whadath(at)rogers.com Guest
Posted: Thu Apr 10, 2008 4:13 am Post subject: RV10-List Digest: 60 Msgs - 04/09/08 |
Fellow Builders
I am in the process of working on the doors and the main problem I see is that the alignment of the door is controlled by the hinge placement. In my set of hinges there was 1/32 of side play which I shimmed out. If the hinges are installed precisely then the door drops down and closes into the correct position.The only time the door is guided into position is on the last 1/4 inches of travel when the bevelled door edges come into contact with the fuselage. Now in the ideal setting which I guess would be wings off, precisely bushed and installed hinges and standing on the floor outside the aircraft while closing the door, all things work beautifully. But, in real life you will sitting inside the aircraft so there will be no visual references to help guide the door, there will be a hinges/pin mechanism that is forever wearing and causing more play (fore and aft movement of the door) and when you close the door you will be relying to a large extent on that last 1/4 inch bevel to guide the door into the correct position. I am not comfortable with relying on the last 1/4 inch. In my opinion the major mod that should be made is a method of guiding the door into it's correct position. The guide should come into play long before the last 1/4 inch. I am making my door in such a way that it is guided into the correct position and it will be impossible to throw the pins if the door is not properly seated. I believe that the latching mechanism is adequate but mods to the receiver area and to the pin ends can easily be made in any shop.
Doors!!! and I thought building a canopy was a pain!
Wayne Hadath
F1 Rocket C-FAUH
250 hours
RV 10 Fusealge top and doors.
RV10-List Digest Server <rv10-list(at)matronics.com> wrote:
[quote]*
Today's complete RV10-List Digest can also be found in either of the
of the RV10-List Digest and can be viewed with a generic text editor
HTML Version:
http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 08-04-09&Archive=RV10
Text Version:
http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 08-04-09&Archive=RV10
RV10-List Digest Archive
Total Messages Posted Wed 04/09/08: 60
Today's Message Index:
1. 12:45 AM - ATP plug (Chris and Susie McGough)
2. 12:58 AM - Re: Re: The King has no Clothes (Steven DiNieri)
3. 01:08 AM - Re: Door handles (Steven DiNieri)
4. 03:37 AM - Re: Door handles (Bob Leffler)
5. 04:12 AM - Re: RV Grin (Bob Leffler)
6. 04:52 AM - Re: Re: NVFR avionics help (Rodger Todd)
7. 05:16 AM - Re: Re: The King has no Clothes (John Testement)
8. 05:18 AM - Re: RV Grin (gary)
9. 06:16 AM - Re: RV Grin (gary)
10. 06:44 AM - Re: P-Mag! (marcausman)
11. 06:56 AM - 2 blade Hartzell- SnF attendees (Pascal)
12. 07:05 AM - Re: Air field flow for the 10 (Bobby J. Hughes)
13. 07:42 AM - Re: NVFR avionics help (GRANSCOTT(at)aol.com)
14. 08:35 AM - Re: RV Grin (Deems Davis)
15. 08:49 AM - Re: Door handles (Steven DiNieri)
16. 08:54 AM - Re: Garmin 1000 additions (SteinAir, Inc.)
17. 08:58 AM - Re: Re: The King has no Clothes (Steven DiNieri)
18. 09:12 AM - Re: Engine stop tests. (Bill DeRouchey)
19. 09:26 AM - Re: Garmin 1000 additions (RV Builder (Michael Sausen))
20. 09:46 AM - Re: Garmin 1000 additions (Tim Olson)
21. 09:49 AM - Re: Garmin 1000 additions (Tim Olson)
22. 10:07 AM - Re: Garmin 1000 additions (John W. Cox)
23. 11:24 AM - Re: Engine stop tests. (Neil & Sarah Colliver)
24. 11:43 AM - Re: Re: P-Mag! (Larry Rosen)
25. 01:04 PM - Re: Garmin 1000 additions (John Ackerman)
26. 02:59 PM - Re: Re: The King has no Clothes (Scott Schmidt)
27. 03:02 PM - Re: Garmin 1000 additions (Patrick Thyssen)
28. 03:14 PM - Engine Special (Jeff Carpenter)
29. 03:24 PM - Re: Re: The King has no Clothes (Tim Olson)
30. 03:39 PM - Re: Re: The King has no Clothes (Rene Felker)
31. 03:40 PM - Re: Re: The King has no Clothes (PJ Seipel)
32. 03:41 PM - Re: Re: The King has no Clothes ()
33. 03:47 PM - Re: Garmin 1000 additions (McGANN, Ron)
34. 03:54 PM - Re: Re: The King has no Clothes (Deems Davis)
35. 04:07 PM - Re: Re: The King has no Clothes (Bob Leffler)
36. 04:51 PM - Re: Re: The King has no Clothes (Steven DiNieri)
37. 05:09 PM - Re: Garmin 1000 additions (John W. Cox)
38. 05:15 PM - Re: Re: The King has no Clothes (John W. Cox)
39. 05:24 PM - Re: Garmin 1000 additions (John W. Cox)
40. 05:48 PM - Re: AFS Systems (Rick Sked)
41. 05:59 PM - Re: Engine Special (John Cram)
42. 06:30 PM - Re: Re: The King has no Clothes (David McNeill)
43. 06:32 PM - Re: Re: The King has no Clothes (Larry Rosen)
44. 06:51 PM - Re: Re: The King has no Clothes (David McNeill)
45. 07:03 PM - Re: Re: P-Mag! (Jesse Saint)
46. 07:49 PM - Re: Engine Special (Pascal)
47. 07:54 PM - Re: Door handles (Condrey, Bob (US SSA))
48. 07:58 PM - Doors coming off (Chris and Susie McGough)
49. 08:04 PM - Re: Re: The King has no Clothes (Rick Sked)
50. 08:14 PM - Re: Doors coming off (Tim Olson)
51. 08:26 PM - Re: Doors coming off (Ben Westfall)
52. 08:33 PM - Re: Engine stop tests. (Marcus Cooper)
53. 08:35 PM - Re: RV Grin (Marcus Cooper)
54. 08:42 PM - Re: Doors coming off (David McNeill)
55. 09:11 PM - Re: Doors coming off (John W. Cox)
56. 09:15 PM - Re: Engine stop tests. (John W. Cox)
57. 09:33 PM - Re: Doors coming off (Perry, Phil)
58. 10:36 PM - Re: Doors coming off (Kelly McMullen)
59. 10:59 PM - Re: Re: The King has no Clothes (John Ackerman)
60. 11:25 PM - Re: Doors coming off (John Dunne)
________________________________ Message 1 _____________________________________
Time: 12:45:08 AM PST US
Subject: ATP plug
Just recieved visors from Aviation Tech Products. Came within 10 days to
Australia and answered all questions .
Great service.
Chris 388
________________________________ Message 2 _____________________________________
Time: 12:58:06 AM PST US
Subject: RE: Re: The King has no Clothes
When I went to install a set in my rv10, I modified them to be much easier
to install. After seeing my mods coupled with the shipping delays I was
asked to reproduce a similar product by a few builders. I think they are a
very good anchor for the door rods to latch into, and should add a margin of
strength to the latch mech. I do offer them on my website (available
immediately sorry for the commercial announcement, I just want all to
know there are options...
Steve dinieri
Iflyrv10.com
[quote] --
