NO Battery box in my 701. Support only COMMENTS, CRITICISM.
larry(at)macsmachine.com
PostPosted: Mon May 05, 2008 3:41 pm    Post subject: NO Battery box in my 701. Support only COMMENTS, CRITICISM. Reply with quote
Hi Geoff,
There is no requirement for a battery box, but there is an implied
rationale for making whatever electric power device you use secure so
that it doesn't become a hazard to
you or anyone. Secure attachment I think is your case. If it were a wet
battery, a battery box or equal would be logically one answer.
Experimental tag places
options that you have to define. It's probably easier if you look at
the "requirements" as performance-based safety or common sense.
Geoff Heap wrote:
The rivets actually just miss the bottom of the battery. They come a little closer than I meant them to.
Thanks for noticing though. what I'm looking for is criticism. Does anyone know an FAA ruling stating that a battery box is mandatory. I have not tried to research that.
http://forums.matronics.com/viewtopic.php?p=181328#181328
