GLJSOJ1
Joined: 18 Aug 2007 Posts: 82 Location: Chesapeake, Virginia
Posted: Fri Feb 01, 2008 6:39 am Post subject: GPS ANTENNAE |
Hi All
Question on the placement of the GPS antennae. I have panel mounted my Lawrence GPS and now the antennae will only reach three feet. Has anyone put the antennae over the panel instead of over the baggage area as indicated in the plans.
_________________ 601XL N676L FLYING PHASE I
CHESAPEAKE VA |
gfmjr_20(at)HOTMAIL.COM Guest
Posted: Fri Feb 01, 2008 8:04 am Post subject: GPS ANTENNAE |
I have a Lowrance 2000 panel mounted with the antenna immediately above it on the top of the panel. Has been working fine for 185 hours
George May
601XL 912s
| Quote: | Subject: GPS ANTENNAE
Date: Fri, 1 Feb 2008 06:39:20 -0800
--> Zenith-List message posted by: "GLJSOJ1" <gljno10(at)hotmail.com>
Hi All
601XL BUILDER
ALMOST DONE
CHESAPEAKE VA
http://forums.matronics.com/viewtopic.php?p=161822#161822
&g==
Need to know the score, the latest news, or you need your Hotmail®-get your "fix". Check it out.
dredmoody(at)cox.net Guest
Posted: Fri Feb 01, 2008 8:46 am Post subject: GPS ANTENNAE |
I have my old Lowrance 2000C and a recently bought Garmin 496 on the panel. It's kind of a belt and suspenders issue but I'll only bring both on X-C flights. I bought the Garmin mostly to get the XM weather radar data. Both of them locked onto the satellites with antennas on the forward top skin even inside my workshop so you should have no issues with your antenna placed there inflight.
Dred
---- george may <gfmjr_20(at)HOTMAIL.COM> wrote:
George May
601XL 912s> Subject: GPS ANTENNAE> From: gljno10(at)HOTMAIL.COM> Date: Fri, 1 Feb 2008 06:39:20 -0800> To: zenith-list(at)matronics.com> >
http://www.msnmobilefix.com/Default.aspx
Dred
George May
Al Hays
Posted: Fri Feb 01, 2008 10:06 am Post subject: GPS ANTENNAE |
Dred, and George,
How's the whiskey compass behave with those GPS antennas on the panel?
Do not archive.
Al
On Feb 1, 2008, at 11:43 AM, <dredmoody(at)cox.net> <dredmoody(at)cox.net>
wrote:
Dred
> hours
> George May
Posted: Fri Feb 01, 2008 10:24 am Post subject: GPS ANTENNAE |
Well, one thing to watch out for is that some remote GPS antennas have a
strong magnet in them to hold them to the "dash". Generally the magnet is
glued on and can be pried off.
-- Craig
Posted: Fri Feb 01, 2008 10:36 am Post subject: GPS ANTENNAE |
Not a problem with the antenna, however, I did have to move the compass from the top of the panel up and away onto the canopy due to interference from the Lowrance gps itself.
George
| Quote: | From: alhays(at)hickoryhillfarmsheep.com
Subject: Re: GPS ANTENNAE
Date: Fri, 1 Feb 2008 13:03:43 -0500
--> Zenith-List message posted by: Al Hays <alhays(at)hickoryhillfarmsheep.com>
Dred, and George,
Do not archive.
Al
wrote:
> --> Zenith-List message posted by: <dredmoody(at)cox.net>
> Dred
>> hours
>> George M=======================
&g========================>
Connect and share in new ways with Windows Live. Get it now! [quote][b]
Posted: Fri Feb 01, 2008 11:04 am Post subject: GPS ANTENNAE |
My installation won't help answer that question, Al. My whiskey compass is suspended on it's mounting stalk from the bubble to keep it as far away from the magnetic fields as possible. That being said, I saw someone's remote magneotmeter installation right smack in the middle of a number of high current wires between the firewall and the panel of his plane. Guess what? He said it is spot on! Who'da thunk it?
Dred
---- Al Hays <alhays(at)hickoryhillfarmsheep.com> wrote:
Dred, and George,
Do not archive.
Al
> Dred
>> hours
>> George May
Posted: Fri Feb 01, 2008 11:05 am Post subject: GPS ANTENNAE |
The magnetic mount on Garmin and Lowrance is an option and has to be glued or screwed on if you want it. Velcro mounting is more than adequate for the antenna and allows you to take it with you if you care to use the gps in land mode too. That's how mine are done and it works fine.
Dred
-- Craig
Posted: Fri Feb 01, 2008 1:44 pm Post subject: GPS ANTENNAE |
on my panel I haver the airmap antenna on the passenger side of dash. SIRS Compass is in middle, after adjusting it, it is fine. Keep the antenna about a foot away and you should be good to go.
