autopilots
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Avionics-List
Wade
PostPosted: Sun May 11, 2008 6:05 pm    Post subject: autopilots Reply with quote
I've convinced myself that an autopilot is now a 'must have' item. The apparent choices seem to be Trio's EZpilot, or TruTrac's Pictoral Pilot II. Any Pro/Con comments on either. Or alternatives.
Dennis
RV6 - SE VA
- The Matronics Avionics-List Email Forum -
http://www.matronics.com/Navigator?Avionics-List
flybill2usa(at)msn.com
PostPosted: Mon May 12, 2008 5:23 am    Post subject: autopilots Reply with quote
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> Dennis
Have you considered the Dynon AP which sounds too good to be true especially if you are using the Dynon D100 for your primary instrument package. It won't be out until the fall apparently but they are now accepting orders I believe. I agree the an AP is a must have item, particularly if you plan to do much IFR work with it. These airplanes are such good cross country machines, an AP for about 3 grand ($1,500 for the fancy Dynon AP76 and $750 each for 2 servos) is too good a tool to pass up even on a nice sunny VFR day. If it works as good as the rest of their stuff supposedly does.
Bill
RV-7 Finish kit
South Fork, CO
tonyplane(at)bellsouth.ne
PostPosted: Mon May 12, 2008 8:21 pm    Post subject: autopilots Reply with quote
I have been using a Trio EZ Pilot II in my Zodiac 601XL for 374 hours. Never a problem. EZ to install. Works as advertised and would do it again. I would highly recommend an AP. I can have the data stream sent to the AP either via my GPS296 or via my BM EFIS via a switch on the panel.Tony GrazianoZodiac 601XL; N493TG----------------------------I've convinced myself that an autopilot is now a 'must have' item. The
Dennis
RV6 - SE VA
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Avionics-List All times are GMT - 8 Hours
