emrath(at)comcast.net Guest
Posted: Tue Nov 13, 2007 6:16 pm Post subject: Nose Gear Leg |
Has anyone found that shortening the leg in anyway reduces the prop ground
clearance? I also find that the Langair web site now states to include a
check for $100 and they will refund or bill for any difference.
Marty in Brentwood TN
Time: 06:55:38 PM PST US
Subject: Price for nose gear leg?
Charlie,
Here is the story on the gear leg mod from Harmon Lang. This is to go from a
-2 to a -3, if you have the -1 I believe you need the new leg, I was unable
to find the price on "the list" either. You probably need to call Van's.
/"The procedure to send the nose gear for modifying.
Pack it up in a box or tube and send it to Langair Machining 33094 Church
Rd. Warren Or. 97053. A drawing for a box is on the web site. A tube from a
carpet core also works. Include $75.00 for the work and enough to ship it
back. Cash or check. We don't take credit cards. Include a return label. We
will remove it from the container, cut the 1 in off, rethread and put it
back in the same container. The rethreading is done with a carbide thread
milling tool running in a CNC mill. If you have the mill you can do this
yourself. Cutter cost and set up will only cost about $300.00 or so. Expect
the time in our shop to be about 4 days. Until we know how many there will
be, we have to set one day aside to do the batch that comes in for the week.
Please help by making the repackaging go as easily as possible. NO
CONFUSION. Harmon"/
bobbyhester(at)newwavecom Guest
Posted: Tue Nov 13, 2007 6:56 pm Post subject: Nose Gear Leg |
Not for sure here, but I think the prop/ground clearance stays the same.
The redesigned nose fork is where the difference is, it allows the leg
to be shorter, therefore allowing more clearance between the nut and the
ground. Just placed my order a few minutes ago
Surfing the web from Hopkinsville, KY
Visit my RV7A web site: http://www.geocities.com/hester-hoptown/RVSite/
Charlie,
CONFUSION. Harmon"/
lifeofreiley2003(at)yahoo Guest
Posted: Tue Nov 13, 2007 7:35 pm Post subject: Nose Gear Leg |
With the new fork there is a 'rake' adjustment.
Shortening the leg does nothing but raise the threads
as the thickness of the fork yoke is narrower. How
much difference in 'rake' (angle on the fork) to my
knowledge has not been published.
Darrell
it allows the leg
Emrath wrote:
<emrath(at)comcast.net>
any difference.
> From: Ralph Hoover <hooverra(at)verizon.net>
> Charlie,
modifying.
as possible. NO
> CONFUSION. Harmon"/
Bill Schlatterer
Posted: Tue Nov 13, 2007 7:42 pm Post subject: Nose Gear Leg |
It is shortened from the bottom which increases ground clearance for the
fork but has no impact on prop clearance. Attached pix might help. Not
sure whose it is but it shows the difference well.
Also the $100 from Lang is really $75 for machining and $25 for freight back
and he sends you a check for the diff. I think mine was about $8 back. He
did a perfect job and I had it back in two weeks. A bargain! Building the
box was the hard part.
Bill S
7a Ark
74.97 KB |
354 Time(s) |
ronlee(at)pcisys.net Guest
Posted: Tue Nov 13, 2007 8:01 pm Post subject: Nose Gear Leg |
The hole for the axle and the forward hole for holding the nose wheel
fairing are in the same place. The top of the fork is in the same place.
The bottom angle has changed but is not a factor.
Ron Lee
Posted: Tue Nov 13, 2007 8:17 pm Post subject: Nose Gear Leg |
Ditto what Bill said. The rake diffrence is in the
fork due to the shortening of the leg at the threads.
No clearance difference at all to my knowledge.
Darrell
--- Bill Schlatterer <billschlatterer(at)sbcglobal.net>
wrote:
[quote] It is shortened from the bottom which increases
pix might help. Not
Bill S
7a Ark
bmeyette(at)gmail.com Guest
Posted: Thu Nov 15, 2007 12:41 pm Post subject: Nose Gear Leg |
So, to make this change, does one just have to swap out the fork, or does
the nose gear leg have to come out, too? I think it'd be near impossible
to get my nose gear leg out now.
Posted: Thu Nov 15, 2007 5:11 pm Post subject: Nose Gear Leg |
Did you even read the SB?
http://www.vansaircraft.com/pdf/sb07-11-9.pdf
Posted: Fri Nov 16, 2007 9:46 am Post subject: Nose Gear Leg |
No, I wasn't aware of any of it until yesterday. Thanks for the link.
brian
Posted: Fri Nov 16, 2007 5:49 pm Post subject: Nose Gear Leg |
Ok, sorry about sounding so harsh. We've been talking about this for about a week on the list.
Brian Meyette wrote: [quote] [quote]--> RV-List message posted by: "Brian Meyette" <bmeyette(at)gmail.com> (bmeyette(at)gmail.com) No, I wasn't aware of any of it until yesterday. Thanks for the link. brian --
rmkeith(at)gwi.net Guest
Posted: Sun Nov 18, 2007 2:54 pm Post subject: Nose Gear Leg |
Has anybody looked into this? Why do you need to shorten the leg? If the reason for the modification is to get 1" additional ground clearance and the new fork provides the proper geometry then why not add a 1" spacer on top of the new fork. No cutting of the existing gear leg and as an added benefit you will have an additional inch of prop clearance. I have a friend that has a new fork assembly on order and I will have an opportunity to check out this theory myself when we install / remove the fork assembly.
Russ Keith
RV9A Slow Build
Posted: Sun Nov 18, 2007 4:45 pm Post subject: Nose Gear Leg |
Won't work.
Ron Lee
Posted: Sun Nov 18, 2007 5:28 pm Post subject: Nose Gear Leg |
Ok, it may work but you will have to drill a hole for the piece that limits the wheel travel.
Ron Lee
