msm_9949(at)yahoo.com Guest
Posted: Tue Feb 28, 2006 2:35 pm Post subject: Orange peeling |
Hey List:
I'm having a terrible time spray painting Stitts enamel on fiberglass cargo pod. Keep getting that "orange peel" effect. Thinned 5 to 1 with reducer as suggested on can, same problem. Is temperature critical? Equipment? I'm tired of sanding and pod is amost a quart heavier now. Any advice appreciated.
Marco Menezes
Model 2 582 N99KX
Use Photomail to share photos without annoying attachments.
roncarolnikko(at)hotmail. Guest
Posted: Tue Feb 28, 2006 3:22 pm Post subject: Orange peeling |
Marco Orange peel is the opposite of a run. To make a run, or stop orange
peel, turn up the paint and move closer to the work. I would suggest
turning up the air pressure and paint then move faster getting the paint
"wet". See how much you can do on a scrap before making a run. Most
single stage enamels can be wet sanded with 800-1500 grit then buffed to
shine whether it is a run or orange peel you are fixing.
Ron NB Ore
Quote: | From: Marco Menezes <msm_9949(at)yahoo.com>
To: "Matronics.com" <kitfox-list(at)matronics.com>
Subject: Orange peeling
Date: Tue, 28 Feb 2006 14:35:08 -0800 (PST)
Hey List:
advice appreciated.
Marco Menezes
Model 2 582 N99KX
lcfitt(at)sbcglobal.net Guest
Posted: Tue Feb 28, 2006 4:32 pm Post subject: Orange peeling |
Polyfiber Eurothanes are a different formulation - I think - since I
painted, but sanding and polishing didn't work for me. It was explained
that with the Aerothane, the solids will drop to the bottom of the paint
layer and the "clear" will float to the surface. That is exactly what it
looked like when I color sanded and polished. The sanded part had a matt
surface no matter what I did. I don't know about the present product.
Lowell
Posted: Tue Feb 28, 2006 4:37 pm Post subject: Orange peeling |
Marko, in my experience which is admittedly limited, temperature can be
critical and orange peel can be a problem in warm weather when the reducer
flashes off too soon. If you are painting in a warm environment you will
need a higher temperature reducer that will allow the paint to level before
it flashes off. Be careful with applying the Aerothane too heavily because
it's milk like consistency will run very easily. When I painted, I had the
best success with numerous lite coats with a slow reducer.
The worst experience I had was the time I inadvertently used polyspray
reducer instead of the Aerothane reducer. Fast flash and lots of orange
peel.
Lowell
Posted: Tue Feb 28, 2006 9:56 pm Post subject: Orange peeling |
Thanks Lowell and Ron. I'll mess with those variables and see what happens. I'm not using Aerothane on the pod. Poly Fiber Enamel (single stage?) was recommended for fiberglass. Reduces with Xylene. If I can't get smooth finish with next coat, i'll try wet sanding to a gloss or if really fed up, take pod and what's left of quart to local autobody shop. Too cold to paint outside and wife justifiably complaining about me stinkin up the basement.
