ahinsdale(at)yahoo.com Guest
Posted: Sat Mar 22, 2008 3:57 pm Post subject: 5th Bearing - What is the Purpose? |
Hello Listers
I have been reading the traffic on the 5th bearing for
the Corvair. I posted this question on CORVAIRCRAFT a
while back and did not get an answer. Simply put..
why would I want a 5th bearing? My impression is that
it applies mostly to extended crankshafts as used in
some KRs, not really to the 601XL installation.
Andy Hinsdale
Never miss a thing. Make Yahoo your home page.
http://www.yahoo.com/r/hs
kmccune
Joined: 22 Sep 2007 Posts: 577 Location: Wisconsin, USA
Posted: Sat Mar 22, 2008 5:41 pm Post subject: Re: 5th Bearing - What is the Purpose? |
The idea is to shorten the distance to the 1st bearing, to transfer more prop load to the case. This may be simplistic, but then there seems to be opinions on this topic, so thats how I'll leave it. There have been some crank failures in the last year of so. I'm not the one to ask about its effectiveness, as I am so not qualified to discuss it.
_________________ “Always do what you are afraid to do.”
R.W. Emerson (1803-1882)
Dorothy McCune |
Kevin Bonds
Joined: 09 Jan 2006 Posts: 171 Location: Nashville, Tn
Posted: Sat Mar 22, 2008 6:11 pm Post subject: 5th Bearing - What is the Purpose? |
Andy
This subject is in a state of evolution. We've had to adjust our thinking, on things, as some failures have occurred. There are a lot of improvements being suggested and worked on right now to make the Corvaircraft engine more bulletproof. I think the engine needs this. I would like a to feel a little more certain, that I have done all I can, to make my powerplant safe--before I install it on my plane and go flying. I have been contemplating different engines in case the Corvair becomes too complicated and heavy.
I'm excited about many of the prospects (brand new cranks; 5th bearing, etc.). I'm excited to see where this may lead. I'm hoping that once the 5th bearing design is decided on; and the new cranks are tested; we can safely get rid of the harmonic balancer. This will help offset the added weight of the 5th bearing. My thinking is that the balancer was designed by GM to address a resonance issue in the car. We' ve changed so much that GM's research can't mean much. The new cranks will even be of a different alloy--which will certainly have different resonant characteristics.
Kevin Bonds
-------------- Original message ----------------------
Hello Listers
Andy Hinsdale
_________________ KevinBonds
Nashville, TN
Plans-building Zenith CH601XL w/Corvair Power
http://home.comcast.net/~kevinbonds |
Ron Lendon
Posted: Sat Mar 22, 2008 6:16 pm Post subject: Re: 5th Bearing - What is the Purpose? |
The corvair engine really wasn't designed for spinning a propeller. Having the 5th bearing will take some of the precession loads out of the crank and transfer them to the engine case.
If you fly the engine gently you will probably never have any problems with crank breakage. I am having the www.roysgarage.com made for my plane just for more peace of mind.
Today I dropped the case and crank off to Roy and showed him a full size blue print of the 1958 machining drawings of the engine. He did take some notes.
_________________ Ron Lendon
CH 601 XLB
N601LT - Flying
Corvair Engine Prints:
ashontz
Posted: Sun Mar 23, 2008 5:28 pm Post subject: Re: 5th Bearing - What is the Purpose? |
I agree. Great engine, it's just needs some help becoming a true aircraft engine. Not much hlep, but some help. I' ve got 3 of them now ready to be rebuilt and just looking at them, you can see the aircraft engine in them. But they do need a little help getting there.
| Ron Lendon wrote: | The corvair engine really wasn't designed for spinning a propeller. Having the 5th bearing will take some of the precession loads out of the crank and transfer them to the engine case.
Today I dropped the case and crank off to Roy and showed him a full size blue print of the 1958 machining drawings of the engine. He did take some notes. |
ashontz
Posted: Sun Mar 23, 2008 5:32 pm Post subject: Re: 5th Bearing - What is the Purpose? |
By the way, how far apart do you two live? Geoff Heap and I are about 3 miles from each other. I'll tell you what, having other builders, that you actually like no less (I invited him to my wedding, we get together at least twice a month if not more), is friggin' priceless.
kmccune
Posted: Sun Mar 23, 2008 6:14 pm Post subject: Re: 5th Bearing - What is the Purpose? |
I agree with ashontz, but I'm building a 701 and the corvair is already a little bit heavy for it. I'm not so concerned about the W&B but more about payload and range. I'm betting performance wise... its kick a$$ though. If I were building a 601 I'd have a corvair, continental or maybe an older franklin (don't know anything about the new ones)
Dorothy McCune |
Ron Lendon
Posted: Sun Mar 23, 2008 6:28 pm Post subject: Re: 5th Bearing - What is the Purpose? |
Andy,
Roy and I are about 3 hours apart by car. I made the trip out to see what he was doing because it looked important, it was.
Yesterday we met where we were both crossing paths about half way to transfer the case and crank and oil pump.
CH 601 XLB
N601LT - Flying
bill_dom(at)yahoo.com Guest
Posted: Tue Mar 25, 2008 4:25 am Post subject: 5th Bearing - What is the Purpose? |
Andy,
The purpose of the 5th bearing is not to extend the crankshaft, it is to avoid breaking the crankshaft due to the gyroscopic force of the propeller.
William Dominguez
Zodiac 601XL Plans
Miami Florida
http://www.geocities.com/bill_dom
[quote]-------------- Original message ----------------------
[quote] --> Zenith-List message posted by: Andrew Hinsdale
Hello Listers
ashontz
Posted: Tue Mar 25, 2008 5:17 am Post subject: Re: 5th Bearing - What is the Purpose? |
Exactly! I think it's a good idea.
[quote="bill_dom(at)yahoo.com"]Andy,
William Dominguez
Zodiac 601XL Plans
Miami Florida
Hello Listers
