		maarten versteeg
				 Posted: Fri May 09, 2008 8:21 pm    Post subject: Right wing completed |
				Hello All,
 I am plans building the 601xl wings and have just completed my
 first (right) wing after starting on the wing with the rib form
 blocks on 10/22/06. Plans building takes it's time but I have
 learned a lot and except for the welding of the tanks and the
 fiberglass wing tips made all parts myself.
 The resulting right wing has the aileron with trim attached but
 the flap has been removed. Further on the wing has a tip light
 and strobe (no electronics), landings lights and the heated
 AOA/Pitot tube. Internal surfaces have been treated (especially
 the contact surfaces) with ZnCr. The total assembly weighted in
 at 39.0 kg (or 86.0 lbs).
 - Maarten, San Antonio TX
    601xl plans building wings
  |  | - The Matronics Zenith601-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
  _________________ Maarten Versteeg
601XL  scratch building wings |
		ter_turn(at)yahoo.com Guest
				 Posted: Fri May 09, 2008 9:15 pm    Post subject: Right wing completed |
				Maarten, just wondering, did you install trim, lights, pitot etc. on the right wing for weight distribution purposes?
 Terry Turnquist
 601 XL-Plans
 Maarten Versteeg <maarten.versteeg(at)swri.org> wrote:[quote] --> Zenith601-List message posted by: Maarten Versteeg
 Hello All,
 and strobe (no electronics), landings lights and the        Be a better friend, newshound, and  [quote][b]
		psm(at)att.net Guest
				 Posted: Sat May 10, 2008 1:25 am    Post subject: Right wing completed |
				Hi Maarten,
 Are you planning to add the power supply for the strobe at a later time?
 The strobes supplied by ZAC include a separate power supply for each
 strobe light.  This allows a short set of wires between the flash
 tube and power supply which is advantageous from a radio noise point
 of view.  Perhaps the single supply approach works well too, but it
 would certainly require shielded wire to the flash tubes.
 Paul
 XL fuselage
 At 09:20 PM 5/9/2008, you wrote:
  	  | Quote: | 	 		  the wing has a tip light
		maarten versteeg
				 Posted: Sat May 10, 2008 7:48 am    Post subject: Right wing completed |
				Hello Terry,
 With the trim and pitot yes, I assume that many times I will
 be flying alone and even if I have a passenger she (he) is
 likely to be lighter.In that case any mass on the right side
 will help. I have a heated Dynon pitot so I can keep the
 option open to certify for IFR without opening up the wing
 (if I ever want to pursue an IFR license).
 My plan is to have lights on both sides to I can wire up a
 wig-wag light to have a create a good visibility for my craft.
 I have had so many occasion where the ATC indicated traffic
 that I never saw against the city background that I want to
 go for good visibility.
 The second spar is now on the table so I officially started
 the second wing.
  Terry Turnquist
  601 XL-Plans
		Ron Lendon
				 Posted: Sat May 10, 2008 8:26 am    Post subject: Re: Right wing completed |
				I'm right there with you Maarten,  I just started my second wing also.
  _________________ Ron Lendon
CH 601 XLB
N601LT  - Flying
Corvair Engine Prints:
		maarten versteeg
				 Posted: Sun May 11, 2008 10:06 am    Post subject: Right wing completed |
				Hello Paul,
 I selected the nova electronics wing-tip light units, these
 have a central control unit and shielded cables from that
 unit to the two wing tips. I weighted the EMI causing radio
 noise and requiring a shielded cable versus the additional
 weight in the wing tips and decided for the central unit.
 The Nav lights in this setup are both LED based.
 - Maarten
  Hi Maarten,
  Paul
  XL fuselage
		maarten versteeg
				 Posted: Sun May 11, 2008 10:16 am    Post subject: Right wing completed |
				Hello Ron,
 I just don't have such a nice electronic logbook, my book
 is an old fashioned notebook with some of my pictures glued
 in it. Looking back in the book I see that I started the
 first form block in November 2006, but I actually started
 placing ribs in the right spar in October 2007. So I should
 be able to complete this wing before the end of the year.
 - Maarten
  	  | Quote: | 	 		   Subject: Re: Right wing completed
  Ron Lendon, Clinton Township, MI
  Corvair Zodiac XL, ScrapBuilder
