Fuel pumps in series can get blocked
gcrowder2
PostPosted: Wed Feb 22, 2006 7:07 am    Post subject: Fuel pumps in series can get blocked Reply with quote
I switched the pumps on my setup from series to parallel as the Ellison
throttle body
on my Subaru setup only requires 3 psi. One big negative on two pumps in
series is that if
there is a blockage, both pumps are taken out. In the parallel arrangement,
if one pump
gets blocked, the other pump can still deliver fuel.
Glenn
[quote]From: "Craig Ellison" <craig.ellison2(at)verizon.net>
Reply-To: europa-list(at)matronics.com
To: <europa-list(at)matronics.com>
Subject: Re: RE: 914 Fuel System
Date: Tue, 21 Feb 2006 17:43:31 -0800
All,
I too had my system set up in parellel and changed to series after talking
to John H. One reason I remember of the conversation was about allowing
proper readings on the fuel pressure/MP differential gauge.
craig ellison
A205/N205CN
Almost ready to fly
Ivor Phillips
PostPosted: Wed Feb 22, 2006 7:56 am    Post subject: Fuel pumps in series can get blocked Reply with quote
Glen that is not actually the case, If one Pump became blocked, ( There
are small mesh filters on the inlet) the second pump would draw its
fuel around the Bi-pass pipe and Non-return valve,
But i agree i would also prefer the Parallel system,
On the Pierburg website there no mention of running these pumps in series ,
schematics only show parallel, Makes you wonder!!!
throttle body
series is that if
arrangement,
if one pump
Ivor Phillips
tonyk(at)kaon.co.nz
PostPosted: Wed Feb 22, 2006 12:06 pm    Post subject: Fuel pumps in series can get blocked Reply with quote
The reason for the change to series based pumps is to bring the fuel pressure down to that specified by Rotax. If you measure the differential fuel pressure to airbox pressure as recommended then you'll find that the pressure delivered by parallel pumps is too high.
Having said that. There are many 914's flying with parallel pumps as this is what Rotax used to show in the installation manual.
Unless you intend retrofitting the UMA pressure sensor there is no need to change.
For new installations the Rotax manual now shows pumps in series with bypass valves
Tony
daseitz(at)cfl.rr.com
PostPosted: Wed Feb 22, 2006 12:56 pm    Post subject: Fuel pumps in series can get blocked Reply with quote
europa flugzeug fabrik
PostPosted: Thu Feb 23, 2006 8:00 pm    Post subject: Re: Fuel pumps in series can get blocked Reply with quote
I have them in parallel, and it would be a rather "Rube Goldberg" arrangement to make them series. That's because I have (all in the trigear console tunnel) a sump I made. It's attached to the front of the floor-mounted fuel valve and has 2 outlets.
In a parallel setup, do you think cutting back the volts on the boost/emergency pump will relieve the pressure? I was thinking a 3.9V 10W Zener diode (if I can find 'em), parallel pair (reasonably matched in Vz) for redundancy. I know I can test it for flow rate etc., but do you see a reason not to do this?
I think that don't come out quite right. Wink The 914 carbs may indeed tolerate excess pressure, but to restate what a famous football coach here once said, "On any given Sunday....a carb may flood!"
Reg,
Fred F.
BEBERRY(at)aol.com
PostPosted: Fri Feb 24, 2006 1:12 am    Post subject: Fuel pumps in series can get blocked Reply with quote
I am really learning about fuel pumps and pressures etc (I think) and wonder
if anyone can comment on the problem I have with getting a smooth running
engine at RPM below about 3600 on my 914. Could it be overmuch fuel pressure
and carb flooding with both pumps on in my parallel system? On the other hand
when doing test engine ground runs I have the pumps, filters etc in view and
there is always only one pump fully working as witness the amount of fuel
flowing through the transparent filter barrels..
Going back to some recent discussions on filters and accumulation of grot.
A good while ago I removed a huge amount of stuff from my carbs and jets,
none of which had been trapped by the filters which were as clean as a whistle.
With my briefish experience of the Rotax I find this curious.
Patrick
paul.mcallister
PostPosted: Fri Feb 24, 2006 6:45 am    Post subject: Fuel pumps in series can get blocked Reply with quote
Fred,
The standard Europa design has the fuel return coming in at the bottom of
the tank. I made my system return the fuel into the top of the tank via a
1/4" aluminum line. I found in my setup with parallel pumps that I did not
did not exceed the maximum return fuel pressure as specified by Rotax.
Paul
n100rh(at)sbcglobal.net
PostPosted: Fri Feb 24, 2006 7:29 am    Post subject: Fuel pumps in series can get blocked Reply with quote
Paul,
Makes perfect sense. This way you aren't returning back against the
hydrostatic pressure of all the fuel in the tank.
Ralph
RK Hallett III
Reno,NV
Paul McAllister wrote:
Fred,
Paul
PostPosted: Fri Feb 24, 2006 8:27 am    Post subject: Re: Fuel pumps in series can get blocked Reply with quote
n100rh(at)sbcglobal.net wrote:
Makes perfect sense. This way you aren't returning back against the hydrostatic pressure of all the fuel in the tank.
If the return line still runs along the floor, I was assuming that the head pressure would be identical -- full tank vs. upward push in the return line. Partial tank; we're in the hole. However, I can just about remember what my Physics 101 prof looked like! Whatever works, though, I always say.
Best would be the routing return line back along the fuselage side, thence to tank top. That one I'm pretty sure of... Wink
Reg,
Fred F..
paul.mcallister
PostPosted: Fri Feb 24, 2006 9:15 am    Post subject: Fuel pumps in series can get blocked Reply with quote
Fred,
Mine runs through the firewall along the side of the fuselage under the
window still and into the tank. It never gets to run uphill.
Paul
rparigor(at)suffolk.lib.n
PostPosted: Fri Feb 24, 2006 9:36 am    Post subject: Fuel pumps in series can get blocked Reply with quote
Quick note on parallel vs series.
In parallel, if 1 pump destroys itself, and some debris jams the 1 way
valve in the pump opened, the other pump, although may be perfectly
functional may not create enough pressure to prevent the playing of silent
night.
Has anyone actual had a pump 1 way fail opened?
Like someone mentioned a Andair or similar 1 way in series with each pump
output could help with both pumps, or one 1 way not allowing back feed
from the aux pump back through main.
Not going to help the excess pressure though.
One thing I noticed on my build is that all fittings are not created
equal. Some have smaller internal holes than other. This for certain can
cause restriction on 914s where flow rates can be 40gph plus. I chose
fittings or bored so restriction held to minimum.
Paul it would be interesting to see if your lack of a too high
differential fuel pressure with both pumps on are in fact because of not
returning to bottom of tank, or because of lack of restriction in return
line??
The thicker the air, the greater the return pressure should be.
Ron Parigoris