Marco
Lynn Matteson
Posted: Wed Mar 01, 2006 6:22 am Post subject: Orange peeling |
Marco-
Is it really Stits you are using or Poly-Fiber? If it says Stits on the
can it may be old stuff. Are you sure about the Xylene for reducing
Poly-Fiber Enamel? I know that the P-F Enamel reducer that I have says
"contains Xylene", but maybe they put a little orange peel eliminator
in the P-F Enamel Reducer, and don't say so. I might be a sucker for
the "brand name" stuff, but I did not have a problem with any of my
painting...over fabric with Poly-Tone, or over fiberglass, metal, etc.,
with P-F Enamel, using the P-F suggested products. And did you first
use EP-420 Epoxy Primer to prime the fiberglass? If you want to call an
expert, try Jim Miller at 1-877-877-3334...he's my guru for all things
paintable, and a Poly-Fiber dealer.... www.poly-fiber.com/
Lynn
On Tuesday, February 28, 2006, at 05:35 PM, Marco Menezes wrote:
Quote: |
Hey List:
Marco Menezes
Model 2 582 N99KX
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
JeffFowler(at)aol.com Guest
Posted: Wed Mar 01, 2006 6:58 am Post subject: Orange peeling |
In a message dated 3/1/2006 2:01:20 AM Eastern Standard Time,
msm_9949(at)yahoo.com writes:
Hello Marco
I'm new to the list and, while not having worked with the brand of enamel
you are using, I noticed some clues you put in this reply that might be a
small part of the problem. Not enough ventilation where you are painting will
mean that overspray will get back on what you are painting and cause "some"
orange peel. Try to paint in an area that is between 70 and 84 degrees. Spraying
technique has a lot to do with this problem too. What type of spraying setup
do you have? There will always be a tiney amount of orange peel effect. Look
at the surface of a new car closely in the sun. Just a few thoughts. I don't
own a full scale airplane. I joined this board because I got some plans for a
quarter scale Kitfox IV and the backround comments will help me detail it out
when I build it.
Till Next Time,
Jeff
Posted: Wed Mar 01, 2006 7:16 am Post subject: Orange peeling |
Lynn:
It's a new can of Poly-Fiber enamel, thinned with new PF enamel reducer. Did not use epoxy primer first. My reading suggested it wan't really necessary on fiberglass that was first sanded to give some "tooth." Put another coat on this am with so-so result. I'm beginning to think it's my spray technique that's the problem.
Marco
Lynn Matteson <lynnmatt(at)jps.net> wrote:
Marco-
Lynn
Quote: |
Hey List:
Marco Menezes
Model 2 582 N99KX
Posted: Wed Mar 01, 2006 7:53 am Post subject: Orange peeling |
I sold dupont automotive paint to body shops and the public for three years.
Many amatuers had a hard time following directions or using the right
tools/ technique. Some used laquer primer with fast laquer thinner from the
hardware store. This usually dried to cobwebs before it hit the car. One
solution was to hold the gun really close to the work (or use slower
thinner). Others thought they could take a half hour to put one coat on a
car. I can put a coat on a small car in about 5 minutes which allows the
paint to flow into the starting point instead of overlapping on dry.
Anywhere the paint dries before the next amount hits will not flow and
become orange peel. I have painted bare fiberglass with single stage
enamels and the main problem I have are pinholes that I had missed in
repairs.
It sounds as though you have plenty of paint on to wet sand so try it and
see. Ron NB Ore.
Richard Rabbers
Joined: 09 Jan 2006 Posts: 114 Location: Benton Harbor, MI - USA
Posted: Wed Mar 01, 2006 8:16 am Post subject: Re: Orange peeling |
Marco,
I look forward to sharing flight with you some day since I’m located just a bit south of you in Michigan.
I considered contacting you offline but decided I may as well share my thoughts with the list.
I've got a Model 1 - in restoration. I'm not actively painting but have done a lot of spraying in the past.
List members are contributing very good info – I don’t want to add clutter to the list.
My message is that practice makes perfect.
The line between ‘too much’ paint and ‘too little’ paint is the ‘challenge’ as I see it. Spray tip and adjustment of spray patterns, etc. best done on a board - get happy before you start painting your part.
Monitoring the wet edge, keeping paint thickness consistent, not too much, not too little.
After proper solvents, appropriate thinning, priming and surface prep comes technique.
Practice with some cheap paint on the sidelines until you get comfortable.
Keep in mind that paint types ‘act’ differently so adjustments will need to be made, mostly related to drying times (due to solvents, temperatures, etc.)
