MHerder
Joined: 11 Feb 2008 Posts: 143 Location: Fort Worth TX
Posted: Sun Apr 27, 2008 8:21 pm Post subject: Upper Engine Mount (BRS Style) |
My drawings show the old style of upper engine mount without BRS, it looks like I need to drill the new one for the 3/8" bolt. Is this correct?
Do I just drill in the center of the box. I just made an x to center it but have not drilled yet?
I am now adjusting the fuselage level, plumb, square etc and it appears that you might be able to make a very small adjustment to the longeron level by drilling a little out of center but I would really feel much better about having this 3/8" hole as close to center as possible.
Does anyone have some photos that detail this a little better. I also need dimensions for the bolts that go to the longeron. I would have liked to have seen this area detailed a little better in the drawings.
Thanks in advance for your help!!!
_________________ Zodiac 601 HD
Jabiru 3300
Wood Sensinich 64x47
Finally Flying |
PatrickW
Joined: 27 Oct 2006 Posts: 380 Location: Fort Worth, Texas
Posted: Mon Apr 28, 2008 9:27 am Post subject: Re: Upper Engine Mount (BRS Style) |
Recommend pinging Zenith on this one, so they know more people are wondering about this, and to get the most-current information from them.
In the meantime, here is a diagram somebody sent me:
http://picasaweb.google.com/Patrick.Hoyt/Zenith601XLBRSBrackets/photo#5190655085433945250
Were any of the other BRS brackets included in your kit? I got just the triangular engine mount ones, but the diagram also shows ones towards the back, near the baggage area. May have to fabricate those, I'm guessing out of 4130. Or maybe a mountpoint across the main gear instead. Just an idea..
Patrick
XL/Corvair
cookwithgas
Posted: Fri May 02, 2008 5:33 am Post subject: Re: Upper Engine Mount (BRS Style) |
Patrick:
Wow! There are lots of ways to skin a cat! (my daughter's least favorite expression). My BRS mounts are completely different from either of the drawings you posted. I got my drawings from BRS, then sent them back some small revisions for the XL since their drawings were for the non-XL 601.
I have an extra attach point up front and my rear point is on the bottom longerons tied into the step support.
I guess all three ways would work if you needed to pull the red handle.
Scott Laughlin
http://www.cooknwithgas.com/BRS.html
Gig Giacona
Posted: Thu May 08, 2008 7:05 am Post subject: Re: Upper Engine Mount (BRS Style) |
Scott, Does your front attach point connect with the bottom longeron?
| cookwithgas wrote: | Patrick:
Scott Laughlin
http://www.cooknwithgas.com/BRS.html |
601XL Under Construction
cookwithgas
