? Thanks for all the input everyone. Building is slowly accelerating as I move through the fuselage!
Dave Leikam
#40496 N89DA (Reserved)
Muskego, WI
bhughes(at)qnsi.net Guest
Posted: Wed Jul 02, 2008 7:04 am Post subject: How tight to make the plumbing fittings? |
Aeroquip specifications 37 degree fittings.
Bobby
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Dave Leikam
Sent: Wednesday, July 02, 2008 7:11 AM
To: rhaugh(at)wi.rr.com; RV-10 matronics; Jeff Point
Subject: How tight to make the plumbing fittings?
Dave Leikam
Muskego, WI
 Download |
| Filename: |
Aeroquip_torq_specs.pdf |
64.75 KB |
| Downloaded: |
236 Time(s) |
ricksked(at)embarqmail.co Guest
Posted: Wed Jul 02, 2008 8:42 am Post subject: How tight to make the plumbing fittings? |
This is invaluable for performance fittings, go to page 50 for torq anf hex flat options for torq, I pasted the PDF and also included the link.
Rick Sked
40185
http://hydraulics.eaton.com/products/pdfs/fc/A-SPPE-MC001-E2.pdf
 Download |
| Filename: |
64.75 KB |
| Downloaded: |
227 Time(s) |
