Carb Heat
bertrv6(at)highstream.net
PostPosted: Tue Feb 28, 2006 2:39 pm    Post subject: Carb Heat Reply with quote
Hi:
First time I try to contact this list.
Question is I do not get any confirmation on my EIS, on rpm drop. when
applying Carb Heat.
I have checked with other rv onwners, they do not understand why?
We check every thing...looks OK..
It is standard RV6A....I have checked when taxing,, after temp is hot..
also during flying...on the pattern, nothing...
My friend with same RV6a, gets 50 RPM drop even when taxing...
He does not have EIS.. has regular gauges..
Any Suggestions, comments appreciated
Bert
RV6A
Steve Glasgow
PostPosted: Tue Feb 28, 2006 3:06 pm    Post subject: Carb Heat Reply with quote
I had the same problem when I started flying. Changed to a better Carb Heater than the original and restricted the opening a bit, then I got a drop. Drop me a line and I will send a photo of what I have on Cappy's Toy.
Steve Glasgow-Cappy
N123SG RV-8
Cappy's Toy
704-362-0005
704-281-7884
Steve Glasgow-Cappy
Cappy's Toy
RV-8 N123SG
tadsargent(at)bellsouth.n
PostPosted: Tue Feb 28, 2006 5:53 pm    Post subject: Carb Heat Reply with quote
I do not get a dramatic drop either, maybe 10 degrees at an altitude of 3-5000 feet, but not on the ground.
Have you checked your carb temp while applying heat?
Tad
Date: 2006/02/28 Tue PM 05:38:49 EST
To: RVSouthEast-List(at)matronics.com
Subject: Carb Heat
Hi:
applying Carb Heat.
Bert
RV6A
Larry Bowen
PostPosted: Tue Feb 28, 2006 6:44 pm    Post subject: Carb Heat Reply with quote
I have about a 20 rpm drop during run-up per the EIS. I have the bigger
heat muff. I think of it more as an alternate air source than carb heat.
From what I've heard little or no drop is fairly common on the RV's.
Larry Bowen
Larry(at)BowenAero.com
http://BowenAero.com
[quote] --
Larry Bowen
RV-8 SOLD,
RV-7QB in progress...
View user's profile Send private message Visit poster's website AIM Address MSN Messenger
robert(at)thenews-journal
PostPosted: Tue Feb 28, 2006 7:54 pm    Post subject: Carb Heat Reply with quote
I've got Vetterman's good carb heat muff and a flange mounted
directly to FAB (no gap as in plans) and I don't get any drop on my EIS.
Like Larry said, I view it more as an alternate air source than carb
heat.
Robert Dickson
RV-6A N69WZ
150 hrs
On Feb 28, 2006, at 5:38 PM, bertrv6(at)highstream.net wrote:
Hi:
applying Carb Heat.
hot..
Bert
RV6A
rwayne(at)gamewood.net
PostPosted: Tue Feb 28, 2006 8:46 pm    Post subject: Carb Heat Reply with quote
I have an EIS and a large heat muff for my carb heat. I get a little drop in
rpm, but about 2" drop in MAP. I agree that your experience is normal for
RVs.
Wayne
Dale Ensing
PostPosted: Wed Mar 01, 2006 4:05 am    Post subject: Carb Heat Reply with quote
"...carb heat muff and a flange mounted directly to FAB (no gap as in plans)
Robert, does this allow for full air flow at wide open throttle?
Dale Ensing
Dale Ensing
RV-6A
Aero Plantation
Weddington NC
PostPosted: Wed Mar 01, 2006 4:19 am    Post subject: Carb Heat Reply with quote
that's a good question, one that I'm not sure I know the answer to. I
set the carb heat up like this after a long conversation with Larry
Vetterman, but I don't think I've ever pulled carb heat at full
throttle. I'm going flying today and will give it a try and report back.
BTW Larry V said that I'd get 50 rpm drop with this setup but I
haven't seen anything on the ground, maybe a little with some altitude.
Robert Dickson
RV-6A N60WZ
On Mar 1, 2006, at 7:05 AM, Dale Ensing wrote:
<densing(at)carolina.rr.com>
plans)
Dale Ensing
PostPosted: Wed Mar 01, 2006 7:52 pm    Post subject: Carb Heat Reply with quote
after a brief flight today I'd have to say no to your question. I
didn't pull carb heat at full throttle, but I tried it at 25/25 (3000
msl) and watched the MAP fall to about 24.4 on the GRT EIS. Of course
with the constant speed prop there was no rpm change. I guess a fixed
pitch prop would have shown an rpm drop.
I don't know how big a deal it is to lose 0.6 in. of MAP. The engine
didn't miss a beat and the plane was still climbing nicely. I hope
this info helps.
Robert Dickson
RV-6A N69WZ
160 hrs
plans)
Dale Ensing
