Form Blocks and Flanging Dies
SafeAirOne
PostPosted: Wed May 21, 2008 7:16 pm    Post subject: Form Blocks and Flanging Dies Reply with quote
As I prepare to embark on a plans-built 701, I can't help but think that I'll spend a considerable amount of time laying out and building non-flying items such as forming blocks and flanging dies.
It also occurs to me that I will be duplicating the efforts of dozens (maybe hundreds) of other plans-builders who built their own blocks and dies and, after using them once, have them sitting around collecting dust in a corner of the garage.
QUESTION: Is there currently any program where a "community" set of forming blocks is passed along from one builder to another as the need for the particular block/die arises? I figure that if there were, we could all save the time and expense of re-inventing the wheel. The only cost would be the shipping to the next borrower.
I know (and agree) that making the forming blocks and flanging dies is not terribly difficult; In fact, it's kinda fun; However, the more effort and money I put into other stuff, the less I'll have to devote to the actual airframe.
Thoughts, comments...??
--Mark
dan(at)hillsgun.com
PostPosted: Thu May 22, 2008 6:42 am    Post subject: Form Blocks and Flanging Dies Reply with quote
Hi Mark: I remember hearing about a set floating around somewhere on the 601
list, but I made a set of my own. I felt that even if I borrowed a set from
someone that I would have to flange a hole in a part that I either messed up
or forgot to do when I had sent the dies on to someone else. I used the idea
from Debo Cox on the 601 list and made my dies out of timbertech deck
material which is the plastic decking made from recycled plastic I think.
They came out great cost me about $20 bucks and probably a day and a half to
build. All my form blocks are done except the 4 used on the fuselage. Dan.
kmccune
PostPosted: Thu May 22, 2008 9:22 am    Post subject: Re: Form Blocks and Flanging Dies Reply with quote
Their really are not that many on the 701 as the wing is not tapered. I made my own for future rebuilds/modification. Remember your the MFG and you may need to supply yourself with parts in the future Very Happy
I did hear of some flanging dies some ware though.
Kevin
R.W. Emerson (1803-1882)
Dorothy McCune
ifly4fun2(at)sbcglobal.ne
PostPosted: Fri May 23, 2008 5:44 pm    Post subject: Form Blocks and Flanging Dies Reply with quote
Mark,
I believe Larry Winger has a set of steel dies floating around you may want to ask him he's kind
enough to share. He is at larrywinger(at)gmail.com.
Art
701 scratchin
flanging dies.
--Mark
http://forums.matronics.com/viewtopic.php?p=184296#184296