_________________ Richard in SW Michigan
Model 1 / 618 - full-lotus floats (restoration) |
Lynn Matteson
Posted: Wed Mar 01, 2006 9:46 am Post subject: Orange peeling |
Marco-
Maybe it's the lack of the epoxy primer that's causing the problem. Be
sure to give Jim Miller a call....he'll know if anyone does, regarding
Poly-Fiber products. The epoxy primer that P-F uses takes a long time
to cure...7 days at 70 degrees F....but that's what they recommend, and
I followed it to a "T" with good results. I can't say that the orange
peel is a result of NOT using the right primer, but the proper
foundation is best to build on.
By the way, where are you in Michigan...upper or lower? Answer to my
email address if you'd like.
Lynn
Kitfox IV...Jabiru 2200
On Wednesday, March 1, 2006, at 10:15 AM, Marco Menezes wrote:
Quote: |
Lynn:
N369LM |
Posted: Wed Mar 01, 2006 12:45 pm Post subject: Orange peeling |
Thanks Richard and everyone else who responded to my post. Last coat went on Ok so i'll try to get my finish with some wet sanding.
Say Richard, did you purchase N120DD from guy in Greenville?
Richard Rabbers <rira1950(at)yahoo.com> wrote:
Marco,
I look forward to sharing flight with you some day since Im located just a bit south of you in Michigan.
List members are contributing very good info I dont want to add clutter to the list.
The line between too much paint and too little paint is the challenge as I see it. Spray tip and adjustment of spray patterns, etc. best done on a board - get happy before you start painting your part.
Keep in mind that paint types act differently so adjustments will need to be made, mostly related to drying times (due to solvents, temperatures, etc.)
Model 1 / 618 lotus floats (restoration)
http://forums.matronics.com/viewtopic.php?p=18744#18744
Marco Menezes
Model 2 582 N99KX
Posted: Wed Mar 01, 2006 12:57 pm Post subject: Orange peeling |
Hi Lynn.
If my problem was from lack of primer there's nothing i'm gonna do about that now! I'm about 6nm WSW of Evart (9C8), right under the Hersey MOA. Have to duck the Warthogs now and again. They always seem to be flying lower than they're supposed to.
Marco-
Lynn
Quote: |
Lynn:
Marco Menezes
Model 2 582 N99KX
Bring photos to life! New PhotoMail makes sharing a breeze.
Lynn Matteson
Posted: Wed Mar 01, 2006 1:40 pm Post subject: Orange peeling |
Ok, Marco...got you located, about 130-150 miles from me, as "the
Kitfox flies" to butcher an old saying. Heck, I could probably visit
you and Deke, and maybe Richard, all on one fill-up this
summer...yee-haaaaa! oops, sorry...
Lynn
On Wednesday, March 1, 2006, at 03:56 PM, Marco Menezes wrote:
Quote: |
Hi Lynn.
Marco-
Lynn
> Lynn:
Marco Menezes
Model 2 582 N99KX
N369LM |
Richard Rabbers
Posted: Wed Mar 01, 2006 2:05 pm Post subject: Re: Orange peeling |
<<Say Richard, did you purchase N120DD from guy in Greenville?>>
Hello Marco,
I bought my Model 1 in Tampa Florida in the fall of 2004 and trailered it north between Hurricanes. The last storm that passed by Tampa area did some damage to the hanger it was in - about a week after I made my trip north.
The plane in Greenville (sold on Ebay) looked pretty slick. I tried to connect with the seller - then the buyer, trying to get a copy of a Model 1 builders manual (still trying to find one) I believe the buyer is from New Hampshire.
regards,
Glenn Horne
Posted: Wed Mar 01, 2006 6:55 pm Post subject: Orange peeling |
Lynn,
What type of gun are you using? Is it a gravity feed or a
siphon? If gravity fed set your presser about 18/25 lb at the gun.
If it's a siphon, set the pressure 50/55 lb at the gun. Also make sure the
paint is thin correctly.
I used aero-thane on my fox and got a smooth job.
Glenn Horne Model II 582
Glenn Horne
Posted: Wed Mar 01, 2006 6:57 pm Post subject: Orange peeling |
It is not for a fabric aircraft. Do not use it.
